I have a Kenmore Elite model no. 110.24962300 top-loading washer. It recently began to leak from underneath. As best as I can tell, it is coming from the pump- part number 3363394 of the motor and pump assembly. There is a round white plastic disc on the front of the pump, and it appears water is coming from it. What do I do?
  • 1,170 Answers
It sounds like a common problem on top loading washers. This symptom usually indicates that you have a failed inlet solenoid water valve assembly. Completely unplug the washer from the electrical supply and see if the water stops filling. If it does, then you likely have a control board failure. This is rare but possible. If the water continues to fill with the washer unplugged from electricity, I recommend shutting off the hot and cold water supply faucets behind the washer. It is likely that the water will stop filling the washer. This would indicate that you have a failed water valve assembly.
Posted on Jul 11, 2009
How do you remove the cover of a Kenmore elite top load washer . Have a leak and need to find where it is coming from.
water coming from the bad seal on the shaft. Lift agitator, bolt underneath, loosen pull out basket. From spindle. ..seal underneath. Must take cover off first. Slide a butter knife at edges in front at seam. there's a two ,clips. in there. Usually 2 bolts up towards top on inside edge of front cover. Make sure power cord unplugged.turn basket upside down. You will see seal.
Sep 11, 2014 | Kenmore 24032\24036 Top Load Washer
My kenmore elite washer model # 110.24082200 is leaking from bottom. No visible leak from back panel acces...
my kemore whasing machine model10010 .25864400is not drain all c los left sam wather in dram and sound of water pamp like cenot turne tenks Bruno
Aug 21, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Water is leaking from underneath checked all hoses seems like it coming from the top
Could be hoses Sump hose or Door boot seal seperates the inner and outer drum this may have hole in it...
Mar 30, 2010 | Kenmore Elite 45986 Front Load Washer
Washer kenmore leaking water out bottom
Its very possible it could be one of the tubes that run to the fabric softener or detergent.
Dec 30, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
It's an Elite not sure the model number but I have a leak from underneath after the clothes are washed and when the water is discharged before the spin cycle.
this could be a broken hose or a leak from the water pump , if you have an access panel in the back u can check this , or access from underneath
Sep 26, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
I have a top loader kenmore elite washer that is leaking. The service guys have replaced everything from valves, tub ring and the fabric softner dispenser but its still leaking Help
Hi, Did they check the pump seal or the hoses. Does it seem to leak from the front center? Is it leaking while filling or during agitation or spin cycle? Are you getting water every load and is it a little water or a lot?
Please forgive all the questions, I have to ask.
Questions I need to ask in order to assist you as best I can.
Vic
Jun 28, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
My kenmore elite front loader leaks
well you can remove teh boootm acess panel by removingthe 3 screws that run along the bootm of the unit . afete rthat you can set a cycle to wash ans see where the leak is coming from
Jan 28, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite
could be spash over be sure washer is as level as possible
Jun 01, 2008 | Kenmore 22422 Top Load Washer
Leaks water onto floor in front of washer after spin cycle, help
open the door though, put your hand around the rubber boot assy, run *** all around looking for small tears, and or holes, if so replace it. only other thing to do is remove the lower access panel and watch it spin a load and youll be able to detect where te waters coming from
Mar 22, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
paul
paul
