Nokia 6500 Slide Cellular Phone Logo
Posted on Jul 11, 2009
My mobile 6500 slide is not switching on
My mobile 6500 slide is switchedf off and not switching on
Anonymous
Level 1:
  • Contributor 30 Answers
  • Posted on Jul 11, 2009
Anonymous
Contributor
Level 1:
Answers
30
Questions
0
Helped
8883
Points
84
What do you mean sir, your mobile now is dead or not power on or no power
How to unlock my nokia 6500 s1 slide
You can unlock your Nokia 6500 s1 slide mobile from network lock by getting the unlocking service from the online vendor
Mobile Unlock Solutions The Ultimate Website For Mobile Phone Unlocking .To get the service you need to submit your IMEI number to the technical support.
Restriction code for nokia 6500 slide please
If your mobile displays Restriction Code, then it is locked with some network and requires a code to be entered, to allow your mobile to use any network. Restriction code for your Nokia 6500 silde mode mobile can be got at Mobile-unlocker.com which gives easy instructions to unlock your mobile.
3helpful
How i unlock my nokia 6500 slide ?
There are lot of ways to Unlock the Phone from Network lock,But i suggest the Network Unlock code to unlock the Phone from Network ,you can get the unlock code at here
Mobile-Unlocker and follow the instructions below and unlock it step by step.....
1 - Switch on your Nokia 6500 SLIDE without any sim card.
2 - Don't bother as to what is displayed on your Nokia 6500 SLIDE.
3 - Compose #pw+CODE+1#.
4 - The Nokia 6500 SLIDE would then display the message "SIM Restriction Off" and will be unlocked!
Unlocking instructions for Nokia 6500 SLIDE:
Note :For Nokia 6500 SLIDE mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 6500 SLIDE
7helpful
My nokia 6500 slide phone getting switch off automatically every five minutes.. pls give solution
When we do check bus with MXkey this message will show. SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. This error can only repair with MXKEY via internet.So the best way to solve this problem is to concern a good mobile tech.Without going to repairing shop it cannot repair.In case if you are a mobile tech pl reply let me give you the procedure.
3helpful
2answers
My security code is miss plz help me my phone is nokia 6500 slide
first switch off the mobile then press * 3 calling button and then press on off switch your handset will be formated
2helpful
My nokia 6500 slide two days now no more displaying any thing and no more switch on again. please send me solution.
did ur handset fell in water or u are in a cold region.... ?! if it is so then switch off ur mobile, remove the battery and dry it in a hot place also dry ur mobile....
I have an 6500 Nokia phone and i forgot about the security number because i changed it please can i get the number so i can use my phone
Try by following instructions
Warning: Do not enter any wrong unlock unlock codes on your Nokia 6500 mobile phones. If you enter over a certain amount of wrong unlock codes on your mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia 6500 mobile phone without any sim card.
2 - Don't bother as to what is displayed on your Nokia 6500 mobile phone.
4 - The Nokia 6500 mobile phone would then display the message "SIM Restriction Off" and will be unlocked!
The CODE you need to enter is the unique unlock code for your Nokia 6500 mobile phone
No switch on of my 6500 mobile can you advice me?
Press and hold the power key located at the right side bottom corner. It will turn on/off your phone
1helpful
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
