Question about Canon PIXMA MP780 All-In-One InkJet Printer
Missing Colors Within the past month my printer has just started printing only in yellow. All cartridges are full, have done all levels of cleaning, calibrating, and alignments available... still only yellow ink? Tried to uninstall but get message" HP System Check has determined that your system does not match the requirements specified on the box. The following items do not meet the minimum requirements:Your operating system does not match the supported operating systems or service packs." Any ideas short of a sledge hammer?
  • 2,427 Answers
your ink well is clogged, do a few deep cleanings and if that dont work remove the ink well and clean it manually by boinling it in alcohol or submerging it in alcohol
thats the service manual for your printer
nb. my method of cleaning is unconventional but it works for most people
Posted on Dec 31, 2007
Why am I missing colors on prints
Could be the print job you send to the printer is set up to print in black and white.
Or the cartridges are full and the nozzles from the printhead are blocked.
Run a cleaning cycle on the printer. If some colour appears continue till all colours are back for all nozzles.
If you did not use he printer for a long time, remove the cartridges one by one and put a drop of cleaning fluid in the pipes in the cartridge holder (where the ink goes in) tun replace the cartridge and print one or two full sized colour photos, till all colours are back.
Jul 26, 2014 | Kodak ESP 7250 All-in-One Printer
Yellow printhead on my Designjet 3500CP isn't releasing ink
If you can access the printhead, try taking a rag with a small area heavily wet with Denatured Alcohol (this is a cleaning solution that can be purchased at Walmart or most stores with cleaning supplies. Rub the printhead thoroughly with the alcohol for a minute or two, it should help loosen any dried ink. Then try to print or run a print head clean cycle on the printer.
Nov 03, 2017 | HP Designjet CP UV Yellow Ink System...
Check ink levels, if showing full go to the printer properties, printing preferrencess,servicess, nozzle clean,..after cleaning the nozzles check print quality..
Sep 08, 2011 | HP LaserJet 4700 Printer
Don't print the black color
Doing reference on your issue. Double check the ink cartridge to make sure that the cartridge is correctly installed. Also be sure that the black ink cartridge used is compatible with the machine.
The next thing to do is a cartridge cleaning as the belief is that the print head is blocked. If you have done a thurough cleaning, the next thing to do is replace the black ink cartridge to be certain the ink cartridge is not faulty.
I have included print head cleaning instructions in case you have not done this cleaning process.
here is some information from the Brother support site:
If one or more of the ink colors are missing from pages printed by your machine (i.e. received faxes, copies and/or documents printed from the PC etc), nozzles in the print head may be clogged, or the ink cartridge in question may not be installed correctly. Verifying that the ink cartridges are installed correctly and/or cleaning the print head may solve the problem.
Cleaning the print head may solve the problem. When cleaning the print head, you are given the option to clean BLACK ONLY, one of the three colors (CYAN, YELLOW, or MAGENTA), or all four colors at once. For this issue we recommend cleaning only the affected color. If more than one color is missing then choose ALL.
When the machine completes cleaning the print head, press Color Start. A Print Quality Check Sheet will print.
Jan 22, 2011 | Canon MX700 Office All-In-One InkJet...
I am not getting yellow when I print although the cartridge is nearly full
I have had this happen several times with different colors. I wasted an incredible amount of ink cleaning and deep cleaning, even replacing the ink tank with no success. I found something on this site telling me to remove all ink cartridges, unplug the printer for 5 minutes then replace them as the printer asked for them, one by one. I did that with no success. I was ready to toss the printer. I then searched Canon's website under "prints missing colors" which gave a number of things to try. I cleaned the print head using their directions and all my colors are back. Hope this helps. By the way, on Canon's website, they give a number of things to try for this. Just type in "prints missing colors" in the support section.
Jun 14, 2010 | Canon PIXMA MP620 All-In-One InkJet...
Yellow and blue colors disappeared.
Click Here!! For my how-to on how to fix clogged printer cartridges.
If that still doesn't help, Try printing a 'test page' in your printer settings.
If that still doesn't help.... Replace!!
Hope this helps!!
If this was helpful please rate with a 4 thumbs up!! Thanks for using!!
May 23, 2010 | Apple HP DeskJet 940c InkJet Printer
I have a HP photosmart D7460 printer,when I bought it it had all the ink cartridges with it.After first install it told me that Cyan & light Cyan were missing & Black was incompatible as it worked...
you are lucky to have use the cartridges of your printer for 19 months. In my office experience, I am actually replacing the cartridges of my printers within a year. Just a regular life span of an ink refilled cartridge.
May 17, 2010 | HP Photosmart D7460 Printer
Canon pixma mp830 not printing yellow.
This just started happening to me also, I have been using the printer without issue for a few years. Replaced the yellow cartride, still no yellow. Anybody else seeing this?
Feb 23, 2010 | Canon PIXMA MP830 All-In-One InkJet...
One of the 3 colors will not print
This problem may be due to blocked nozzles, faulty cartridges or a faulty print head or main board. The first thing to do is eliminate the cartridges. Do a proper cartridge change on both printers, but swap the yellow and cyan (blue) cartridges between printers rather than fit new ones. If either (or both) of the missing colours now appear, you know the problem is the cartridges; replace it (or them) with new ones.
For example, take printer A, with yellow missing. Do a cartridge change procedure on printer A, but instead of fitting a new yellow cartridge, put in the yellow cartridge from printer B (since you know this yellow cartridge works). If yellow now prints in printer A, you know the cartridge you took out is faulty - put a new yellow in printer B, and throw away the cartridge you removed from printer A. Repeat this process for printer B with the Cyan cartridge.
For one or both printers where the above does not solve the problem, then you can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head across fully into its parking position on the right, so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try a head clean or two. If the missing colours now start to appear, try another clean or two. If still not perfect, leave for 24 hours and try again. If still nothing, report back.
Feb 08, 2009 | Epson Stylus C62 InkJet Printer
Excessive Yellow ink use
Issue The printer is working, but the colors in the printed output are not the expected colors. The output may look as if only one color has printed, or as if a color has not printed, or as if the wrong colors have been printed. Solution Complete the following steps to resolve this issue. Step one: Check ink levels If the print defect is minor, it might be caused by reserve mode operation. When the printer runs out of some colors, it can continue printing using remaining inks, but print quality may be affected. If cyan, magenta, or yellow is out, the printer can print only in grayscale.
NOTE: HP cannot guarantee the quality or reliability of non-HP ink. If ink cartridges have been refilled, try replacing them with genuine HP ink cartridges. Replace any empty print cartridges. To access the ink level gauge, follow these steps.
  1. Press Setup .
  2. Press c00707172.gif to select Tools , then press OK .
  3. Select Display Ink Gauge and press OK . The ink levels are displayed. Figure 1: Ink levels c00410056.gif
    • Each icon corresponds to the cartridge that is the color of the icon. The icons are also in the same order, from left to right, as the cartridges in the printer.
    • If an icon is empty, the corresponding cartridge may need to be replaced soon.
    • The ink levels in non-HP, refilled, and remanufactured cartridges cannot be read by the printer. Instead of an icon, a question mark is displayed for these cartridges. HP cannot guarantee the quality or reliability of non-HP ink. Printer service or repairs required as a result of printer failure or damage attributable to the use of non-HP ink will not be covered under warranty.
Step two: Calibrate the color If the cartridges have not been refilled and none are empty, try calibrating the color.
  1. Open the printer Toolbox :
    1. Open HP Solution Center (click Start , then All Programs , then HP , then HP Solution Center ).
    2. If you have more than one printer installed, make sure to select the correct printer tab in HP Solution Center .
    3. Click Settings .
    4. Click Print Settings .
    5. Click Printer Toolbox .
  2. On the Device Services tab, click Calibrate Color , then follow the onscreen instructions. The procedure takes about two minutes and requires two sheets of paper.
Step three: Clean the printhead If the steps above did not help, clean the printhead.
  1. Open the All-in-One Toolbox :
    1. Open HP Solution Center (click Start , click All Programs , click HP , and then click HP Solution Center ).
    2. If you have more than one All-in-One installed, make sure to select the correct All-in-One tab in HP Solution Center .
    3. Click Settings .
  2. On the Device Services tab, click Clean the Print Cartridges , and then follow the onscreen instructions. Three levels of cleaning are available.
Step four: Contact HP If the error still occurs, click the link at the bottom of this page to contact HP.
Jan 24, 2008 | HP Photosmart C5180 All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
63 people viewed this question
old marine
old marine
