Is this amp safe at mid to low volumes with a pair of polk Lsi15s
Is this amp safe at mid to low volumes with apair of polk Lsi15s? Is there a ''safe'' way to wire them? At this time I can't afford another amp/receiver.
  • 73 Answers
Hi there. This should work for you. Use only one speaker per side.
Thanks
Paul
Posted on Jul 11, 2009
Low volume, seems volume button is wired backwards. push on the left side and volume raises
My Android (not an Iolo) has both a touchscreen volume control--as well as a pair of physical volume control sliders--the latter on the right outside edge. I put the tab into a temp car mount: The resulting friction slid the volume down to nil--the the physical sliders, contacting the mount, proved the culprit (despite the touchscreen volume control setting). I proved puzzled at first, cursing the tab.
Mar 17, 2014 | Irulu iulu 10.1 inch Andoid 4.0 Touchcreen...
Sleuthing a 300/4 low-ohm issue. 300/4 amp history: unknown. just connected today whole system yesterday/today: head unit, 300/4(to 4 polk 6.5" component speakers brand new) 1000/1 (4-W3's),...
Are you sure you getting enough power to push everything. I have seen when the voltage is too low coming in, the amps will shut down so they don't overheat. Once they've cooled off and the volume level is lowered they will kick in again. Low voltage and a heavy draw will create massive amounts of heat.
May 24, 2011 | Jl Audio 500/1 Car Audio Amplifier
I have a pair of polk audio speakers for my pc. They are 4 inches tall and 3 inches wide. There is no volume control on either speaker and would like to know how to raise the sound. Thank you,
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 08, 2011 | Polk Audio AMR50 Computer Speakers
Hi, I have a pair of Polk RT1000i powered towers and one now makes a constant loud humming or buzzing sound. It is not hooked up to the receiver. It does it as soon as its pluged into the wall. Any...
the volume on the speakers are too high. try to put make the speakers the master volume(whatever device you plug in into your speakers make that device's volume go all the way up and then adjust the volume on the speakers to what ever volume you desire.had the same problem with my computer speakers
Jan 16, 2010 | Polk Audio RT1000I Speaker
Need apair passive crossover for pair of maxp64 600 watts
You can easily make one yourself. All you need are two non-polar capacitors of about 1 Farad each. Radio Shack and any respectable electronic component store have them. For a high pass filter (AKA crossover) connect in series with the speaker wires. For low pass operation like a sub-woofer, use it in parallel with the speaker.
Oct 02, 2009 | Car Audio & Video
Changed computer but using same speakers but no volume
Hello there:
if the volume controle is not on the taskbar try to go under controle panel and go to sounds and the adjustments for the speakers will be there. than click on add to taskbar and click apply when finished ok?
best regards mike
Aug 18, 2009 | Polk Audio Audio Players & Recorders
Exact same problem; low volume
1st check your PC if audio is fine with headphones or some other speakers , then check your control panel and test sounds compatibility might that you are using wrong speaker setting in the PC.
The below is the company web link to your speaker set , try this too
http://www.polkaudio.com/homeaudio/specs/recent/amr50/
if nothing works please msg me the exact config of ur PC
Aug 02, 2009 | Polk Audio AMR50 Computer Speakers
I have had a set of Polk Audio SDA1 speakers that I had attached to an old but great Pioneer SPEC-1 pre-amp and SPEC-2 power amp. The old speakers had one connection for the right speaker positive and...
bi-wiring requires the removal of the copper jumpers between the hi and low speaker terminals. you can use two wire pairs twisted together at amp out connections and the four separate ends at each speaker, but the quality of sound will not be as good as buying quality bi-wire cables. But a pair of quality single set of wires at each speaker would be fine, but put jumpers back on and attach to the top terminals, they are designed that way. bi-wiring does allow the crossover to put out a little better sound. Hooking up four sets of wires to the a and b speaker terminals sounds bad. i have had alot of trouble with my rti10's and learned the hard way that it is best to pay more for wires with quality terminations.
Jun 21, 2009 | Polk Audio RTi A7 Main / Stereo Speaker
Polk speakers play very low sound on youtube etc. windows xp
maybe the problem is on the files you play but not your device.
Apr 27, 2009 | Polk Audio AMR50 Computer Speakers
32 people viewed this question
 Grubhead
Grubhead
Steve Allison
Steve Allison
