Question about Lands Phones
The light on the base flickers and the phones have an extremely loud buzz, making it impossible to talk on. The batteries are not old. I have checked to make sure everything is plugged in. Seems like there is a problem with the base and not the phones. Any suggestions before I purchase a new one?
  • 69 Answers
You go for new one
Posted on Jul 11, 2009
There is a loud buz on the phone line
is there a channel selection button/. if so try selecting different channel as lots of electrical equipment can interfere with walkabout phones as can hearing aids. have u asked neighbors if they are having same problem? might be a fault on line? u can check to see if there is a fault on the line by going to bt faultfinder and typing in your phone number and they check it for u for free. hope some of this helps?
Feb 24, 2013 | Panasonic KX-TG6524 Cordless Phone
My wireless phone is about seven years old. There is a loud static sound in the dial tone and a loud buzzing sound when I am talking, which can also be heard by the person I am talking to. I just put new...
Try disconnecting the cordless phone base unit from the phone jack where it's connected and plug in a basic corded phone. If you still have the noise, the trouble is in the phone line itself and you'll need to contact your telephone service provider.
If the phone line isn't at fault, the trouble is in the base unit. Most likely, the power supply filtering isn't working, and you're hearing hum in the audio as a result. If the base unit uses an external plug-in adapter (a "wall-wart") with a DC output, you can try replacing it with a new one. Radio Shack sells replacements. Just be sure to get one with the same voltage rating, the same or higher current rating, and the right polarity plug. It may be that the old adapter isn't filtering any more because of its age.
If the adapter is an AC output type, or the base has a built-in power supply with a regular AC power cord, you should probably shop for a new phone. The trouble is in the unit itself, and you'll spend more trying to have it fixed than it's worth.
Dec 26, 2010 | Uniden Lands Phones
The original battery stopped working. Whenever we picked up the phone it just made a very loud noise in our ears. Now I ordered replacements batteries from ebatts. The red light is always on, slightly...
place the phone in the BASE for several seconds then try it. make sure it is the base and not a stand alone charger. if this does not correct it ensure you have the correct replacement battery for the phone. be aware the first time you charge it ... it has to be charged for at least 12 hours
Dec 08, 2010 | Dual Maxus 5.8GHz Handset Cordless Phone
There is a very loud buzzing on the phone when talking. Does this mean the battery needs replacing?
Because the cordless phones use radio frequencies to receive / transmit what you say and hear, it also picks up other radio interference. I sujest you move the hand set or base station away from other mains operated equipment as this will interfer with your phones.
Aug 04, 2010 | Uniden Cordless Phone
Loud buzzing while other phone is on base. Switching phones on base has no effect on issue. Taking phone off base hitting 'talk' helps with issue, but buzzing returns upon placement on base..
did you have "buzzing" Before these phones? Anything electrical fan etc on the same circut breaker of your house?. Or buzzing start recently with these already running. It sounds like your describing "electrical noise" and not really a issue with the phoned them selves. Try relocating the base if you have another open wall jack and on another circut. If you notice it goes away check whats all on that circut (wall outlet) that you unplugged the base from. depending on the noise or lack of at the new location it would probly be something running on there. ..
Hope this gives ya a solid start on a fix :)
Nov 13, 2009 | Uniden 5.8GHz Cordless Phone
We have a lot of static and loud buzzing on the phone
I had the same issue that started on some 3 year old 5.8 GHZ Uniden cordless phones. I moved it from room to room and same buzzing. I found a older Uniden set I had kept in a desk drawer. I swapped out the power transformer (power cord) and it is clear as a bell now.
Jun 15, 2009 | Uniden 5.8GHz Cordless Phone
Buzzing in both phones
hi,
im working on your problem,
the batteries are not the problem for sure,
have you thought of this loud buzzer being just a reminder of some function of your phone?
such as message, missed phonecalls, maybe an alert (if phone features this function)
im working on you!
good luck
Aug 18, 2008 | Uniden 5.8GHz Dual Cordless Phone
Buzzing Noise When trying to charge
it means your battery is too discharged to charge. when you plug the phone in, it doesn't use the AC power right away, it uses the battery to jump start it until the red lights come on the front, then it will switch to the AC power. try this. turn on the phone with out it plugged in and as soon as those front lights come on, plug the charger in. if the battery is not too discharged i.e. it didn't power down while you were talking to it, it should work. I went through three batteries until i figured it out
May 31, 2008 | LG CHOCOLATE VX8500 Cellular Phone
My new Razar V3a makes buzzing sound
If the buzzing is coming from the keyboard then it's a known problem/feature. Got the same on mine when the keypad is lit up, so rag Motorola, who said sorry, known feature with that model.
Aug 29, 2007 | Motorola Mobility RAZR V3
2 uniden cordless phones aren't working
I always tell people NOT to buy new batteries to try and fix their cordless phone. It seems to rarely solve the problem and you are usually better off just spending the money on a new phone. Unfortunately 5 years is a long time for cordless phones these days. There are so many brands, and so many thousands of models, it's impossible to keep track of them all.
Jul 04, 2007 | Uniden Cordless Phone
Lands Phones Logo
Top Lands Phones Experts
Marvin
Marvin
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
