Question about 2wire 1800HG Router (RG1800HG00)
I have an 1800hg router that wont go to the IP page
I have tried restoring defaults and restarting and re-installing. But whenever I try to bring up the options and configure it the page doesnt load. Well, it loads, and says "done" in the bottom of the browser but just displays a blank page. Any thoughts?
  • backtothefut Jul 11, 2009
    Ok, um, I'm the same person that posted the orignial problem, I guess I wasn't clear enough. The 'router' is a dsl modem too. It's got 4 ethernet ports, 1 dsl phoneline port, and a usb port. I only have the one ethernet cable connected to it right now that goes to just my computer. I have another DSL modem I am using to transmit this, but it would be more convenient to have the 4 slotter up and running for the household internet. none of the pages will load.
    The two devices arent running at the same time or hooked together or anything.
    President:
  • 1,865 Answers
If you have a DSL or cable modem with the same ip address, this problem will occur. Disconnect your ISP modem and connect your computer only to your router, and then open the config page, and change the ip address of the router to prevent future issues
Posted on Jul 11, 2009
I want to configure my router through web,but i ca not connect at 192.168.0.1 web address..
The default IP for the DIR-300 is 192.168.0.1. First, make sure you're entering "http://192.168.0.1" in your browser's address bar. In some browsers, if you try entering just the numbers, it won't work.
If you can't access the setup page at all, that address may have been changed. If this is the case, or you can't log in because you don't remember the username and password, you should reset the router which will restore the factory defaults.Press the recessed rear-panel reset button and hold it in for 10 seconds. Release it and the router will restart. The defualt IP (192.168.0.1) and username and password (both admin) will be restored.
Aug 16, 2011 | D-Link DIR-300 Wireless Router
Wen i push the next button after completeing the wizard installation it brings up a page that says its connect then brings up another page that says page not found
You can configure router with below method. You can also configure it with below method.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then click on WAN settings set it as your internet service provider settings enable DHCP Then click on wireless and enable it. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Jun 26, 2011 | NetGear WGR614 Wireless Router
When i try to console into my router i get a "page cannot be reached" error yes i am using the correct IP
Have you reset the router? Then restart your PC....
Reset the router to factory default
Resolution With the router powered on, use a small thin object to press and hold the reset button for exactly seven seconds. The router lights will flash and this will restore the router to factory default. Connect your computer to one of the routers lan ports with an etherent cable. Open your web browser and navigate to 192.168.2.1. This should show the router status page with the default settings.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 12, 2010 | Belkin (F5D7230-4) Router (587009)
Belkin F5D8230-4 not working
there could be minor system glitch on your router. you may try hard reset on the router just to re-flash the firmware. here's how to do it. unplug the router, press and hold the reset button while plugging the power back in. Release the reset button. This will bring your router to the factory defaults settings. If this is not possible then login to the web utility and reset it. or if you still can access the router homepage you may try this steps:
  1. Type your router's IP address in the address of web browser.
  2. Go to Utilities
  3. Go to Restoring Factory Default Settings
  4. Click the “Restore Defaults” button.
  5. A message will appear asking for your confirmation, click “OK”.
  6. Another message will appear informing you not to turn off the router, click “OK”.
  7. After 60 second, the router’s defaults page will be restored. If it does not, then type in the router’s address "192.168.2.1".
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Apr 29, 2010 | Belkin Wireless Pre-N (F5D8230-4) Router...
Xbox 360 wireless adapter wont connect to my 2wire
Have you tried removing all security protocols on the 2wire and trying to connect?
Good Luck!
Jesse
Jan 05, 2010 | 2wire HomePortal 1800HG Router...
Hi, I am trying to reset my 2wire 1800HG router in order to restore to factory default. I reset to factory default on the webpage for the router, and then hit the reset button on the router itself. Now, I...
you have to open internet explorer and type 192.168.1.254. then go to broadband link at the top of the page. hit the advanced settings then you have to re enter all you information like your username, password etc... i hope the helps you if i doesnt let me know.
May 18, 2009 | 2wire 1800HG Router (RG1800HG00)
2wire IP page won't log in??
If the above doesn't work, try resetting the router back to its factory defaults.  There should be a reset on the router.  Then try the 192.168.1.1 address or 192.168.1.254.
Apr 24, 2009 | 2wire 1800HG Router (RG1800HG00)
1800 hg 2 wire wireless
1.can i use my 2wire 1800hg with vista?hooked up to ethernet connection.- yes its possible make sure you enable dhcp on your lan side of you router and under tcp/ip on your pc set it to authomatic assign IP address and dns server address. most router use 192.168.1.1 as thier default address to access it.
to fix your passkey problem.need to access the router and try to change the passkey then save and don't forget to restart the router after you save it,by unplugging it. "make sure your passkey is 8 characters long"
Nov 11, 2008 | 2wire 1800HG Router (RG1800HG00)
How to use 1800 HG on a non BT IP
i got all green lights on my route and was working a week ago but for some reason it has stop work. please help
Jan 27, 2008 | 2wire 1800HG Router (RG1800HG00)
The D-link di524 router was almost intalled but it never finished intalling
hard reset the box>turn on and press and hold the reset button about 40 sec>And restart the pc and check the pc dont have any static ip>and delete all temp files cookies,clear history>and do restore default
to clear all temp thing open inter net explorer-click-tools-click inter net option- >click-general-and do >and for restoring default click-advance in the top and in the bottom click restore default and apply and ok and try to login and change the ether net cord
Oct 13, 2007 | D-Link AirPlus DI-524 Wireless Router
2wire 1800HG Router (RG1800HG00) Logo
81 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
