Question about Nespresso Le Cube
My nespresso machine has an air lock - how do I clear it
My nespresso c190 makes coffee watery
Have you decalcified the machine? They need descaling about once every year - 18 months, and one MUST use the Nespresso Descaling Pack, which is designed for all Nespresso machines. I can't understand why the capsule holder is tight, unless you have used so-called "Nespresso Compatible" capsules, which can cause this. The machines are designed for use only with genuine Nespresso capsules.
Feb 28, 2015 | Nespresso C190 Espresso Machine
Nespresso Essenza 90 leaking at the bottom seam underneath the used capsule holder, HELP
Try gluing the seam with lock tight glue or similar plastic gluing compound. Let it dry overnight and try again.
Oct 16, 2014 | Nespresso Essenza C90 Espresso Machine
How do i clear the air bubble in the nespresso machine?
OK fill the tank and only use water press the small cap botton and after 5 seconds stop the machein and do the same again untill the pump gets the water into the system
Sep 17, 2014 | Krups Nespresso Essenza XN 2009 Espresso...
No water comes out of C190
Basically there are air pockets in the system that need to be cleared. Make sure the light has stopped blinking before you do this. If the light is blinking it means the machine is too hot. Turn off and unplug the unit. Fill the tank with hot water and run in coffee mode (lever towards you). You have to be patient it may take a while. Let it run till tank is empty. Now start the descaling process. You need to use the Nespresso descaling kit for this. This should solve your problem.
Oct 23, 2013 | Nespresso C190 Espresso Machine
Very slow water flow, barely filling tea cup
It could be a problem with an air bubble or with scale deposits.
It is recommended that you first run a descaling cycle using the proper descaling product. Do not use vinegar as it can damage your machine. Information on descaling can be found here:
http://www.nespresso.com/fileadmin/shared/_img/manuals/Nes_DescalingKit_CBU_internet_081216.pdf
To find more help with your product go to the website below:
http://www.nespresso.com/#/no/en/coffee_machines/selecteur_gamme/machines-le-cube/le-cube-nespresso-auto-d180---110-v-1
Feb 28, 2011 | Nespresso Le Cube
WHEN SWITCHED OFF, WATER LEAKS AT THE BASE OF NESPRESSO C100 MACHINE
I opened mine when this did this - it also happened to my second Magimix Nespresso Manual machine. A short pipe carrying pressurized water had burst. I called Nespresso . parts were not available and they offered me a new half-price machine. We are talking a 4 inch piece of plastic tubing here. Shame on you Nespresso for encouraging me to throw what is otherwise a fine machine....
Nov 14, 2010 | Nespresso Essenza C100 Espresso...
Our machine does not puncture the Nespresso capsule - so we only get murky water.
I just had the same problem with my new (less than one month use) Nespresso U. (the top of the capsule doesnt puncture and only water comes through). I called Nespresso customer service and a very helpful man suggested I run water through three times by pushing the top slider open with the Longa button pushed and then closed without a capsule in the chamber. That released the air bubble and now I am enjoying a wonderful cappuccino again! The customer service is fabulous, there was never a suggestion of charging me and I was told that Nespresso will send me a free loaner machine if anything goes wrong in the future that can be readily fixed over the phone. The Nespresso U is the best thing I ever bought.
Aug 25, 2010 | Nespresso C100B Essenza Single-Serve...
Where might I get a replacement frothing ring (which rests on the post at the bottom of the pot) for the Nespresso Model 3190 milk frother? Mine is lost.
All Nespresso machines purchased through Nespresso or an authorized Nespresso vendor are sold with a one-year warranty. Nespresso offers a comprehensive After Sales Program including troubleshooting services by telephone for the life of your Nespresso machine.
Nespresso’s Online Assistance Service provides a wide-range of technical information concerning your specific Nespresso machine model. In addition, you can request a call back from one of our Coffee Specialists at the time of your choice. Our Coffee Specialist’s technical expertise is at your disposal for assistance with Nespresso machine use, maintenance, as well as spare part replazcement.
While we are able to resolve the vast majority of technical concerns through troubleshooting, repair services through Nespresso’s After Sales Program have been designed for optimum convenience. Repairs for Nespresso machines under warranty include all parts, shipping, labor and the use of a loaner machine during the repair at no charge. For those machines needing repair outside of the one-year warranty, servicing is available at a flat rate per machine model.
Please contact the Nespresso Club at our toll free telephone 1.800.562.1465 during business hours (Monday through Friday between 8:00am and 8:00pm or Saturday between 9:00am and 5:30pm EST) or complete the form by clicking on Service Request and a Coffee Specialists will return your call at the time of your choice.
http://nespresso-assistance.com/index.jp?edge=display.about
Jun 15, 2010 | Nespresso Aeroccino Automatic Milk Frother
Coffee not hot enough Is there a way to modify the factory settings to make coffee/milk warmer for the Nespresso Latissima machine?
Before placing first coffee capsule in the machine, run the large espresso cup button into a cup (clear water will come out). This primes the machine and makes for hotter coffee.
Oct 03, 2009 | Nespresso Lattissima 660.R
Nespresso essenza problem
It's not supposed to make holes in the capsule until the water comes through. So, basically, when you put the capsule in, it pierces the capsule in three spots, on the top. The aluminum part will not pierce until you press the button and water comes through. If water is not coming through, then you can clear the air bubble by opening the lever on top of the machine, pressing the coffee button, and then closing the lever once the water begins to come through.
Jul 30, 2009 | Nespresso Essenza C100 Espresso...
Nespresso Le Cube Logo
1,013 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
