Question about Nokia 6233 Cellular Phone
Headset HS-23 dispays as 'enhancement not supported' when plugged into a nokia 6233
  • 3 Answers
Try a different one or check the pin of ur phone is it write or wrong
Posted on Jul 11, 2009
Can you adjust volume using nokia hs23-headset?
At the side of the headset microphone are 3 buttons, the center is called PTT and the other two adjust the volume.
Jan 12, 2010 | Nokia HS-23 Headset
Enhancement problem
firstof all,,, are you a cellphone technician?if yes just check first the connection in the head set area! use a tester if the connections are ok!
Sep 02, 2008 | Nokia 6233 Cellular Phone
HS-23 problem disconnected
Assuming that the joint which connects the neck strap has been damaged ( see below image )
, I advice you fix the loosed or broken joint back in its proper place permanently by using fevi kwik or some other fast bonding adhesive, but the only problem which will remain is that each time you have to use the headset you will have to wear it through your head andremove it the same way.
Apr 19, 2008 | Nokia HS-23 Headset
Says an enhancement is connected when it is not!
Try to Restore factory settings
To reset some of the menu settings to their original values, select Menu > Settings > Restore factory sett..
Enter the security code.
The default security code for Nokia is 12345
Mar 25, 2008 | Nokia 6233 Cellular Phone
Please help me with a diagram for hs-23 plug connections...
http://free-zg.htnet.hr/GoranJurkovic/nokia/
http://cellphones.hackaday.com/2005/08/16/how-to-make-a-nokia-pop-port-to-female-mini-jack-with-volume/
Dec 03, 2007 | Nokia HS-23 Headset
Headset not Supported
Nokia HS-3 is a stereo headset.
Your phone does not support stereo.
So Use mono Headsets like HS-5.
Nokia 9300 is a stereo supported phone and hence works with the headset fine.
Dec 01, 2007 | Nokia 7610
HS-23 Not Being Recognized by Phone
Rub the pins of your headset, and your phone with some tissue paper or something like that.
You might use some cleansining agent like alcohol.
Switch off your phone while doing that.
I too encounter such problems.
Dec 01, 2007 | Nokia HS-23 Headset
Search for audio enhancement
Press and hold the On/Off button until the blue light flashes, then search for your headset. This is to initiate the headset for pairing, otherwise it hides from other phones to prevent unintended pairing.
Jan 05, 2007 | Nokia HS-36W Wireless Headset
Nokia 6233 Cellular Phone Logo
148 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
Damen Wong
Damen Wong
