Question about Sony Televison & Video
Sony TV shuts off automatically
My 29 inch Sony KV-SZ29M80 TV, shuts down automatically after variable period of running. It started after a power fluctuation probably. before shuttin down the picture gets horizontaly compressed and collapses in the center. on some tv channels it occur early and on same after delayed period. The channels on which it occurs usually have the TV's displayed channel number (top right corner) to become distorted
my local tv repair man has told me that the problem is with the main bord of the tv but he could not sort it out
    Problem Solver:
  • 15 Answers
1.Check first if the shutdown of your tv follows a certain period of time. Example after using it within 12 hours it automatically shut down. If so the the matter is only on settings of your tv.
2.But if your tv shut down at an irregular time the problem is in your board. In this case if your tv still work but still shutting down automatically its better not to use it so that their will be broader damage.
3.The most common defect on this case is loss contact of components due heat and mechanical undergone during the usage of the tv. If you know how to resolder board, try to resolder the components specially those who are showing loss contact. You can recognize it because a good solder one has shinny and no round like on the soldered surface.Try also to resolder important parts such as IC's and transistors. note : a good resolder needs to be done in order to avoid problems and damage.
4.Another possible cause is the tack switch for channels,menu,power and etc. You can remedy it by spraying it a contact cleaner.
5.If the problem still going even after the procedure its better to bring it on reliable and trusted service center.
Posted on Jul 11, 2009
I nead a diagram sony model kv sz29m80
i need a schematic diagram for my sony trinitron kv-sz29m80. it was a one horizontal line
Sep 26, 2011 | Sony Televison & Video
32 inch sony trinitron wega
It will most probably need an overhual of the power supply
Mar 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron WEGA KV-XJ29M50 29" TV - Dead, LED flashes 2 times
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 24, 2010 | Sony KV-XJ29M50 29" TV
How to avoid the sudden increase in sound - sony 29 inches tv
Complain to the station running the loud adverts!
Try plugging the output to an amplifier that is turned lower and reduce the volume of the TV to almost nil. The amplifier re jigs the recieved waves through a filter better than most tv's.
Jun 03, 2010 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Realy chattering in Sony WEGA Trinitron
Hi, that is probly a capacitor in the power supply section near the relay, he failed to keep it charged
whit a good capacitor tester wizard you must be able to find and check for cracked soldering around it or directly on the relays
good luck and hope that will help you/
that is not an expensive repair;half or 1 hr time....
Mar 30, 2010 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Hi...I have a problem with my Sony Trinitron 29
the power supply section should be resoldered....must be loose contact..in power section...
Jan 26, 2010 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Please
Tries to change a new Flyback transformer.
Might need a new power inverter board too.
Feb 23, 2009 | Sony KV-32S45 32" TV
Sony trinitron 29 inch kv j29mn
Possibly dry solder joints or faulty coupling capacitors around the audio section.
Jan 20, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Televison & Video Logo
615 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
