Question about Westinghouse 78500 Casanova White Ceiling Fan
Fan doesnt work and light pulses on and off
Is this a known problem ? How can I fix it ?
Thanks for your help.
  • sa_cornford Jul 11, 2009
    The fan has been installed for about 2 1/2 years and worked fine up until now. Its just started pulsing the light. We dont use it very much and probably not for the last year at all.
    The blades turn fine by hand wit no resistance and I've changed the battery in the remote to make sure it wasnt this.
  • 11,896 Answers
There could be 3 known causes.
1. The wires are not securely attached
2. Motor is fried and is sucking power it can transfer
3. A short in the switch.
You can try replacing the switch or tap directly around the motor itself and see if the brushes inside motor free up. You can also turn fan to on and try spinning by hand to see if she frees up
Posted on Jul 11, 2009
Sys fan nor cpu fan working and black screen
Try a known , good working PS. If that does not do it, you have serious mo bo issues.
Mar 27, 2017 | ASUS PTGD1-LA Motherboard
Has power to the injector but it doesnt have a pulse
Ah, here we are again, Adam! Sounds like the injector ground circuit is not working properly. Do as I posted previously, put a testlight on the positive post of battery, and probe the injector ground terminal. Now crank the car over. If light is flashing, circuit is good. If no light, or light is not blinking, computer malfunction or malfunction in the ground circuit.
Jan 14, 2013 | 2004 Dodge Stratus
When I hit the start button on my NP 115 it begins to sound like the fan labors and pulses until it shuts down and the red light blinks in a series of 6 blinks. It also has a very hit frequency squeak that...
after 5 minute image go out n power indicator steady light orange n status indicator red light blikns in a series of 6 blinks. in the manual book said lamp error.. what mind "lamp error". please help me.
Jul 28, 2011 | NEC NP115 DLP Projector
2001 BMW 330ci Blower Fan quit working
sounds like the resister for the fan is failing. it is located under the dash on the duct work for the blower (fan). you will see two wires going to it. unscrew the bolts or screws that hold it in and replace it with a new one. it should work fine after that.
Sep 02, 2009 | 2001 BMW 330
Headlights/heater fan/wipers don't work. e-brake light on faintly
Check your taillight bulbs. Usually the interior accessories are connected to the taillight circuit as a warning system for when your laillight or breaklight bulbs are blown
Jul 05, 2009 | 1998 Volkswagen Golf
Tv sensor not working ????
Press and hold down the up volume button on the original remote, look at the light (led) on the remote, the light should be lit and slightly pulsing. If no pulse your remote is bad, if you are seeing the pulse try cleaning the ir window on front of tv. Let me know if this helps and please rate this solution. lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Jan 11, 2009 | Sanyo DP42746 42 in. Plasma Television
Lost everything on my laptop as soon as i open it
I dont think you lost everything. Do you see any green power lights and do you hear the normal hard drive and fan sounds when booting up ? If you do and still wont boot up to Windows then reboot and keep tapping on F8 to safe mode and select "last known good configuration". You can also perform system restore.
If you dont hear anything at all, no power and you dont see any green power lights then you may have to plug into another known good power outlet. check that your power connections (including the power adaptor) are secured and if on a strip power off and on. If that doesnt work, try another power adaptor. If those doesnt work
remove the laptop battery and just plug in the adapter.
If youre concern about your personal files you can always take out the hard drive, piggyback it to another hard drive on a known good PC and retrieve the files.
Jan 04, 2009 | Microsoft Windows Vista Ultimate Edition
Continuous blinking standby light
according to the manual try unplugging the cord and waiting 5 minutes then replugging and trying again. If that doesnt help you may want to check the bulb as they have been known to shatter
May 13, 2008 | Sony Grand WEGA KF50XBR800 50" Rear...
Switching from pulse to tone.
Hi There, I had the same problem and what worked with me was by pressing the star button before the number, or if it works with u, by keeping a hard press on thre star button for 3-4 seconds
Jan 10, 2008 | Thomson GE 26925GE2 Cordless Phone
Westinghouse 78500 Casanova White Ceiling Fan Logo
124 people viewed this question
Top Westinghouse Dryers Experts
Paul Bade
john h
Are you a Westinghouse Dryer Expert? Answer questions, earn points and help others
