Question about Garden
Need to fined carb adjustment tool?? - Garden
4 Suggested Answers
KMusselmann
  • 247 Answers
SOURCE: carb adjustment tool
It is probably a star or a square head. You should be able to pick up at any auto parts store.
Hope this helps
Kurt
Posted on Mar 18, 2009
  • 109 Answers
SOURCE: Getting the right tool to adjust carb on Homelite Blower.
Type in "AYP" on google...scroll down to "jackssmallengines.com, in the AYP part number box type number 530035560.
Posted on May 12, 2009
  • 4088 Answers
SOURCE: carburetor tool
Unless you are skilled enough to make your own, you are stuck taking the saw to a servicing dealer as they are the only ones allowed to possess the necessary 'D' head screwdriver. Give thanks to the EPA for mandating the prevention of mal-adjustment pollution.
Posted on Jul 07, 2010
How do you adjust the carburetor?
Most of the newer equipment have EPA carbs that wont allow serious carb adjustment without special tools. The tools are only supposed to be sold to service shops who will make adjustments and then put limiting caps on the adjustment screws. Anyone found defeating these systems can be fined by the EPA. If you think your carb is running a bit lean just use a little bit of choke and see if the engine picks up a bit. Then you can try mixing in some fuel system cleaner into your next tank of fuel and see if that gets you back on track. It is the cheapest way to go before spending any money on shop service or new equipment.
Be safe and good luck!
Oct 03, 2014 | Homelite Garden
How to adjust carb screws on husqvarna 125b blower
You need a special carb screw tool for Walbro carbs. Readily available from eBay, search ''Carb Adjusting Tool for Partner/Husqvarna''
Apr 12, 2013 | Husqvarna Garden
My husqvarna 122c starts fine with the choke on. When the choke is turned off, the motor revs very high then eventually dies. If I feather the press the throttle, it dies right away? carb issues?
This is classic fuel starvation, replace the fuel filter in the tank, check the fuel hoses from the tank to the carb for signs of leaking or slits and cracks, failing that you may need to adjust the fuel mixture, there is a special tool to adjust the mixture screws, part no. 530035560 ( try the web for sellers ) once you have the tool unscrew the H screw 1/4 turn to adjust the upper fuel supply.
Oct 24, 2011 | Garden
When cutting and after letting off throttle saw runs for maybe 10 seconds and then stalls. Have to constantly restart because will not continue to idle. Runs fine at full power just will not idle for any...
The carb may well have anti tamper sleeves on the jet screws, or will need a special splined tool to adjust them, the tool is part no. 530035560, if there are caps you will have to gently screw a self tapping screw into the end, when it hits the head of the screw behind it will draw off, you only need to adjust the L screw, i would suggest turning out 1/8 of a turn to richen it up a little.
Jun 26, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Runs full throttle but dies when let off gas, carb new, plug new, fuel line new, ?
It could be as simple as carb adjustment,if it was a new carb it will be set at base settings, which is just intended for running the machine ready for fine tuning for individual machines, unfortunatly you need a special tool to make an adjustment, part no. 530035560, once you have this tool you need to unscrew the L screw on the carb to richen up the idle mixture.
Feb 04, 2011 | Husqvarna 450 e-series 18" Chain Saw
Trimmer will start but as soon as i depress the trigger it dies. I have had to replace the primer bubble and in doing so made sure the gasket was put back on properly IT JUST WONT STAY RUNNING can you...
Your trimmer is starving for fuel. If it is less than 18 months old, my guess is that it just needs a carburetor adjustment. If it is older than 18 months, it should have the carb cleaned and rebuilt, or replaced. Check with homelite.com for the cost of a replacement carb, sometimes they are less expensive than having the old one repaired. If it just needs an adjustment, find a local repair shop to do it for you. Homelite requires a special tool to adjust the carb, and won't sell the tool directly to consumers. Some shops will sell the adjustment tool. No special tools are required to replace the carb, just basic tools.
Sep 11, 2010 | Homelite Mighty Lite Lawn Trimmer
My home lite start when on half choke but shuts off in a few seconds to a min. or if i put it on run it immediately stalls
Your trimmer is starving for fuel. If it is less than 18 months old, my guess is that it just needs a carburetor adjustment. If it is older than 18 months, it should have the carb cleaned and rebuilt, or replaced. Check with homelite.com for the cost of a replacement carb, sometimes they are less expensive than having the old one repaired. If it just needs an adjustment, find a local repair to do it for you. Homelite requires a special tool to adjust the carb, and won't sell the tool directly to consumers. Some shops will sell the adjustment tool. No special tools are required to replace the carb, just basic tools.
Sep 09, 2010 | Homelite Mighty Lite Lawn Trimmer
24cc craftsman 2 stoke trimmer. took apart everything and cleaned. new fuel lines. cleaned air filter. ran fine saturday. now sunday bogs out while trying to throttle up or just stalls.
Low side adjustment on the carb needs to be opened up or the carb needs to be overhauled. To open up the low sie, find the carb jet adjustment screws. The screw closest to the cylinder is the low side. Turn the screw counter-clockwise 1/2 turn. You may need to romove tho plastic locks from the adjustment screws, or if it is fairly new, you may need to buy a special tool to use on these screws. The tool is available anywhere that sells Poulan parts. If adjusting the screws doesm't fix it, the carb will need to be overhauled or replaced. Check with www.searspartsdirect.com . Replacement carbs are sometimes cheaper than an overhaul.
Aug 30, 2010 | Craftsman 25cc Gas Line Trimmer
Twin mikuni carb adjustment
it wont hrut to have a tune up on the carbs but to set them back in sync you need a tool for it and you would need to reset the fule mix after that as well,
Mar 13, 2010 | 2005 Yamaha V Star Classic
Ryobi SS30 Carburetor Problems
Replace thecarb screen, make sure you can see through the screen
Aug 18, 2009 | Ryobi Garden
Garden Logo
200 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
