MY GOODMAN AIR HANDLER IS DRIPPING WATER FROM THE BOTTOM
  • 614 Answers
You may have dirty stopped up drain pan or drain. Take a dryvac and **** the drain from outside. This will clear all the drain. Is it cooling ok? Is the unit in an attic? The drain is not hard to clean. Check your coil(evap) inside to see if this is clean. Rus
Posted on Jul 11, 2009
Why does the drip pan overflow?
The pan may have been installed incorrectly but it also is possible that debris may be clogging the outlet periodically.
Jul 16, 2015 | Goodman Manufacturing Goodman ARUF182416...
What cause 3 amp fuse to keep blowing when power in turn on goodman 16 sier air handler
Hello...
Apparently, there is an overload or shorted wires. Elequipo Disconnect electricity and check the cables are in good condition.
Nov 13, 2014 | Goodman Manufacturing Goodman ARUF48D14...
Heating elements not energizing on Goodman AFUE 60 air handler
FIRST i would use a multi meter and check elements for power. one or more may not be working. SECOND iwould check sequenser . also look for burnt wires at element and throughout. probably sequensor they are usually under 20 dollars. the wires on very bottom of sequensor should have 24 volts when heat is on.
Jan 21, 2014 | Goodman Heating & Cooling
Water is leaking from the air handler in the house?
stopped up drain or rusted out pan. should have auxiallry pan under a/c air-handler.
Aug 18, 2013 | Goodman CKL36AR36 Air Conditioner
Air handler keeps running
Most likely this the fan delay. They weld closed and cause the fan to continuously run. They are available at your GOODMAN dealer.
Feb 20, 2013 | Goodman Manufacturing Goodman ARUF193116...
Not hot air
One of three issues
Thermostat not wired properly
failed heat sequencer in air handler
bad heat element in air handler
Feb 10, 2013 | Goodman Manufacturing Goodman ARUF182416...
Air Handler is leaking water, drain lines are clear. does not leak when unit is on and the back is off the air handler
Most air handlers pull air through the evaporator coil which produces the water and then the blower sucks some of the water off the surface preventing the water from going to the drain pan. A drain trap at the drain pan should be also installed. All manufactures used to ship drip shield panel to install in drain for down flow applications, some do not now unless noted on order that the system is to be in the down flow configuration.
Sep 11, 2011 | Goodman CKL60AR60 Air Conditioner
Our fujitsu reverse cycle AC is leaking water at bottom left hand side of the internally mounted blower unit
Your drain for the inside unit is stopped up and the water condensate that drips off of the coils when the AC is running has no where to go, so it drips off of the collection channel and over flows to the bottom of the air handler, gravity dictates the place where it leaks. You are going to have to unstop the drain.
Feb 01, 2011 | Fujitsu 24C1 Air Conditioner
Heating & Cooling Logo
440 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
