Question about Freezers
Am planning to make burger at home as ahome business. so pls. show me how can freeze my product for market ?
  • 60 Answers
To stop them freezing into a single block of meat put a sheet of greaseproof paper, sometimes called baking parchment, between each patty. You also buy ready cut individual sheets for just this job, or freeze in trays with a big sheet between each layer.
Posted on Jul 11, 2009
I need the owners manual for the estate chest freezer model no. tcf1510ew00, or if someone could just tell me the temp settings for each number? it shows on the side that 4 is i guess the freezing point...
The numbers are generic and don't mean a thing. They are there to make you feel like you have control. Anything under 1 should be very much frozen. If it is not then you have T-stat problem and should address that. Chest freezers run at -25f on average if the freezer has enough product in it. The more food in the freezer the better and more efficiently it will run.
Apr 10, 2014 | Whirlpool 10 cu. ft. Chest Freezer...
I have a Admiral freezer Model F1053. I was wondering how old it is and what you thionk it is worth if I sell it? I works fine.
I don't know how old your freezer is. These freezes can run for decades. About the only thing that will go wrong with them are, leaky freon which isn't producted anymore. It a against the law to own, product, distribute, black market it and freon based the R series, such as, R12, R16 etc. If this happen to your Admiral Freezer I don't think the make a retro-fit kit for it for modern day coolent 134a and some others.
If the conpressor is working and no rattles an it keeps food item frozen to about 14 or 16 below zero and it appearance is striking. I would it's awesome!! $50 to $125 max... GB stewbison
Aug 20, 2011 | Freezers
I have had my True Freezer for a short time. I bought it brand new. I opened my business on Oct 19th. Since then the service man has had to come 6 times to try to correct the problem with the defrost. To...
Hello there: You didn't give out enough informations for me to think what is wrong with a new unit like yours.. What did the serviceman been doing durring these 6 times service call. Did the unit ever work even for one day? Did he change the defrost timer or just made adjustment on the timer. What happen, is the unit icing up so much so that the unit is just a block of ice and that blocked the circulation of the freezing cold air around the unit . Ice is only 32 degree and that is why you only can get 40 degree box. May be the drain tube always frosten up that cause the ice building back up to the coil and form a big lumb of ice. Let me know what is happening , did he add some gas in everytime he service your unit? Let me know more and I will try to solve your problem. Dickson
Nov 04, 2010 | True Freezers
Correct suction line pressure
If it is R22 then it will be about 11psig on the suction side. This should give you a -18 degrees across the coil.
Jun 30, 2010 | True 49 cu. ft. / 1388 liter Commercial...
What do the three buttons mean at the top of our neff freezer
First, I'm not a Neff representative.
* Check your warranty. Call for support.https://www.neff-home.com/uk/service/support
* Website; https://www.neff-home.com/uk/products/fridges-freezers/fridges
* Manual (official - requires you to register.); https://www.neff-home.com/ie/service/manual
*** The following is for information only.***
* Model needed for specific solution.
* The buttons are for setting the coldness (harder?)
* There are some models that can change the chill "box" section to a freezer.
* Product specs (Official); https://www.neff-home.com/uk/products/fridges-freezers
* Neff Integrated Fridge Freezer K8524X8GB Product Overview (check 0:35) ; https://www.youtube.com/watch?v=NVqMz7cbY4o
* Neff K5920L0GB Side By Side American Fridge Freezer; https://www.youtube.com/watch?v=92ugO2ArjaA
* Neff KA3902B20G Side-by-side fridge-freezer; https://www.ruislipappliances.com/images/PDF/KA3902B20G.pdf
* Catalogs; http://pdf.archiexpo.com/pdf/neff-9796.html
* Products; http://www.jamesratfordbridge.co.uk/downloads/Neff_brochure.pdf
* NEFF KI2823F30G Built In Fridge;http://www.creativelivingni.co.uk/neff9.pdf
* use the posted contacts for specific support.
Aloha, ukeboy57
Jun 06, 2010 | Neff 3.80 cu. ft. / 108 liter Upright...
Franklin FIM 70 Keeps freezing up and now stopped freezing totaly
throw it away...i have the same problem. the company is out of business and no parts available.
Feb 20, 2010 | Franklin Freezer Chef FIM70 Commercial Ice...
Used freezer won't freeze food
If the compressor is running and it still doesn't cool, it is probably leaking freon. If this is a frostless model there are other minor things that can go wrong. This usually shows up on a freezer that has recently been moved or hasn't been used for a time. This is almost never worth fixing as even if you fix it you can't ever completely trust it again. The food inside is usually worth far more than the freezer and most homeowners insurance doesn't cover it anyway.
Jun 30, 2008 | Freezers
Whirlpool upright frost free freezer
over charging can certainly keep it from freezing depending on the pressures how much it is overcharged the sealed systems on whirlpools have a five year warranty with your history id call whirlpool cust relations and discuss this problem with them they will help not customer assistance cust relations they are different talk highly of their product and tell them you think you just got a lemon thats all and it hasn't ever worked right now Whirlpool cares about their customers most people believe that the factories just build things to last till the warranty runs out that's not true they want you happy with their product on average one unhappy customer will tell 20 people and that's bad for business they would be happy if you never had a problem with their stuff so give them a call tell your mom had Whirlpool your granny had whirlpool you got your whole kitchen whirlpool this is the first Whirlpool you've had a problem with so you think it just must be a bad unit let me know what they tell you now that's customer relations you want to call ok
Feb 20, 2008 | Freezers
Freezers Logo
67 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
