Question about Ecoquest Flair Air Purifier
EcoQuest Flair Air Purifier
I am hearing like a electrical sound comming from my purifier. I found the source of the problem. It is a little black modual with to red wires comming out of it and a little white tube with a little metal piece in the center of it. How can I get this part or at least a schemetic drawing?
  • 3 Answers
Re: EcoQuest Flair Air Purifier
The part you are describing is the Ozone generator. You can find them easily on Ebay however its important to get the same one so that the hook-up matches and also the amount of ozone it generates is correct for the EcoQuest Flair room capacity selector on the back of the unit. Sometimes ozone generators make a hissing sound but that doesn't mean that they are bad, especially if you are still smelling fresh purified air coming from the unit. If you can't smell the fresh air on any setting then it needs replaced. the sound you are hearing may be coming from the ceramic ozone plates that slide into the unit. You can test it by getting a piece of 1"plastic PVC tubing (about 12" long ) and placing it near the plates and then listen with the other end up to your ear. It's import never to touch the plates while the unit is on because you will get a nasty shock ! Electricity can't pass through the PVC so you are safe testing it this way. You can also email the customer service dept. at EcoQuest by going to their website. Be prepared for a slow response. Hope this helps. DM
Posted on Mar 26, 2013
Get more distance from the two sparking points....with the power disconected, pryde the two metal points apart as mach as a quarter of an inch!
Posted on Nov 19, 2007
0 characters
3 Points
Open the back and change the Ozone plate. then slide out the ION plate and clean it with denatured alcohol. If no light inside, you may have to replace the bulb and / or starter. Hope that helps.
Mar 18, 2010 | Ecoquest Flair Air Purifier
Ecoquest flair fan replacement. Cannot read the model # on fan.
I can help you get a replacement fan for your flair if you still have not found one. You can reach me at
Oct 12, 2009 | Ecoquest Breeze AT Living Air Purifier
My Flair Ari purifier makes much more noise
Sounds like Motor or bearing is failing.
You could order parts but you will find it less expensive to replace unit. Than trying to repair.
Please rate. Hope this helped. If i can help you further let me know. Good luck!
Mar 09, 2009 | Ecoquest Flair Air Purifier
Ecoquest Flair Air Purifier leaves black residue on walls and...
The black residue is what is in your air. The reason for it to cling to the walls is the Ionization process that the machine creates. The ionization is to create a clean breathing space, free from contaminants. All particles floating in the air will be negatively charged and cling to each other or to objects in the room (like walls) that are positively charged.
If you cook, there is some smoke created, or when you burn candles. These greasy particles will stick to the wall or to surfaces. Cleaning them up regularly might help. You can also try another product from EcoQuest called EcoH which is based on enzymes and cut through that grime easily. That might take the black stuff off the walls.
Mar 01, 2009 | Ecoquest Flair Air Purifier
Have the same problem with my flair but am searching for a local shop. However I did find this site if you are interested...I know nothing about them...just found it and am passing it on.
Sep 01, 2008 | Ecoquest Flair Air Purifier
You need to order two ceramic plates and a lint filter. The lint filter is the one that goes on the back. The two glass plates are what ionizes the air. They do not make them from glass anymore. You will need to go to the ecoquest website nd order the parts. It will run you right about $75. Ecoquest bought Flair out a few years ago. Hope it helps.
Jul 24, 2008 | Ecoquest Flair Air Purifier
Living Air Purifier (Flair Model) Ecoquest
Pull the unit out of the box and flip it upside down. You should see it
Feb 16, 2008 | Ecoquest Flair Air Purifier
Flair air purifier
You can download the users manual and troubleshooting guides from the Ecoquest web site.
Oct 21, 2007 | Ecoquest Flair Air Purifier
Ecoquest Flair Air Purifier Logo
182 people viewed this question
Top Ecoquest Air Purifiers Experts
Custom Exchange
Custom Exchange
Level 1 Expert
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
