Question about SanDisk Sansa c200 MP3 Player
I lost my adapter that connects computer to the download songs and rechare it!!
I lost my connects the mp3 to the I can recharge it and put new songs on it!! Where can I find just that piece??
Thanks for helping...
Re: I lost my adapter that connects computer to the download songs and rechare it!! - SanDisk Sansa c200 MP3...
Try Ebay or
Posted on Dec 04, 2007
0 characters
3 Points
How can i recover my songs in my mp3 yp-k3 samsung. when i tried to use it after i connect it in my pc it says no file. please help me with this i need to recover my songs. thanks...
You may try this data recovery which helped me before. You can download trial for free
Please be noted that your mp3 memory should show as a drive letter in your explorer, if not, you need to take out your memory card and connect using a card reader, or plug-in to card reader slot if there's any on your computer.
Mar 03, 2011 | Samsung YP-K3 MP3 Player
How do i download music to a sharper image 1GB mp3 player
Downloading songs to an MP3 player is similar on all the MP 3 players.
If you would like to download to your MP# player and then listen to MP3 files on your computer, then you need:
1.An Internet connection
2.An MP3 player.
If you find a song on the web as MP3 file, and you like to download it to your hard disk , all you have to do, double click on it.
Most songs range between 2 and 4 MB, so it will take 10 to 15 minutes unless you have a high-speed Internet connection.
Once the song has finished downloading, try to double-click on the file and see what happens.
Once you have downloaded the songs, connect the MP3 player with the computer via the USB cable that has been given in the box.
One end to go inside the MP3 palayer and the other to go in the usb port on the computer. The moment you connect the MP3 player the somputer will detect the MP3 player. You can then save the copy of songs you have downladed on your MP3 player.
You can select the sond saved on your compuet by doing a CTRL+C key and then go to:
2.Under the drives section it will show your MP3 player.
3.Click on the player to go inside so that you you can do a A CTRL+V and copy the songs on the MP3 player.
That should do the trick and you shoudl be able to listen to your favourite songs on the move.
Please rate me if you are happy with the support provided.
Sep 15, 2009 | Sharp MP3 & Digital Media Players
I lost my sansa fuse driver. were can i find a new driver?
just connect it to your it as a external hard disk and copy paste songs on to should work...
May 21, 2009 | SanDisk Sansa Fuze MP3 Player
Lost usb connection cord any suggestions??
I bought a new usb connector in The Reject shop for $2. MP3 back up and running!
Dec 28, 2008 | Verge DFP-200 MP3 Player
Lost CD that came with Sony MP3 Player
you dont need any special program here are some instructions for you hope this helps
**Drag and Drop**
Connect your MP3 player to the computer. Some MP3 players connect directly to a USB port, while others connect to a USB port by way of a specific USB connector that comes with the MP3 player. Open the folder on the computer that contains the music files you want to transfer. This is usually the "My Music" folder, available from the "Start" menu, but it can be any folder where you save your music files. Scroll down to the song you want to transfer to the MP3 player. Right-click on the title. When the options are displayed, click on "Send To." Scroll down the "Send To" options and select your MP3 player. This can be listed as your MP3 player's name or as "Removable Drive." Click on this selection. Continue this process until you have transferred all songs that you want to your MP3 player.
--**Windows Media Player**--
If you have a large playlist to transfer, you may prefer to do it from your media player, such as Windows Media Player. Once your MP3 player is connected to the computer, open Windows Media Player. Click on the "Sync Music" tab. Drag songs that you want from your Windows Media Library over to the "Sync Music" column to create a playlist. Click the "Begin Sync" tab at the bottom once you have all of the songs on your playlist. This action will sync all of the songs to your MP3 player with one click. Disconnect your device once songs have been transferred by clicking on the "Safely Remove Hardware" icon in the bottom-right side of the desktop tray.
Jul 14, 2008 | Sony Network Walkman NW-A1200 MP3 Player
Im trying to put my songs in the mp3 and take out the old songs to. Can you help me?
Got to download the program. Go tu Itune download the program for your mp3. Do musice serach on, select your songs and download songs to your computer. Connect your mp3 to your computer. Use the itune software to open up your music library and music list, the download your songs to your mp3..also erase from your play list your old songs.
When you connect your mp3 you might have to configure it out (adjust ) to the itune the computer will promt you and guide you thru the steps.
Jul 12, 2008 | GPX MP3 & Digital Media Players
Kaser Mambo Mano 4GB YoFun104 - I have spent already 12 hours on it
my mambo-mano mp3 playar cannot play songs & movies all songs sea error please give me sugession
Jul 10, 2008 | Kaser Corporation Yo!Fun 100 MP3 Player
Downloading software
the iRiver 700 Series Players use a software package called iRiver Music Manager for loading music.
The software package can be downloaded from iRiver at this link:
You can also find firmware upgrade software there.
May 26, 2008 | iRiver iFP-790 MP3 Player
RCA Opal M4002 MP3
Maybe you can delete that song by connecting your MP3 to the computer or any pc that is available. Once you have connected, you can browse the file on the drive designated by the computer.
By using the computer you can add more songs or you can delete the song that is not necessary.
may this regards, melnavz
Feb 22, 2008 | RCA OPAL M4001 MP3 Player
Downloading songs from computer to mp3 player
If you songs are downloaded in a folder for example my music,,,after you connect your device (mp3) into the usb port in your computer or laptop you wil get a notification of new device being installed, you follow directions on screen. Once the mp3 is intalled the you can goto my computer and you will see an icon on the screen for it. Click on it open it up, minimize the screen, no go to my music folder , open it up, minimize it too, now you have the two floders open, just drad the music from the my music folder to the mp3 folder icon and there you go,, i have found these to be the easiest way to do it. please advice.
Sep 23, 2007 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa  c200 MP3 Player Logo
Top SanDisk MP3 & Digital Media Players Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a SanDisk MP3 and Digital Media Player Expert? Answer questions, earn points and help others
