Question about Car Audio & Video
I have checked all connections to my amp battery,head unit,remote or trigger wire,fuses,power cable,rca leads,ground wire,amp has a green led light on it indicating if it works ok,red if it`s not,light shines green telling me it`s ok.Ihave hooked up another speaker to amp to test and see if subby has blown,it has not,i have changed rca leads in the back of the head unit from rear to front.I still have no sound coming from amp to sub woofer,Have i blown the channels in my amp i am wondering ?
  • 655 Answers
Hello scottsmad1,
You do not specify the make and model of your amp, so it is not possible to point you to specific troubleshooting information. However, some problems are generic and it appears that you have already isolated the problem to the amp itself.
It's still possible that the head unit does not provide a strong enough input signal, but your amp should have a level control that allows you to match it to the head unit. I'd also doublecheck the other amp settings. If the setting check out, it's likely that the amp is defective.
Hope this helps.
Posted on Jul 11, 2009
How do I wire external amplifier
In order for this to work correctly you need:
  1. Power wire (with fuse) from battery to amp (+)
  2. Ground wire from amp to car chassis. (-)
  3. remote-on lead from a 12V power source that turns on and off with the ignition if the head unit does not supply a wire. (switch)
  4. RCA connection from head unit to the amp. (sound in)
  5. Speaker wire connection from amp to speakers. (sound out)
It is easiest to start with deciding on the amp mounting location, and then running all the wires. Add an extra foot or so to each wire. You may discover in the process that you have to move things around due to unforeseen obstacles. This extra foot will help in that case. Always attach the ground wire to the chassis first and then to the amp first. Once you have the fused power wire from the battery installed; remove the fuse before trying to attach it to the amp. ONLY re-install the fuse once all connections to the amp are made, secure, have been checked twice and you're ready to test it.. This includes speakers. DO NOT for ANY reason have the amp powered up before attaching ALL speaker connections.
Feb 23, 2015 | Panasonic CQ-C1100U CD Player
Connected a Dual XPA2100 300 watt amp to the battery and connected ground to chassis of vehicle. Vehicle is 2004 Saturn Ion with battery located in trunk area. Amp does not power on, all connections are...
The remote wire DOES need to be connected to the head unit. You can see if thats the problem simply by touching the remote wire to the power wire. The unit should come on. The head unit should either have a remote lead, or a power antenna lead, and thats what you need to turn the amp on and off. BE SURE your ground is solid, and its usually best to take that to the battery as well to prevent unwanted engine noise. Hope this helps!
Sep 25, 2011 | Dual XPA2100 2/1 Channel 300 Watt...
WHAT DO IT MEAN FOR MY AMP TO READ DIAGNOSTIC
The diagnostic light, for this particular model, means that there is either a short circuit on the loudspeaker leads or there is an internal amplifier fault that is causing a DC offset. In order to determine which, disconnect all RCA and speaker leads while keeping the +12 volt, power ground and remote leads connected. Now turn the amplifier back on, and if the diagnostic LED lights up, the amp has an internal fault. If not, plug the RCA cables back in and reset the amp. If it goes into diagnostic now, the problem is with the input (either bad cables or a faulty head unit). If the amp is fine with the RCA cables plugged in, repeat the process with the speaker cables (one at a time). When you plug in the faulty speaker wire it will put the amp into diagnostic mode.
Mar 06, 2011 | Hifonics XX-Hercules Car Audio Amplifier
Wiring diagrams for clarion dxz535 car stereo
Here's how it goes:
Speaker wires:
grey=right front pos.
grey/black=right front neg.
white=left front pos.
white/black=left front neg.
violet=right rear pos.
violet/black=right rear neg.
green=left rear pos.
green/black=left rear neg.
red=12 volt switched power source
yellow=12 volt constant power source (direct to battery)
black=chassis ground
orange/white=illumination (switched source,not to head light switch)
blue/white=amp turn on lead (to remote turn on lead of amp)
blue=auto antenna (switched power source)
brown=phone mute lead (to cell phone mute lead)
RCA connector leads:
grey lead:
red=right front
white=left front
black lead:
red=right rear/right rear subwoofer
white=left rear/left rear subwoofer
(connect to external amp)
red lead:
red=right aux input
white=left aux input
(connect to external unit)
green lead:
red=right dual zone output
white=left dual zone output
(connect to wireless head phones)
That should be all there is. on the yellow that goes direct to the battery you need to use an inline fuse holder with 30 amp fuse.
Sep 26, 2010 | Car Audio & Video
I have checked all connections to my amp battery,head unit,remote or trigger wire,fuses,power cable,rca leads,ground wire,amp has a green led light on it indicating if it works ok,red if it`s not,light...
Your amp could be in protection mode! Sometimes turning up to high or wires touching will put in protection mode! It will have to be unplugged for a day or two to drain all power out of the memory. Leave accessorie/ignition wire hooked up, just not power and ground wiring. It should reset itself.
Jan 22, 2010 | Lightning Audio B4.250.2 Car Amp
I cant get power to the amp, everything is hooked up right, i replaced the power cord fuse... what else could be wrong,...??? the green led light is off and i tested to volts on the remote terminal and it...
Check in this order:
  1. Battery connection
  2. Fuse at battery
  3. Ground wire at vehicle
  4. Bat. and ground at amp
  5. Remote turn on lead should read 12v
If you have no power at the turn on lead pull deck and see if it cam disconnected, should be blue w/ white strip.
Jun 01, 2009 | Kicker SX650.1 650W Mono-Block Amplifier...
Xplod to a jvc
I would recommend using an 8 AWG minimum or preferably 4 AWG power and ground cable. Use as short a ground lead as possible and connect it directly to some chassis metal (avoid accidentally screwing into the gas tank if in trunk). Use a fuse holder with a 40 - 60 amp fuse under the hood within 18 inches of the battery. Your RCA cable coming from the back of the JVC radio should be run to your amp along with the remote turn on lead. This wire should connect to the JVC's amplifier turn on lead which should be a blue wire with a white stripe.
Aug 08, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Where do i connect my amp to my paosonic cq-dfx301u
On the the back of the unit there will be be a set of rca leads marked pre out run set of rca leads from these to the input connectors on your amp,you will also need to run a single wire from the wiring harness of head unit look for a wire marked remote (usually blue)run this to the terminal on amp marked remote ,you will also need a fused power cable run to battery +and a earth cable - screw this to metal part of chassis ,then run your speaker wires make sure + - symbols on speakers get connected to + - terminals for speakers on amp.
Apr 20, 2008 | Car Audio & Video
Amp Power LED Display blinks red and no sound
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. Does the voltage on either the B+ or remote pulse below ~11 volts when the LED flashes?
Jan 26, 2008 | Kicker ZX650.4 Multi-Channel Amp - 480W ZX...
No power
Other than the +12V, the ground (-) and the 2 RCA inputs, normally external amps have also a remote trigger which switches it to active on. The remote trigger is activated by a wire from the head unit. Colors would either be yellow or blue but depends on manufacturer of head unit. Alternately, you can connect a simple toggle on/off switch to activate the external amp.
Additionally, pls verify that the 2 RCAs from your head unit are audio out and not audio in for aux source.
Good luck and kind regards.
Nov 01, 2007 | Infinity BASSLINK Car Subwoofer
Car Audio & Video Logo
129 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
