Question about Garden
My Simplicity Lancer has just cut out. I can hear a relay under the seat clicking on and off and the engine will start when it clicks but then cut out again.
  • 24 Answers
I think the solinoid might be bad. If you can take a screwdriver and jump across the 2 main studs that the heavy wire is connected to and the mower starts........then that is what is wrong.
Posted on Aug 23, 2009
2008 Mitsubishi lancer radio from loud squealing noise
What is causing that irritating noise? ' DSMtuners
www.dsmtuners.com > ... > Articles: Miscellaneous
Jun 1, 2009 - 2 posts - ‎1 author Check the ECU power relay in the console, under the radio. ... You hear a loud clicking type noise from under the hood when you try to start the car. .... You hear a squealing, grinding, or rubbing noise in the lower timing belt .... The Mitsubishi Eclipse, Eagle Talon, Plymouth Laser, Mitsubishi Galant VR-4, ... LOUD squeak when turning steering wheel (Video Inside)
Mar 5, 2011
Why does my alternator belt squeal so much on initial ...
May 14, 2010
More results from www.dsmtuners.com
Lancer Troubleshooting [Archive] - evolutionm.net
www.evolutionm.net/forums/mitsubishi-evolution-forums/f-203.html
NEED RADIO HELP! ... Help not start Lancer GT 2012 EngineOverheating STOP SAFELY warning on ... AC ISSUES 2011 Mitsubishi Lancer ES · 2008 Lancer GTS no start please ... 2011 lancer no sound · Driver/Passenger side floor squeaky? ... plastic piece of rear shelf rattles a lot · Very loud noise on Lancer ES 2008 ...
Dec 03, 2015 | 2008 Mitsubishi Lancer GTS CVT Sedan
Aurora 4.0 im stumped checked starer relay and car still wont start clicking ssound comin from backseat jumped it whats wrong
What year vehicle ? The clicking sound you hear from bake seat is probably a relay ! There is a fuse / relay box under the back seat ! How did you check the starter relay ? Just pull it out an look at it ? Was it #36 START 1 Relay
-- Starter Solenoid and PCM in the under hood fuse / relay Box ?
This relay is computer energized - PCM supply's a ground to circuit 447 which energizes the relay sending voltage to the starter S terminal engaging the starter . Do you have a test light or a volt ohm meter ? If you pull out the starter relay an look on the bottom you will see some numbers , 85,86 an 30,87 . match them up to the holes they came out of . Check out this video on YouTube ,you can check for voltage an computer control . Is the SECRUITY light lit on the dash ?
This VEHICLE RELAYS Operation Diagnosis VEHICLE RELAYS Testing from the relay base
Aug 11, 2015 | Oldsmobile Aurora Cars & Trucks
Our 2002 Harley Electra glide looses power while driving down the road, it can sit for a few minutes and the u hear something click under the seat. After that the bike will crank right back up with no...
I had a friend with a similar problem. Is the check engine light on? The click might be a faulty relay, but often these aren't loud enough to hear, so it might be something else. Next time it does this, remove the seat and see if you can't identify what piece is clicking. Or if you have a CEL you can try pulling the code to get something definitive.
Mar 11, 2015 | Power Motorcycles
Rayamaha v star clicks under seat; will not start
check starter relay under seat or power to starter when pushing starter button
if their is check ground from battery to engine with jumper lead.
Jul 09, 2012 | 2001 Yamaha V Star 1100 Classic
I have 2006 Nissan Altima. The engine will not start or turnover, there is also a clicking sound that is coming from the black wiring box, which is located under the hood by front passenger side...
What size engine ? The clicking you hear is probably the starter relay , provided you hear the click while turning the key to the start position . That black box is the fuse / relay junction box. Testing the starter electrical circuits with a volt meter is the way to find the problem . Voltage drop testing . Free wiring diagrams here http://www.bbbind.com/free_tsb.html Enter vehicle info. Year , make , model and engine size . Under system click on engine then under subsystem click on starting . Click the search button then the blue link.Does your vehicle have a manual or automatic transmission ? First blue link for a manual transmission ,the second link for a automatic transmission .
How to voltage drop test starter motor circuit
Jul 26, 2017 | 2006 Nissan Altima
Lancer cut out while driving. will turn over but will not start. it has fuel but no spark.
check mass air flow sensor or crank sensor. If those are not working then the car won't run. is there a check engine light on or a battery light on? obtain an obd2 scanner from an auto parts store and download the code. that will usually tell you everything you need to know. also, check to make sure youre actually getting fuel to the engine. you might have a weak fuel pump. prime the fuel pump a few times before trying to start the car by turning/cycling the key from off to on, not start*, in 2 second intervals a few times then try to start the car. you might be able to hear the pump running under the back seat.
hope this helps!
May 03, 2011 | 2004 Mitsubishi Lancer
My 04 navigator left power seat wont move any direction and pedal adjust wont move...there is a clicking sound coming from a black box under seat but no function
it does not appear that the driver seat or adjustable pedal share anything in common
furthermore, the sound you hear clicking may be the actual seat motor trying to work, but lets do a quick test
try to move the seat up/down, forward/back and any combination. If while holding the button in said position and you consistently hear the clicking sound that follow the sound and touch the motor under your seat. If you feel the "clicking" then your seat motor is bound or siezed and will need repair.
if instead you just hear one click then you might be experiencing a relay problem
As for the pedal adjustment... have you checked fuse #109 (30A) @ the CJB (Central Junction Box) behind the right kick panel?
Apr 10, 2010 | 2005 Lincoln Navigator
My bike wont start and soon as i turn the engine run switch i hear something under my seat start clicking what is that??
Its probably your starter relay or possible your fuel pump starving for fuel... the starter relay is under your seat behind the battery and the fuel pump is under your tank...
Feb 01, 2010 | 1990 Yamaha FZR 1000
Car cuts off while driving.
sounds like starter relay problem. i believe the relay is probably on the left side under hood were you hear that click.
Apr 01, 2009 | 2000 Hyundai Sonata
Driver's side lumbar support in 05 pacifica seat won't inflate
there is a relay that controls the lumbar its under the seat unbolt seat replace the clicking relay
Dec 24, 2008 | 2005 Chrysler Pacifica
Garden Logo
100 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
