Laptop sl1oo is not getting switched on only orange light is on at the poweron button screen
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
Toshiba satellite laptop lockout
is it a windows password or poweron password? you must be wondering what are they?
windows password is when you have to enter the password to get into windows and before that you get to see the windows loading screen.
poweron password is hard to crack, it will ask a password on a black screen saying Enter a Password, and the background will be completely black in color.
if its a windows password, press the "Alt+Ctrl+Del" twice, you'll get a screen which will ask you a username and password. in the username and password type in, "Administrator" and password will be blank. hit enter. if it works, then for the rest of the steps, mail me at L2support.hp@gmail.com
Apr 29, 2010 | Toshiba Satellite Pro L300-EZ1501 Notebook
When put power cable in orange light comes on power button and wont boot up
Sir,
Orange light usually comes only if your system stays in low power mode or sleeps, So u get orange light immediately when u switch on the system, try pressing the ESC Key on the top left corner of the Keyboard, and if not try pressing the power button again...
If not working,tell me Whether do u get any sounds in system?
Your system Operationg System?
And What u get on the screen, when u switch on?
Thanks, Regards
Vinod
Jun 29, 2009 | Dell GX270 P4-2.8 512/40/24X/XPP/NONE...
One page jammed after switching off when 1 page printed. Orange light on
Hi ,
First off all u switched off the printer and on switch off mode press the green button and on pressing the button switch on the printer hold that button for 5 seconds and then release the button whenever u realese the button the printer start migrating . After migrating if the printer have same problem then u reinstall the printer driver and again reinstall the driver, after reinstalling the driver the printer will working fine .
May 26, 2009 | HP LaserJet 1010 Printer
Wirless connectivity problem
What qualifies you people to write responses? The switch for the 6930 is located just above the NumLock key. It actually looks like an LED indicator of a satellite dish, but it's not. It's the button for the WiFi enable/disable. Push it hard...
Jan 04, 2009 | Acer Aspire 6930-6771 Laptop
Compaq laptop won't connect to internet
on my hp the light is blue when switch is on. go to network and conn. and make sure ur wireless is turn off there. cause if my switch is in the on position and i turn it off hp wireless assistant the light will glow orange eventhough the switch is on . ? Just had an issue simular to this one, hope it helps.
May 19, 2008 | Computers & Internet
Acer laptop problem
Is the charging light on when connected to ac, is the battery old or new? The power supply connector might be faulty either at the cable side or inside the laptop.
Jan 12, 2008 | Computers & Internet
Screen frozen, touch pad not working
there is a switch nearby that orange light or the light may be a switch. press on it then the color of light will change and ur problem will be solve....thats all
Dec 21, 2007 | HP Pavillion ZV6000 Notebook
Computers & Internet Logo
69 people viewed this question
Alun Cox
David Payne
David Payne
