I have a 10 year old maytag machine that leaks from the bottom. I have checked the hoses and there is not a leak where at the end of the washer or the wall.
    Problem Solver:
  • 15 Answers
If you don't find leaks at the hose ends or along the hoses, then it may be a cracked pump housing.
Posted on Jul 11, 2009
Maytag clothes washer model 2500 aae leaks along bottom edge
Sounds like a hose leak inside the machine. Possibly remover front bottom cover then check all hose connections.
Nov 14, 2013 | Maytag Washing Machines
My Maytag MAV6000 washer leaks intermittently. In the past 3 weeks it has been used many times but has leaked 3 times. I removed the front panel to look at the pump and hoses and put the washer through a...
Realistically, a 10-year old Maytag is nearing the end of its usual life. The pump may be leaking at random times during a wash cycle. If you put 50% of the cost of a new one into repairs, it is time to thing seriously about replacement of the machine.
Apr 26, 2017 | Maytag Atlantis MAV6000 Top Load Washer
I have a 30 year old top loading washer Maytag 7710. Leaking.
Sometimes the drum gets a hole in it from rust. That can be fixed with a waterproof sealant available at most hardware stores. That is also where you might find a "hose clamp"; if not, you can get one at any auto supply store.
Make sure you get the right size. The best clamps are tightened with a screw driver. Neither of those items are expensive.
One of the two things I suggest should take care of the problem.
Jim Hart
Jun 20, 2010 | Maytag Washing Machines
Maytag Neptune. 10 years old.Slow drum rotation
The problem may be with the bearing of the washing machine is spoiled due to leak please try to change two inner bearing along with the washer it will work for another ten years
Dec 24, 2009 | Washing Machines
Leaking Maytag Atlantis @6 yrs. old
Do your work from the back of the machine.
Jul 07, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Maytag washer leaking between cycles or if stopped during fill
lift the top up on the washer and see if the fill hose is crack or broke,hose on right side
Jun 18, 2009 | Whirlpool LSN1000LW Top Load Washer
Washing machine is leaking from bottom of machine
Wow, this washer is very old. im sure the drainage hoses will need to be inspected or replaced asap. i would also check the pump housing for cracks as well. make sure the water inlet valve assembly ins in good condition as well. Replace any hose or valve that is leaking or, damaged.
Jun 05, 2009 | Maytag Washing Machines
LEAKING WATER ,LOOKS LIKE THE BOTTOM OF MACHINE
this is joyce
Have you checked to see if the pump may have a small leak, if not then you may just have a hose that is leaking, other than that theirs not to much more to go wrong. maytag is a good brand I have one but I would not put up with a leak of any kind, it will ruin your floor.
if you cant find the leak I can help find you a techn in your area that may can come to check it out for you if you need me to. just let me know.
joyce
Feb 02, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer leaking water on floor
Need to check drain pump and its hose connections. If its not from the drum seal then that's usually where the leaks occur.
Mar 30, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Sep 07, 2007 | Maytag MAT13MN Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
paul
paul
