Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Vacuum condenser is flashing - Sub-Zero 650 / O Bottom Freezer Refrigerator
  • 11,896 Answers
This means your condensor on the back of the unit that pumps the freon needs to be vacuumed. It may be dusty or not getting air flow to cool it off. Also vacuum all your coils on back of unit
Posted on Jul 11, 2009
2 Suggested Answers
SOURCE: Subzero--Vacuum Condenser Signal Won't Turn Off
The vacuum condenser indicator keeps flashing on and off. I did vacuum the unit, the the indicator lights keeps flashing on and off. How can I reset it and keep it off?
Thanks,
Rob
Posted on Aug 23, 2009
"Vacuum condenser" light flashing. What do I do?
It sound like you will have to pull the refrigerator out and remove the back panel and vacuum the lint build up on the condenser coils. they may be accessible form the front by removing the front grill.
Mar 13, 2015 | Refrigerators
"service" flashing also what seems to be an error
Service flashing- 1. Ice maker not working 2, Rise in temperature 3. Condenser needs cleaning
To Clean Condenser 1. Remove Grille 2. Brush with a soft brush 3. Vacuum being careful not to bend fins.
Jul 07, 2011 | Sub-Zero 650/SRH Stainless Steel
Freezer not getting below ) degrees vacuum condenser message keeps flashing
The condenser is the 'radiator' located under the unit near the compressor. If it's clogged it will cause this. Make sure, also, that the fan at the condenser is operating.
If you've not yet cleaned the condenser, do so with a vacuum both sucking, and then blowing, to clean it well. BE READY FOR A DUSTY MESS!!
Jun 17, 2011 | Sub-Zero Freezers
The ice cube indicator is blinking
From the manual:
The Control Center monitors refrigerator and
freezer temperatures as well as the ice maker
system. If there is a temperature or ice maker
problem, you'll be alerted by a flashing
SERVICE indicator light. This same SERVICE
light will also flash if the condenser needs
cleaning. Before calling for service, please
check and see if your condenser area needs
cleaning. Refer to Condenser Cleaning,
page 22.
CONDENSER CLEANING
In all Built-In models, the condenser is located
behind the grille. First, remove the grille. Then
using a soft bristle brush, vacuum to remove
dust and lint from the condenser. NOTE: To
avoid bending the condenser fins, be sure to
vacuum in the direction of the fins (up and
down). Clean the condenser area every three
to six months.
CAUTION
Before cleaning the unit, shut the electricity
off at the control panel. When you
clean the condenser, wear gloves to avoid
injury from the sharp condenser fins.
Failure to clean the condenser could
result in temperature loss or mechanical
failure or damage.
Mar 14, 2011 | Sub-Zero 650 / O Bottom Freezer...
Vacuum condenser flashes on and off, freezer side has warmed up But the freezer fan is still running to circulate the air.
It is telling you that you need to vacuum the condenser coil. if this fails to cure the warming problem then you my need a new condenser. compressors have also been know to cause this.
Dec 20, 2010 | Sub-Zero 632 / S
We have a flashing vacuum condenser message on our screen -- what does this mean?
It probably means that your condenser coils are dirty and need to be cleaned up. The condenser coils are the copper tubes in the back of the machine next to the condenser fan. If just vacuuming them up doesn't sufficiently clean them then you may want to get some coil cleaner from your local hardware store or whoever sold you the refrigerator.
If the condenser coils are already clean then you may not have enough airflow. Be sure you have 4 to 8 inches of free space behind the unit to provide adequate airflow.
Mar 13, 2010 | Sub-Zero 642
My 650 flashes vaccum condenser i turned it off and did then turned it back on. a day later it flashes the same massage again does it have a reset or is there something else i need to do
Good day,
Cleaning the condenser is what the correct term should be. To vacuum many times does a poor job. I use either a compressed air tank with a hose, or else a push-pull vacuum cleaner with the hose and a crevice tool attachment on the end to blow the condenser clean.
Can create a mess at the time, but the condenser will be clean, and the purpose is to protect the compressor.
Nov 05, 2009 | Sub-Zero 650 / O Bottom Freezer...
Thanks,
Rob
Aug 22, 2009 | Sub-Zero 650 / O Bottom Freezer...
601R sub zero vacuum condenser notice
Your problem might be serious enough to warrant a repairman's visit. But this was my experience: An official Sub Zero repair company in NYC told me this: If the "vacumm condenser" light keeps flashing after you've opened and cleaned the condenser grill, then either pull out the plug for the Sub Zero refrigerator or turn off the circuit breaker (or fuse) in your house that leads to it, wait for some minutes and then turn back on. It is NOT enough to turn off the unit using its own internal on-off switch - it has to be totally disconnected from the AC. I did so, waited 15 minutes, turned back on, and it worked!! I had vacuumed the condenser grill twice but the "vacuum condenser" light kept flashing AND the refrig would go bonkers if set below 38. Now the flashing warning is off and it's down to 35. Great !!!
Jun 27, 2009 | Sub-Zero 601R
Vacuum condenser message flashing
Your evaporator needs replacing. covered under 12 yr. warranty parts only.
Jul 25, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
600 people viewed this question
Top Sub-Zero Refrigerators Experts
Sal De
John Tripp
John Tripp
Steve Allison
Steve Allison
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
