Question about Tecnik TKR6620 Bottom Freezer Refrigerator
Shelf for fridge door bottom one - Tecnik TKR6620 Bottom Freezer Refrigerator
  • 63 Answers
Try calling this company '' Ajax Domestic Spares, Ipswich, 01473 211 977. they should be able to oblige, failing that, try a local white goods supplier.
Posted on Jul 11, 2009
My Danby refrigerator shows a lot of temp variance. A thermometer on the top shelf shows 40 degrees, lower shows 32, is this normal?
if the door has been opened or used for a number of times ,that variation will be around normal
the system works like this
the fridge cools air from the bottom up as cold air falls to the bottom of the fridge
if the door is not being opened ( over night) the whole compartment becomes to the same temperature as set by the thermostat and that is when the fridge cuts of
Now if the door seals are leaking cold air out at the bottom then the whole compartment will never get to the same temperature ( your variation)
similarly if the door is constantly being opened , the cold air at the top of the compartment replaces the cold air at the bottom that has flowed out onto the floor on opening the door (again your variation)
so you have to possible items to check
1 are the door seals in top condition and 2 is the door being opened too much in short periods of time
Jul 18, 2015 | Danby Refrigerators
My Samsung Refrigerator side by side door ,,Model,,SRS583DHD,, left hand side door ice maker increases temp and not producing ice,,;-(,,Bot
Your description sounds like a loss of air flow problem. Check for overloading your freezer and fresh food side. In order for the freezer and fresh food side to work properly, the air vents need adequate room for air to circulate. I had a customer who completey filled the middle shelf with cardboard boxes and completely blocked air flow on the middle shelf The lower level near the evaporator was extremely cold and the upper area was room temperature in the freezer. Each shelf needs about an inch of room at the back and room between packaging to allow air to circulate.
Hope this helps
Dec 13, 2014 | Refrigerators
Amana XRBR206BB
The bottom hinge may have to be adjusted or shimmed.
Feb 09, 2014 | Heating & Cooling
I own a KIC Fridge the problem is that the door does not closes the rubber does not grip tightly when closing. I have to sometimes lean on the fridge for 5-10 seconds for it to close and it sometimes does...
Hi did anyone get back to you on this? I have a KIC Fridge and it does the same... take out the top door shelf/rack but then you MUST unscrew the light (cause otherwise your light never goes off and your food doesn't stay cold) cause the top shelf/rack in the door switches off the light... anyway... once the top shelf is out, the door will close better.... not sure how else to fix it though...
Feb 09, 2011 | Smeg FAB32 Bottom Freezer Refrigerator
MFD2560HEW Bottom freezer french doors. Top shelf in fridge is 52.2 degrees 2nd shelf is 45.7 degrees 3rd shelf is 38.5 degrees and the bottom shelf that slides out that sits above the freezer is freezing...
At this point I am not sure if your Auto Damper that regulates the cold air is stuck closed or if the thermistor that controls the damper is responsible. You could also be having a defrost problem restricting the air flow to the fresh food section. Look into rear of freezer to see if there is a layer of frost building on rear panel. If yes then we will need to focus in a different direction. First by manually unplugging fridge and then using a hair dryer to help speed things up. The manual also has diagnostics test that you can do to locate a problem area like thermistors or many other errors will show once placed into diagnostics. Sea Breeze
Jun 03, 2010 | Maytag MFD2560HES Bottom Freezer French...
I need shelves for the fridge and the plastic shelf at the bottom of the door is broken and needs replacing.
hi there......you havent stated the manufacturer of your fridge...however obtaining shelves for your fridge should be no problem..provided you have the model and serial number and if possible the product code.(a) contact your local your local domestic apliance repair/spares shop....(b) go online to the manufacturers web site...(c) go on line to google enter your fridge details this will provide you with information where to obtain your parts...
the door shelf may be a different issue...if the shelf is part of the door lining then you will need a relpacemant door
regards Sir Galahad
Aug 13, 2009 | Kenmore 91493 Stainless Steel Compact...
Water gushed out freezer door, possible solenoid problem?
The drain is clogged. The drain is usually located inside the freezer on the bottom shelf to the rear. Use a meat baster and a solution of 1 tsp. baking soda and 2 cups of hot water-not boiling to unclog the drain. You probably also have about 1/2 inch of ice build-up on the bottom shelf. This will have to be removed first.
Nov 13, 2008 | Kenmore 50522 / 50524 Side by Side...
Tecnik TKR6620 Bottom Freezer Refrigerator Logo
80 people viewed this question
Top Tecnik Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Are you a Tecnik Refrigerator Expert? Answer questions, earn points and help others
