Question about Kenmore 9446 Range
I have a kenmore electric range. The oven door is
I have a kenmore electric range. The oven door is stuck in the lock position. How can I get it unlocked?
  • 89 Answers
You will have to replace the lock motor assembly it is under the panel on the back
Posted on Jul 11, 2009
Kenmore 95024 Electric Range The self clean cycle Door stuck shu
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 27, 2010 | Kenmore 95022 / 95024 / 95029 Electric...
Can not open the door of the self- cleaning electric Range after cleaning operation
Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
or
Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
If these procedures fail to correct the condition, the lock must usually be accessed and moved manually to open the door.
Some model ovens require the oven door to be manually unlatched before the controls are returned to the OFF position or else the door may not be able to be unlocked. Check the owner's manual for proper operating procedures
Mar 11, 2010 | Kenmore 99123 Electric Kitchen Range
Opened oven door before it could lock while I was
try unplugging the unit,
depending on your exact model it may just be lost in the programming becuse it sensed the door open while locking so it shuts down the lock for safety
just unplugging if for a few minutes might clear the error enough for the lock to rotate back to closed
position
Nov 03, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven will not come on to cook, it will come on in cleaning mode
I've seen this problem on my own oven. If yours, like mine, has a door that has a locking mechanism, the catch is most likely stuck in the locked position. The door still closes and the lever still moves (though it may be very stiff).
Take off the screws around the locking plate, manually push the catch to the open position, spray the catch VERY, VERY lightly with WD-40 and dry it thoroughly. Close the oven door and try the lever again.
At this point, it should move freely and your oven should be able to switch between LOCKED/Self-Clean Mode and UNLOCKED/Cook Mode. If it does still get stuck, you'll just has to a) try lubricating the catch a bit more or b) keep a screwdriver handy! ;)
Aug 05, 2009 | Hotpoint RB757 Electric Kitchen Range
Frigidaire electric range digital display light stuck on
Try turning the power off to the appliance for several minutes or un plugging it.
Mar 30, 2009 | Frigidaire Kitchen Ranges
Kenmore 790 Oven Locking mechanism problem
hold down the stop/clear button for 3+ seconds
Jan 13, 2009 | Kitchen Ranges
I had the same problem. Open the oven door. Press and hold the light switch. You will hear the door lock move back into the correct position. Hope this fixes your problem. This has happened to me twice and holding the light switch always works.
Jul 14, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Oven door locked after cleaning
I have a kenmore self cleaning oven. I Locked it
and have held the cleaning button for 3 secs and
returned the lock lever to unlocked position and the
locking lever in the inner of the oven door is still ingaged i have tryed to manually push the lock with a object you can feel it move over but the door still will not open. door will come out an inch.
Apr 07, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Kenmore Elite Electric Range, Display stuck on LOC
I pressed the lock icon on the panel and held it for a few seconds and the display cleared.
Feb 03, 2008 | Kitchen Ranges
Kenmore 9446  Range Logo
387 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Marvin
Marvin
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
