Question about Karcher 1750 psi Electric Pressure Washer
Karucherr pressure washer, no water coming out
I have borrowed the pressure washer with no instruction manual. I think I have everythin connected properly, however, when i turn the machine on no water comes out
  • 1019 Answers
SOURCE: pressure washer karcher
Sounds as simple a fix as " The Fuse Has Blown "
Check the fuse in the plug, and it,s Rating.
I,d assume this should be rated at 13 AMPs.
If the fuse is 3-5 amps it,s under-rated.
You should get it tested out if your not electrical minded, you may have a short circuit. live/earth et.c.
hope this helps.
Mike @ Compurepair.
Posted on Mar 26, 2008
SOURCE: bosch aquatak 120i pressure washer/tetergent
Hi Guys there isnt a problem with your machine you just need to pull the end of the spray lance out -the lumpy bit where the water exits the machine (it kinda clicks out)
Posted on Jun 27, 2008
  • 156 Answers
SOURCE: Pressure Washer quit running
I have owned four of those units. Every one of them did what you are experiencing or just wouldn't give me any pressure after only a few uses. The company was certainly no help. I gave up after four and bought a heavier gas model from Lowes. Hope this info helps.
Posted on Jul 06, 2009
  • 4090 Answers
SOURCE: I started working with the Karcher KB4040 pressure
if the water is in anyway impeded, like kink in hose the unit turns off and goes into protection mode. That it it shuts down for a pewriod of time depending on how hot it may have got.
When its rested try it again ensuring you definitely have water flow.If the solenoid has failed it costs about !60-200 to fix as they replace all seals regardless
Posted on Jul 22, 2009
consaka
  • 661 Answers
SOURCE: started washer, heard 'pop', water started coming out of bottom
Thats not good. Sounds like the seal blew out. Inside the unit there are seals that seal up the parts where they are bolted together. Also there is the pressure connection that could have blown out as well. To determine which is the problem you will need to dissassemble it.
Posted on Jun 22, 2010
Aquarius wmf560 drum not moving after h20 code
if you do not have an instruction manual for this washer then download from this site.
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/WMF560UK_19507120302_UK.pdf
If the drum is not moving then it is very likely the pressure switch is also faulty. This tells the control that water level has been achieved. It is thinking water is not coming in.
Check this out.
PRESSURE SWITCH
Sep 13, 2014 | Washing Machines
There is water squirting out of a hole next the pressure hose connection. Is there a missing screw? Or an adjustment to the washer that can be made. There is no pressure because of this leak.
If this hole has threads then it might be the soap inlet. If water is shooting out under pressure you may have an obstruction in the hose/handle. Try removing the hose and running the washer and see if the water flows out the connection. If the hose ends up being the problem a visual inspection and cleaning of all inlets and the handle should clear it.
If the water coming out of the hole is low/tap line pressure then I think your bypass *(or unloader) valve is stuck in the bypass position.
A stuck unloader just needs to be unstuck and lightly cleaned. A light coating of silicon grease wouldnt hurt either!
Get the manual for this pump and see how to open/remove the unloader valve.
Jun 04, 2011 | Northstar Pressure Washer 3000 PSI
Troy bilt pressure washer 2550 psi 6.25 hp. we borrowed from my brother and it doesn't have full pressure coming from the nozzle because there is water steadily coming out of the side from a sun shaped...
There is a valve installed to release water out of the system if water temp. rises to a level that may damage the pump. Water temp will rise when motor is running and you are not spraying water. This part is called a thermal valve. It can begin to leak water if worn out or debris under seat, however may not effect a lower pressure at the wand unless it leaks more water when you are spraying than when in bypass. You can see various thermal valves by searching on ebay with the key words :
"pressure washer thermal valve". Pressure is created at the tip of the wand. If the nozzle at the wand is worn or too large for the system, pressure will be reduced. You can check if the tip is correct by using a different tip that came with your system or using new of correct gpm as noted on the specs. of your system. Good luck
May 30, 2011 | Briggs & Stratton Prosumer 20324 Gas...
Error code f02 comes up
The f02 error code is caused when the unit control thinks there is still water in the tub after it has tried to drain. If the washer is full of soap suds it will also display an f02 error code. You will need to use only name brand HE detergent. If your washer is not draining the water out you will need to clean the pump filter. I have provided the instructions below. Run the washer in a drain and spin to ensure the pump is running. If the washer has no water and no suds the problem will be either the pressure switch or a plugged pressure hose. To check the pressure hose you will need to remove the top and remove the hose from the pressure switch. Ensure the hose is clear by blowing into it. If the hose is clear I recommend replacing the pressure switch.
Mar 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Hi, so long since i used my pressure washer i cant
  1. connect your garden hose to the bigger screw type part
  2. turn on your water and let it flow for 1 min
  3. then kink the hose and attach the hi pressure hose
  4. then put it on
Aug 01, 2009 | Garden
I started working with the Karcher KB4040 pressure washer and all was well for 1-2mins, then it sputered a bit and all power died. All hoses were still attached properly, it hadn't blown a fuse in my house...
Jul 22, 2009 | Karcher 1750 psi Electric Pressure Washer
LOST KARCHER INSTRUCTION BOOK, ARE INSTRUCTIONS ON LINE
Here is the offical link to manuals and warranty cards for the residential models of Karcher Pressure Washers
http://www.karcherresidential.com/us/Service/usermanuals.htm
Jan 22, 2009 | Karcher K2.26 Electric Power Washer
Karcher 1750 psi Electric Pressure Washer Logo
115 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Tim Venetis
Are you a Karcher Garden Expert? Answer questions, earn points and help others
