Question about AT&T 1738 Digital Answering Machine
When I go to messages, it says the time and then says "POWER FAILURE."
Seems to work OK but displays annnnnnn flashing number PLUS a flaching "C" shaped thing. Is it broke?
  • Aceinthehole Jul 25, 2008
    Same problem with the letter "C" appearing after a power failure. Can't find the owner's manual. Beendoing this for about 6 weeks now. I feel like going to a store and stealing an owner's manual out of another answering machine box. Won't AT&T send me another manual? Can't I just read one online and fix the problem?
    Problem Solver:
  • 13 Answers
Set the Clock
You must set the clock once so that the
system announces the correct day and time
with your messages. After this, if you
subscribe to Caller ID, the system will
automatically reset the clock each time new
call information is received.
Press Pto exit at any time while
setting the clock.
1 Press and hold Cuntil the Message
Window displays C, and the default day
is announced.
2 To change the day setting, press and
release ror auntil
the correct day is announced.
3 Press and release C. The current
hour setting is announced.
4 To change the hour setting, press and
release ror auntil
the correct hour is announced.
5 Press and release C. The current
minutes setting is announced.
6 To change the minutes setting, press and
release ror auntil
the correct minutes setting is announced.
7 Press and release C. The current
year is announced.
8 To change the year setting, press and
release ror auntil
the correct year is announced.
9 Press and release C. The new day,
time, and year are announced.
To check the clock, press and release
C.
Posted on Nov 01, 2008
Will not print, has error message 0xc18a0406. ink system failure
The ink system failure message has a chance to be fixed or it may be a permanent issue. It can be pointing toward a firmware failure in the printer and if that is the case the following steps should fix it.
Press and hold the “*” key. Press the “#” key and release both keys.
Display should say “Enter Special Key Combo”
Press and release in sequence the "1”, “2” and “3” buttons.
Display should say “Support” and display the FW rev (something like R0631R)
Mine reads R0631M
. Press and release the right arrow button until the display says “System Configuration Menu”.
Press and release the “OK” button.
Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
Display should say “Hardware failure status: Clear. Press OK to clear”.
Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer.
Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. Good Luck!
Jan 20, 2010 | HP Photosmart C6180 All-In-One InkJet...
Eror oxc18a0106 ink system has failed,unable to copy receive faxes or print
Mine reads R0631M
Jan 14, 2010 | HP Photosmart C6180 All-In-One InkJet...
I have a printer ?HP c7280 All-in-one?a message, ?Ink system failure, error: 0xc18a0201.?
The ink system failure message has a chance to be fixed or it may be a permanent issue. It can be pointing toward a firmware failure in the printer and if that is the case the following steps should fix it. Press and hold the ?*? key. Press the ?#? key and release both keys. Display should say ?Enter Special Key Combo? Press and release in sequence the "1?, ?2? and ?3? buttons. Display should say ?Support? and display the FW rev (something like R0631R) Mine reads R0631M . Press and release the right arrow button until the display says ?System Configuration Menu?. Press and release the ?OK? button. Display should say ?Hardware failure status?. If not there already, Arrow Key over to ?Hardware failure status?, Press and release the ?OK? button. Display should say ?Hardware failure status: Clear. Press OK to clear?. Press and release the ?OK? Button. Message changes to ?Hardware failure status Cleared. Press Cancel to continue?. Press and release the ?CANCEL? button as many times as necessary, so that, either the ?Welcome to Photosmart Express? screen appears, or, the ?Ink System Failure? screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer. Turn the unit on. The printer may display message ?USE POWER BUTTON TO SHUTDOWN THE PRINTER? followed by ?PRESS OK TO CONTINUE?. Press OK. The Printer will start the ?ONE TIME INK INITIALIZATION PROCESS?. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. Good Luck!
Jan 11, 2010 | HP Photosmart C7280 Printer
To my disappointment I called Hp and spoke with their technicians for the second time regarding Ink System failure 0xc18a0001? I reset the IDS by pushing the * and # key then hit 123 and I got the message...
Hi ok try I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Oct 10, 2009 | HP Photosmart C6180 All-In-One InkJet...
Error 0xc18a0301 - "Ink system has failed" on a Photosmart 6180
Error number 0xc18a0301 on HP printers Follow the below steps on the front panel of the All-in-One printer:
A. - Press and Hold the “Print Photos” & “Red Eye Removal” buttons. Release both buttons. Display should say “Enter Special Key Combo”
B. - Press and release in sequence “Red Eye Removal”, “Print Photos”, “Red Eye Removal”
Display says "enter special key combo"
Press and release in sequence “Red Eye Removal”, “Print Photos”, “Red Eye Removal” .
If "support COxxFN0723BR" appears with "uiaux" message, perform the below steps:
2. Press and release the right arrow button until the display says “System Configuration Menu”. (on C8100 use Touch Screen)
3. Press and release the “OK” button.
4. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status.
5. Press and release the “OK” button
6. Display should say “Hardware failure status: Clear. Press OK to clear”.
7. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
8. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
10. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
11. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
12. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
13. To verify printer functionality print a SELF TEST PAGE.
Aug 28, 2009 | HP Photosmart D7160 InkJet Printer
Message on printer screen "ink system failure" Message on computer screen "print head failure"
Aug 06, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 Ink System Failure
Jun 07, 2009 | HP Photosmart C5180 All-In-One InkJet...
HP photosmart c6280 ink systems failure
Jun 06, 2009 | HP Photosmart 3210 Printer
My printer displays ink system failure error message 0xc18a0101 model hp c6288
May 14, 2009 | Canon imageRUNNER 7200 Copier
60.40 Error Message on HP Laserjet 5025 MFP printer
OK I had the hp error code some problem and here is the conversation I had with the tech...
James Cowan: HP error code 0xc18a0001
Earnest: I will assist you in this regard. I understand that a error code with 0xc18a0001 with "Ink System failure" is displayed on the front panel of the All-In-One printer. Am I correct?
James Cowan: Correct
Earnest: May I have the model number of All-In-One you are using?
James Cowan: c6250
Earnest: Please let me know the room temperature in which printer is replaced
James Cowan: 67 degrees F
Earnest:: OK. Please perform the below steps on the front panel of the printer to resolve the issue
James Cowan: OK
Earnest:: Press and hold the "left arrow" key. Press the "Setup" key and release both keys, display should say "Enter Special Key Combo". Press and release the "OK" button
Earnest: Please ignore the above steps
James Cowan: OK yes nothing seemed to do anything
Earnest: Please perform the below steps on the front panel of the printer. Press and Hold the "Print Photos" & "Red Eye Removal" buttons. Release both buttons. Display should say"Enter Special Key Combo". Press and release in sequence"Red Eye Removal", "Print Photos", "Red Eye Removal"
Earnest: Display should say "Support" and display the FW rev (something like R0616R)
James Cowan: COxxFN0723BR
Earnest: OK. Press and release the right arrow button until the display says "System Configuration Menu"
James Cowan: OK
Earnest: Press and release the "OK" button
James Cowan: OK and it says hardware failure status
Earnest: Display should say "Hardware failure status: Clear. Press OK to clear". Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue". Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. Please do not try to print at this stage
James Cowan: OK
Earnest: Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. Let me know once you are done with the above steps
James Cowan: OK its unplugged
Earnest: Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer. Turn the unit on. The printer may display message "Use POWER button to shutdown the printer" followed by "Press OK to continue". Press OK
James Cowan: OK
Earnest: Let me know the message displaying on the front panel of the printer
James Cowan: printer preparation occuring - do not interrupt
Earnest: OK
James Cowan: OK its done
Earnest: Let us print a self test page from the printer now
James Cowan: OK deal
Earnest: 1) Load letter, A4, or legal unused plain, white paper into the input tray
2) Make sure that the printer is on and loaded with unused plain, white paper
3) Press Setup. The Setup menu appears
4) Press the down arrow button to select Tools and then press OK
5) Press the down arrow button to select Self-test Report , and press OK. The self-test report prints
James Cowan: OK printing
Earnest: OK, please check whether all the colors pritned perfectly on the test page
James Cowan: Perfect
Earnest: Great... Cheers!!!
James Cowan: Thank you very much
Earnest: Now you can continue using the printer.
Feb 22, 2009 | HP Office Equipment & Supplies
AT&T 1738 Digital Answering Machine Logo
171 people viewed this question
Top AT&T Lands Phones Experts
Paul C.
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
