Re: What is Proscan 15LA12Q power supply output voltage...
UpBright NEW AC Adapter For Proscan 19LA25Q 20LA11Q 15LA12Q LCD HD TV DC...
Price:$18.54 + $5.89 shipping
First check it or have the power supply check out with a meter. If you have 0 volts or it is dead then replace it. The main thing is the polarity of the tip, positive tip or negative tip IT MUST BE THE SAME or you will FRY YOUR TV. Good Luck.
If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://remotesearch.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. The output DC voltages comes outfrom it is not normal; and so the flicker occurs. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time.
If the voltage output from the main power regulator board is abnormal, this kind of fault can occur to LCD TVs. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter". http://electronicshelponline.blogspot.com/
I believe this unit has an external power supply (black box) attached to the cord.And it may. This is the first place to trouble shoot. This external power supply has a weak capacitor inside. When this happens, the voltage is low and the current is low. If you can test the the voltage (which will be DC) on the output of this power supply, do so.Any reading less than 12 volts indicates this is a weak power supply. Open this black box, and you may see a capacitor with a bulged top. Replace this cap with the same voltage and MFs. Good luck and thanks for asking and show a few hands of support.
Tv keeps blowing fuses
it is due to short ckt in your tv in
1 power supply.
2 horl output section
it is mainly due to
1 switching transistr
2 main fil cap
3 rectifier diodes
4 print short
5 h/output tra.
6 eht transformer
