Hi Anonymous,
What exactly did you mean, did you want to reset the printer or the fuser?
I would suggests www.xerox.com or the Xerox concessionaire would be the best place to start.
Regards.
Solutions for : Printer Error Fuser Temp Message
There are two configuration options available for this model; the Phaser 3100MFP/X and the Phaser 3100MFP/S. Fax features are only available on the Phaser 3100MFP/X. To determine the configuration of your machine, print a Configuration Page. See the Related Items below for additional information.
Solutions ranked by relevance:
Make Sure the Machine is Plugged Into a Functional and Stable Power Outlet Test the power outlet that the machine is plugged in to by connecting another device to the outlet. Make sure the outlet is functional and stable. If possible, have the line tested by an electrician. If necessary, plug the machine into another power outlet. NOTE: The machine should be plugged directly into the wall outlet, and should not be connected to an extension cord, power strip, or Uninterruptible Power Supply (UPS).
Reset the Fuser Error
Solution : Reset the Fuser Error
CAUTION:The following solution will put the printer in the Diagnostics mode and is only valid for this problem. Follow the steps carefully; any deviation from the process can cause other settings to be changed and / or render the machine inoperable. If at any time it is necessary to cancel the procedure and start again with step 1, press the [Stop] button four times. NOTE: This procedure will delete all pending jobs that have been sent to the machine. To reset the Fuser error: (Click on one of the following links to jump to the corresponding section.)
SISODIYA COMPUTERS "I AM SOLVE THE PROBLEM FUSER TEMP ERROR "
BUTTON FAST PRESS STEP BY STEP
LET'S START
PREES- MENU BUTTON
* BUTTON(THIS IS STAR BUTTON)
# BUTTON
1 BUTTON
OK BUTTON
STOP BUTTON
MENU BUTTON
# BUTTON
^ BUTTON(THIS UP ARROW BUTTON)
OK BUTTON
YOU LAST BUTTON PRESS OK AND POWER "OFF" AND WAIT UNTIL 15 MINUTE AND PRINTER START PROMBLEM IS SOLVE FUSER TEMP
You will have to replace the fuser. Call 1-800-835-6100 and follow the prompts to purchase parts. It isnt real expensive. Just make sure you still don't have some warranty left on the parts.
A hardware module is used to reset Xerox Phaser 3100 which work as permanent solution. After that you can refill unlimited number of times without any problem. www.nakshatraworld.com, 09713862555
