Radio Communications Logo
Sherman Thames Posted on Jun 03, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My mistake on question ashed. Can A d104 m6b be hooked up to my ranger radio?
I need wiring diagram to hook up.
Mike Charette
Level 3:
Genius:
  • Ranger Master 1,847 Answers
  • Posted on Jun 17, 2015
Mike Charette
Ranger Master
Level 3:
Genius:
Answers
1847
Questions
Helped
490026
Points
2211
#1) shield #2 yellow #3) red #4 last wire
D104-M6B WIRING FOR A UNIDEN 880 RADIO DIGRAM
Here is the wiring diagram for connecting a D104-M6B microphone to a Uniden 880 radio:
  • Shield: Connect to pin 1 of the microphone jack on the radio
  • White: Connect to pin 2 of the microphone jack on the radio
  • Red: Connect to pin 3 of the microphone jack on the radio
  • Black: Connect to pin 4 of the microphone jack on the radio
It's important to note that not all Uniden 880 radios are wired the same way. If you're unsure about the wiring on your specific radio, it's best to consult the manual or contact Uniden customer support for assistance.
I have a 6 wire D104 . How do I wire it to a Ranger 2985 dx ?
Wiring a 6-wire D104 microphone to a Ranger 2985 DX requires connecting the wires in the correct order and configuration.
The Ranger 2985 DX has an 8-pin modular plug, and the D104 microphone has a 6-pin modular plug.
Here's one way to wire the D104 microphone to the Ranger 2985 DX:
  1. Connect the red wire from the D104 to the 8-pin modular plug's pin 4 (PTT - Push-To-Talk).
  2. Connect the black wire from the D104 to the 8-pin modular plug's pin 5 (Ground).
  3. Connect the white wire from the D104 to the 8-pin modular plug's pin 6 (MIC + Audio).
  4. Connect the blue wire from the D104 to the 8-pin modular plug's pin 7 (Receive Audio)
  5. Connect the green wire from the D104 to the 8-pin modular plug pin 8 (Transmit Audio)
  6. Connect the yellow wire from the D104 to the 8-pin modular plug's pin 3 (UP-Down).
It's important to double-check the wiring configuration with the user manual of the Ranger 2985 DX and the D104 microphone. Some manufacturers have different wiring configurations and it's important to match the wiring accordingly to avoid any damage to the device.
It's also worth noting that if you are not comfortable with the wiring process, it's best to consult with a professional technician or a radio expert.
I have an Astatic D-104-m6b (4-pin connector) and need to rewire it for my ICOM IC-7410 (8-pin xcvr). I need help with the wire colors to the correct pins.
You've probably already found the answer to this question but doing a search for D104 wiring to ICOM will show you what you need. If the connector is the 8 pin circular one, then the PTT and MIC connections are the same for all ICOM radios.
Wiring diagram to hook up a d104 m6b to the radio.
http://www.cbtricks.com/radios/rci/rci_2995dx/index.htm
1helpful
Im trying to wire a astatic d104 m6b to a galaxy 949 mobile can you give a color code for what color wire goes were?i have black white red blue and a bare wire thank you.
This works for any mic.
dont worry about color codes. look at the switches.. there will be a common on both poles of the d104.. those need to be tied together to grnd. pin 1 on mic . the others d104 on n/c side is your rx. pin 4... the n/o one will be your tx pin 3 the other n/o will be audio and will have a wire from the mic element also on that pole of the switch. pin 2..
2answers
How do i wire my d104 m6b mic for my president dwight d cb raido
This must be the right pinning
Pin 1 = shield / blue
Pin 2 = white
Pin 3 = red
Pin 4 = black
good luck,
Gerard
3helpful
Top Ranger Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Ranger Radio Communication Expert? Answer questions, earn points and help others
