Question about Akai LCT3201AD 32 in. LCD Television
Lct2662 power supply
Our internal power board's voltage has dropped out and the TV no longer turns on. I have a back ground in electronics so I took the volt meter to the various dc outputs and noticed a surging voltage (up and down) - I also noticed the caps had swolen tops.
I replaced all the caps and some of the IC's haphazardly but to no avail.
I would rather replace the damn thing and move on with my life but no one online seems to carry the internal power board.
Now what?
SOURCE: Testing the BN96-00249A power supply in an Akai PDP4294
You can get the schematics for the bn96 00249a smps here in pdf format.
Posted on Aug 14, 2007
  • 62 Answers
SOURCE: power supply
Call 800-726-4405 - But the part may not be available - request an exchange through the manufacturer. By law the manufacturer must provide parts for 5 years.
Posted on Mar 29, 2008
SOURCE: tv wont turn on service manual
Posted on Feb 01, 2009
  • 44 Answers
SOURCE: No Picture & No sound. Red LED, Green LED, Red LED.
If the power supply outputs are good! Then I would say the back light inverter is bad! If the screen stays black and does not come on.
Posted on Feb 28, 2009
  • 1779 Answers
SOURCE: Insignia NS-27lcd tv won't turn on
Well, take the plug that goes to the inverter board out which has the 12v on it. Check the 12v again at the power supply. If 12v is low you can possibly have 2 caps bad, the values should be about 1000uf/35v or there abouts. They set close to the plug. If that doesn't work then replace the Power Supply because there are no service manuals for lcd p/s. plus nearly impossible to locate individual ic's. Try Shop for the P/S.
Posted on Apr 30, 2009
SOURCE: Power supply board needed from a Akai LCT3285TA 32" LCD TV
Go to this is where I found the power supply board for this TV.
Posted on Oct 19, 2010
0 characters
1 Points
Turn on my tv and it goes right back off
tried to disconnect all the output connectors from the power supply board, then make a voltage checking if output voltage is available. if no output dc voltages or drop you have bad power supply board.
Sep 03, 2012 | Sanyo DP46849 46 in. HDTV
When i turn off tv it wont go back on for hours
The most likely issue is your power supply is failing. Most likely issue that would cause this problem is bad capacitors on the power supply.
What happens in the above situation is:
After the Tv has been off for some time the electronics and capacitors are cool and supply the correct voltage so the TV turns on.
After using the TV the electronics heat up and the material in the capacitors expands causing the power supply to supply incorrect voltage. With the TV the power is flowing and is close enough to the correct values for the TV to stay on, after being shut off the TV will not turn back on because correct voltage is not present until the components cool down and the voltage at power on no longer engages the protection circuit.
Info on checking and testing power supply's
Info on finding and repairing bad. Damaged, leaking or swollen capacitors
Jun 07, 2012 | Hisense LHDN32V66AUS 32 in. LCD TV
Hi, My TV has been turning off by itself and
Good day!!!!
If your TV turn ON/OFF itself without sounds..The possible problems are voltage drop on power supply,overheat/overload,loose/cold solder of power supply or bad T-con board..
If you already inspected all capacitors on the power supply and all looks fine but it doesn't mean that your power supply board works fine because sometimes bad capacitors not look like bulged or looks fine visually but the value change its either lower/higher capacitance value.In that case you need to use capacitance meter to find bad caps..But before we do that,I have a procedure to minimize/eliminate troubleshooting.In this procedure you need a multimeter tester to perform voltage data check..
In this procedure we can determine where the fault came from..
This are the steps:
  1. Open the back cover.
  2. Look at the power supply board (it is usually connected directly to power cord).
3. Find the 3 long connectors near the aluminum heat sink.Those connectors having voltage marks on each pins so you can easily determine where did you get the voltage..
4. Point the black test probe to GND (ground) and the other probe (red) to 5vdc,12vdc/15vdc,24vdc..Let me know if you find any voltage drop or voltage lost..
5. If all voltages are works fine..The possible problem is on T-con/logic board or main board..But in that case the common problems is on T-con board I found it online $34..
Hope it helps..Just keep on touch to fix your TV and works fine again..
Chester Pendilton.
Jan 18, 2012 | LG 32LG30 32 in. LCD HDTV
TV had no picture first and then no sound. I have unpugged TV and still nothing happens. There is a blinking red light on that can be seen from rear of TV ( 1 blink on and off). Thanks for your help.
Good day!
Please follow this procedure to fix your problem:
  1. Open the cover of your TV.Remove all screws at the back.
  2. Next,power ON the TV and check the output voltage of power supply using voltmeter.
  3. It should have not less than 5vdc for system board,12vdc for sounds and 24vdc for inverter board.If the 3 supplies are got a voltage drop your power supply had problem.For example if you check the 5vdc then the reading is 4.50vdc only.
  4. If you have voltage drop,check some leak/bulge on top capacitor on power supply.replace it using soldering iron and soldering pump.
  5. When the power supply looks like OK,no voltage drop and no leak/bulge on top capacitor.The problem is your system board or main board.There's no easy remedy for that.You have to replace the whole system board.
A Power supply is like this..(It is not actually look like yours but it was just for your Idea)
Please let me rate and testify by you when you find my solution helps you...
I hope this solution helps you to fix your problem.Thank you and good luck.
Jul 12, 2011 | Element Electronics FLX3210 32 in. LCD TV
Akai LCT2662 won't turn on, indicator solid orange
Any luck getting this fixed?Please let me know.Thank You very much!
Jul 13, 2010 | Akai LCT2662 Television
The power supply on my Akai LCT2662 (Flat screen TV) has gone bad
I went to Radio Shack and purchased a replacement power cord 18-gauge, 10 amp, 1250 watts for 9.00 bucks and it works fine.
Aug 19, 2009 | Akai LCT2662 Television
Building power outage caused TV not to work
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to
Jan 08, 2009 | Akai LCT2715 27 in. LCD Television
LCT2662 turns on, no picture
Mine is the 5volt regutator. It works fine untill I put a load on it then it craps out. Need to know what the 5v regulator part # is.
Dec 22, 2008 | Akai LCT2662 Television
Power supply most likely... It's a common problem with this particular model and we've seen quite a number of them for exactly what you're describing.
You need to replace 19 caps in the power supply 4) 3300uf/35v, 8) 2200uf/25v, 6) 1000uf/10v, 1) 1000uf/16v and you can go a little higher in the voltage of each cap for greater reliability.
It's best to have an ESR meter also and test the remaining caps as well.
Mar 18, 2008 | Akai LCT2662 Television
This is probably caused by faulty capacitors in the power supply. This is a common problem with this model. If you no longer have a standby light, it could also be caused by an unidentified short on the main board. Hope this helps you out.
Dec 30, 2007 | Akai LCT2662 Television
Akai LCT3201AD 32 in. LCD Television Logo
Top Akai Flat Panel Televisions Experts
Jaime Hernandez
Dave Naylor
Dave Naylor
Are you an Akai Flat Panel Television Expert? Answer questions, earn points and help others
