Philips x55p laptop h12y
I need to removal my keyboard how do you do this?
  • rioking Dec 01, 2007
    I am a real amateur my laptop is a philips x55p pink laptop and I still need to know how to remove the keyboard if you can help?
    Rio
  • candgcoaches Jul 03, 2008
    split coke on keyboard and several keys not operative - the one, double-u. Need to take keyboard out to examine, and replace if necessary. Does anyone have any advice, and if irrepairable any idea of supplies of replacement keyboards?
Just done it myself there are little black lugs which secure the keyboard in place.
Look down on the key board and you will see them at the top edge and sides (above keys esc&F1,F5&F6 and so on), just push them in and the key board will pop out.
Anyone know where I can get a motherboard for this machine?
Posted on Jun 01, 2008
    Prodigy:
    An expert who has answered 500 questions.
  • 620 Answers
Wow a generic question to a world of responses, my friend, depending on the Laptop, I dunno the brand or hardware setting, you have to open the top cover, and gently disconect the port cable to the MOBO, thats it! then reconnect the new one, but do this carefully.
Carl
Posted on Nov 15, 2007
  • Carlos L. Burgos
    Carlos L. Burgos Dec 01, 2007
    Hi again rioking
    You have to look for some screwdrivers, and see them near the top cover, or down the laptop, carefully take it out all the drivers, and then proceed carefully to take out the keyboard.
    Good Luck!
Hello my laptop philips freevents h12y i need audio driver win7
Hi shulalbvvc, "Go to this "Website!"
It shows 'all the Audio Drives for the "Philips Freevents H12Y!"
Scroll down to find:
Fill-in necessary information.
ie: Model #, Brand, and or Operating System...
"Select the [Drivers] you need from the "List."
"Download the Drivers!"
!Important: "Take a 'moment to rate the help', so I can get 'credit' for the work.
Thank you!" - paul7of9
Click here: http://www.search.philips.com/search/search?h=support&o=support&q=Audio+Drivers+Windows+7+philips+freevents+h12y&f=all&i=all&language=&l=us_en&s=all&n=10&d=&p=&p_fld=&p_val=&highlighted_param_entry=¶m_group=¶m_group_value=&first=&last=&next_start_hit=11&bannercount=0
Mar 16, 2011 | Computers & Internet
I need the LCD removal procedure for an HP G60.
1) http://www.insidemylaptop.com/remove-replace-damaged-lcd-screen-hp-g50-g60-g70-notebook/
(Scroll the page down)
2) Also; Which one of the HP G60's?
HP G60-100 series? HP G60 200 series? HP G60 400 series? HP G60 500 series? HP G60 600 series?
It's on the bottom of the laptop in the white Service Tag. P/N = Product Number
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_query=HP+G60&submit.x=4&submit.y=7
Disregard if you are aware of the following;
1) Remove ALL electrical sources from the laptop.
AC adapter (Charger), and Battery
2) Use Anti-Static Precautions. I repeat. Use Anti-Static Precautions.
3) Use a multi-compartment container for the various screws, and DO NOT mix them up!
There are different types of screws. Some look VERY similar to each other, of the different types.
If you use the wrong screw it may bind halfway into the threaded hole.
Chances are of removing it, without it breaking are very slim.
If you do get it removed, the threads in the laptop may be ruined, and so will the screw threads.
Basic procedure:
A) Remove the WLAN Module Cover: (WLAN compartment cover. 1 screw)
Disconnect the two antenna wires from the WLAN Module.
[The Black wire antenna lead is connected to the WLAN Module MAIN terminal.
The White wire (Cable) antenna lead is connected to the WLAN Module AUX terminal.
Just in case you forget when assembling ]
(NOTE*
I don't know the exact product number of your G60 laptop, so I cannot give you exact info on where the WLAN compartment is. Most generally it is in the middle of the laptop, next to the battery compartment. This is GENERALLY)
B) Remove the Keyboard:
Laptop upside down, Closed, Front facing you. Look down in the Battery compartment. (Cover has been removed when you removed the Battery)
There are 3 Philips screws down in the compartment to remove, in order to remove the Keyboard.
One to the Left, one to the Right, and one in the Middle.
Turn the laptop over. Front towards you. Open the cover. Open the cover as far as possible.
There is a Tab for the Keyboard to release, on EACH side of the Keyboard.
Two Tabs.
These PLASTIC tabs, (Use care), hold the Keyboard in place. They need to be released.
They are in-between the second key, and third key down on the Left side, and on the Right side.
They are hard to see at first. They are in-between the Keys, and the inner edge of the laptop.
They need to be pressed down in order to release the Keyboard.
A flat tip screwdriver, or butterknife looks to be the optimal tool of choice, but I caution against using one.
One, you don't want to use a magnetized screwdriver.
Two, they're both made of metal, and can easily damage the laptop if you slip. (Plus it will scratch the plastic)
I would use a thick guitar pick, or some object that is plastic, and similar.
Once these tabs are depressed the Keyboard will slightly pop-up.
Use care, and lift Keyboard up at an angle, (45 degrees), towards the LCD screen.
Back down, front up.
(The front of the Keyboard faces the LCD screen)
There are 4 plastic tabs that protrude from the back of the Keyboard, and you don't want to break them.
They ease up out of the Palmrest Cover.
You have a choice here;
One, lay the Keyboard back towards you, so that you can remove the Keyboard Cover.
Two, remove the Keyboard to get it completely out of the way.
There will be a cable attached to the Keyboard. A wide thin cable made of plastic, (Ribbon Cable), and has wires in it. There is a ZIF connector which attaches it to the motherboard. (Zero Insertion Force)
It is a white long connector, and is composed of two parts.
If you look close you will see a parting line on the connector. The connector separates, BUT, does not come apart. The ribbon cable slides out of the connector.
Use your fingernails to separate the connector.
Reversal of these steps is to gently line up the ribbon cable into the ZIF connector, insert it to the proper depth, and close the ZIF connector.
C) Keyboard Cover:
The keyboard Cover is a rectangular frame which surrounds the Keyboard.
Laptop upside down, Front facing you. On the very outside Corners of the laptop, on the Battery compartment side, are two screws to remove. Philips head screws. One in each corner.
There are two Philips head screws to remove in the Battery compartment. These are identified by a Triangle icon.
Laptop right-side up, Front facing you.
There is a ribbon cable which attaches to the Keyboard Cover. It goes to the Power On button.
This has to be disconnected.
Slide the Keyboard Cover towards the LCD screen, the lift up to remove.
D) Display Assembly Removal:
The two Antenna leads are pulled up through the laptop. I should state EASE them up out of the laptop.
They come up out of the laptop on the Left corner where the Keyboard was.
Disconnect them from the mounting clip.
Make sure they are out of the routing channel.
Disconnect the Display Panel Cable from the motherboard.
This cable's connector should be on the Left side, is white, and long. It just unplugs.
Disconnect the Microphone Cable. Goes across the laptop, and is parallel to the LCD screen. Remove it from the mounting clips first, then disconnect the connector.
Disconnect the CAPS LOCK LED from it's mounting clips on the top cover.
Remove the 4 Philips head screws from the hinges. 2 per hinge.
Remove the Display Assembly.
Oct 31, 2010 | HP G60 Notebook
Need to replace keyboard on Philips freevents x56
There is one screw holding the keyboard in from the bottom - remove this, unclip the 4 clips across the top with a bank-card etc. and you're away. Remove the ribbon, Replace, and reverse for re-assembly.
Jun 30, 2009 | Computers & Internet
Replace keyboard
Laptops have screws that secure the keyboard, they are located on the bottom of the laptop directly under the keyboard. There maybe up to 4 screws holding the keyboard in place, remove these screws. The keyboard should be able to be lifted off to reveal connecting cables. There will be one or two ribbon cables that connect the keyboard to the motherboard, carefully detach these cables before you completely remove the keyboard.
Mar 30, 2009 | Computers & Internet
Need to know If I can use this hard drive in this laptop?
More than likley its not inserted all the way. See if it shows on the boot menu in BIOS. To get to BIOS in TOSHIBA units I believe its F2 at startup.
Nov 30, 2008 | Computers & Internet
Phillips x55p
try calling the customer care section of the manufacturers of the product or maybe it has a recovery partition in it.....maybe u find an expert close to you who could help you out...
Aug 04, 2008 | Computers & Internet
HP dv4307cl keyboard replacement
There is no easy way to say it really; you need to take the laptop apart basically! I have just replaced mine on my compaq which is also designed by HP. Once you remove the top part of the laptop from the bottom, this is achieved by removing all the screws, your keyboard will be pretty easy to get to. There will be a connection to the motherboard, which will unplug easily, that's the only connection; remove the old keyboard, which you must also unscrew, place the new one in, connect it to the laptop (the connection will only connect one way or will be simple to determine) and screw the laptop back together. Job done. If you need help along the way just email me philip.irving01@btinternet.com and I will guide you through.
Jan 30, 2008 | HP Pavilion dv4000 Notebook
Damaged laptop's keyboard
HAY IF U R NOT KEEN IN GETTING UR KEYBOARD REPAIRED BUY A NEW USB EXTERNAL KEYBOARD AND IT WILL WORK...
Dec 01, 2007 | Computers & Internet
1,921 people viewed this question
 Grubhead
Grubhead
