Question about Sony CDX-M800 CD Player
Heating up i installed my deck had someone else check it out and everything is hooked up right but the back of my deck gets very hot,hot enough to burn your finger when touched but not give you a blister or anything.I cant figure it out.
Re: Heating up
Suspect short circuit inside if output performance is below satisfactory level and current drawn is 20% or more than rated.
Posted on Nov 15, 2007
0 characters
3 Points
I just got my Pioneer DEH-7200HD Head Unit. The problem is that it doesn't come on when I hook it up. I've tried everything. even touching the ground and positive wires to a 12volt source and still...
This should be the wiring information: 1998 Saturn SL Stereo Wiring Constant 12V+ Orange Switched 12V+ Yellow Ground Black Illumination Gray Dimmer Brown Antenna Right Front Front Speakers 6 1/2" Doors Left Front (+) Tan Left Front (-) Gray Right Front (+) Light Green Right Front (-) Dark Green Rear Speakers 6 1/2" Rear Deck Left Rear (+) Brown Left Rear (-) Yellow Right Rear (+) Dark Blue Right Rear (-) Light Blue If you have additional wires, I would see how much voltage is running through them.
Apr 12, 2011 | Pioneer DEH-P7200HD Car CD Player
I'm trying to install my new kenwood kdc-mp642u cd deck but i can't get it to power on in my car
find a wire that is constent hot hook it to the yellow and find an ignition on hot and then hook it to the red and hook up the ground u might need a test light u can get them at an auto parts store or at walmart for about 5.00 or less
Oct 06, 2009 | Kenwood KDC-MP642U
No sound everything works fine. VRCD400-SDU
If you are sure that everything is hooked up correct and have no sound, you most likely have a bad speaker that caused the final amplifier to go out. These are two chips mounted inside the radio towards the rear. they are connected to a large heat-sink to distribute heat. If your savy enough you can replace them yourself, otherwise you will need to take it to a shop. This is a comon problem and not a very expensive fix. Before replacing the deck back in the vehicle, be sure your speakers are checked and read at least 4 ohms each.
Sep 25, 2009 | Roadmaster (VR500CSBT)
Sub not working after installing the jensen vm9022 deck
reinstall the factory radio use a digital volt meter to see witch wire supplies voltage when radio is turned on and off, note placement on harness then verify this wire is hooked up on the output side aftermarket harness you may have to jump it to get the maps to turn on. tip you can carefully pull unused wire from harness example (dimmer wire orange white) and move it to the position needed to keep it a clean install .
Nov 19, 2008 | Car Audio Receivers
Installing pioneer deck
Considering you have done many installs, make sure you check the fuse in the back of the unit. Then check all the fuses in your car. My car has 4 fuses for the radio.
Jun 30, 2008 | Pioneer DEH-P2000 CD Player
Heating up on back of cde 9852 alpine cd player
try to chek the regulator or replace it and install a heatsink for him
Jan 31, 2008 | Alpine CDE-9852 CD Player
Clarion Problems
take the deck back to where u boiught it from its faulty
Nov 04, 2007 | Clarion DXZ475MP CD Player
How do you remove DVD stuck in navigation system
If you remove the unit from the dash the top, take off the top cover, no screws you can acess the CD slot. Remove the 4 screws holding the CD player in place and the ribbon cable and you should be able to remove the CD from the slot.
Apr 26, 2007 | Dakota Dodge RB4 Navigation, CD, AM/FM,...
My deck doesnt not transmit signal to my amp. Is this an rca cable problem
Hi Your problem is almost defenetly that one speaker is hooked up with reversed polarities, making one speaker cancel out some vibrations of the other speaker. So get the wiring phase checked again, its ethier this or a fauly cable. Good luck.
Mar 21, 2006 | Kenwood KDC-MP728 CD Player
Sony CDX-M800 CD Player Logo
Top Sony Car Audio Receivers Experts
Larry Stiles
Larry Stiles
xxxxxx xxx
Are you a Sony Car Audio Receiver Expert? Answer questions, earn points and help others
