Take a long needle [should be somewat long] Below the tray there is small hole. Insert the needle/ pointed object through it, n press in by applying some pressure. The tray will now come out
If you get water at the bottom of the door then something is blocking it between there and the dispenser. Usually ice. Leave the door open and cover the freezer opening with a blanket to keep freezer cold.It should thaw in 156 or 20 minutes.
A generic power supply from **** Smiths or Tandy will do the same thing. You will need to check the required voltage and current or watts on the back of the TV to ensure you get one that has enough power. They generally wouldn't cost you anymore than about AU$50.
The flow packs are not opening properly. There may a restriction in the lines feeding the flow packs or the springs/ diaphrams may be bad. I suggest replacing both flow packs and making sure all lines feeding flow packs are free of oxidized iron and debris. RJ
Call Marcone Supplies, Tampa Florida. (they are Danbys Supplier for parts.) DO NOT WASTE YOUR TYIME CALLING DANBY. They are not helpful. Danby 18" Dishwasher. Model # DDW 180 2W Parts 800-482-6022. Marcone:Very helpful. My door is open; thank goodness; it just will not stay closed. Latch broken on door. I have to order the "whole handle assembly" (all one piece which includes the door handle latch too.) $4.16 shipping from PA. I am in Calif. Total $12.53. 2 screws. Easy. I can do it, I know I can. (Signed, a woman in LA!)
I have same problem like you, but I have changed the DDW-813s to a new Lite-On DH-20A4P, it work perfectly, good as new.
but you have to make some changes to fix it to the place
