FixYa.com
Tags:
Microwave Ovens
Generic problem for all Microwave Ovens
Daewoo mt1510w over range micowave (by 4 users)
posted by donbrote on Nov 14, 2007
unit cuts off in the middle of cooking does not do it eveytime once about every 2 weeks then we have to reset the clock ect..........
Comment by donbrote, posted on Nov 21, 2007
it total shut down for about 5 to 10 min. then comes on and we have to rest the clock
thanks Don
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by liamf, posted on Feb 04, 2008
also have the same problem on a daewoo combi microwave. after a few seconds the microwave stops as if someone has opened the door or pressed the stop/cancel button. Keeps doing it until I pull the plug for 20 seconds, then it is alright for anything up to a week.
Comment by conkurs, posted on Jan 23, 2008
We have a similar problem. With our Daewoo microwave KOC-8H4T Stainless Steel.
I placed a cup of coffee (on what must have been) exactly in the center of the turntable to reheat it, set the timer for 30 seconds and it shut off after 7 seconds or so.... repeated attempts had the same result, shutting off within 7-12 seconds..... each time I had to reset the clock...! I tried resetting the microwave by pulling the plug out.... but it did not help.
Then I tried it again, placing the mug of coffee off-center on the turntable and now it seems to work fine....!!
Perhaps some sort of sensor that cannot detect the cup in the microwave when it is in the middle of the turntable, the cup I was using had no handle on it....
I did manage to get the microwave to hang completely, where it would not respond to any buttons, the display showed '0', the light was on, the turntable was rotating, but nothing else happening....
I did also get a fault code that came up on the display IA-18 I think it was, wish I had written it down......
Has anyone heard from Daewoo about these problems?
Mike
Comment by lvBethie, posted on Jan 02, 2008
We have had the same problem. We installed this microwave about a month ago and use it a couple of times a day. Today when we went to use it, it started all right but then cut out in the middle of the programmed time. We checked the breaker box, the outlet, and anything else that we could reach. Nothing. We let it sit for about 15 minutes, plugged it back in, and all was fine. This might be some sort of Daewoo defect. It is NOT the door causing the problem. It was NOT an external power failure. It is definitely an internal problem. Any idea what it could be?
Best Solution
posted on Nov 18, 2007
Helpful (85)
MicrowaveSvc
Rank:Guru Guru
Rating: 87%, 2620 votes
When it cuts off, does it act like someone just hit the stop button or do you actually have to reset the clock as if it got unplugged?
If it's the first one, then it's probably a bad door switch or door switch mount, or possibly a bad connection on the circuit board or a failing circuit board relay.
If you wiggle the door up and down and in and out very slightly, does it fail? If so, this is more eveidence pointing to the door switch or door switch mounts.
If it actually resets so you have to set the clock again, then you are losing power somewhere. This could be caused by a bad connection at the fuse holder, at the magnetron or other thermostat / thermal cutout, or on the circuit board.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Please write back with more details if you need further help.
We appreciate your thoughtful rating of our answer.
Rating Locked! (?) donbrote has rated this solution as Helpful
This Problem Also Relates To: GE JVM1660 1000 Watts Microwave Oven GE JVM1650SH Stainless Steel 1000 Watts Microwave Oven GE JVM1190SY/WY/AY/BY Microwave Oven GE JES1456 1100 Watts Microwave Oven GE JES1851 1100 Watts Microwave Oven GE JEM31 800 Watts Microwave Oven GE JES1288SH 950 Watts Convection / Microwave Oven
Can you Help with these Microwave Ovens problems?
Microwave Ovens
How to stop the beeper and...
emerson microwave oven will not... Answer This...
Microwave Ovens
sharps microwave
i have a sharps microwave model... Answer This...
Microwave Ovens
does not work
does not work Answer This...
Microwave Ovens
thermador microwave from...
thermador microwave from... Answer This...
Microwave Ovens
my R-957M microwave ovens key
my R-957M microwave ovens key... Answer This...
Repair Service
Find Microwave Oven Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
