Question about Logitech Cordless Desktop MX3200 Laser Keyboard Mouse
Up arrow key sticks
My up arrow key sticks. It's not a problem with the key physically sticking. When I press the up arrow once, it moves the cursor up several spaces. If I press shift-up arrow and hold down shift but release the arrow key, the cursor keeps moving up until it hits the top of the page if I hold the shift key.
I've tried unsinstalling the driver and Setpoint, but the problem is still there.
Re: Up arrow key sticks
This fix also works for the LX 710 Cordless! Yay! Thank you.
Posted on Feb 18, 2008
Try to update the firmware of the receiver. I had the same problem and the firmware update solve the problem for me.,en?softwareid=658&osid=
Posted on Feb 04, 2008
0 characters
3 Points
The A key keeps sticking on my Acer Aspire 5551- help!
If you mean the key is physically sticking, as in pressing down but not releasing,it is possible that the plastic spring or rubber stop under the key has broken.
You can remove the key cover and check if the plastic spring that the key attaches to is moveable and that the small rubber stop underneath is present. If the spring is broken, a replacement key can be got from ebay for a small cost. Check also that there is no dirt or sticky patches under the key, these should be removed using meths or a similar solvent.
If the key is not physically damaged, or there is no dirt etc underneath, there may be a problem with one of the traces on the ribbon cable to the motherboard, this will necessitate a new keyboard
Jul 26, 2011 | Acer 91.63X07.001 Keyboard
Sony Vaio laptop. I cant type # (8 or *). I do not see any key sticking.
Most likely, a problem has occured in the physical connection between the key and the "motherboard", since you have pointed out that there is no "sticking" of the key itself. Otherwise, if it were a software/driver problem, you would also have problems with the rest of the keyboard. "Aftermarket" keyboards are relatively inexpensive these days, so my advice would be to purchase a new. Keyboards are "plug-and-play", so after connecting the new one, you will not have to go through anymore're done!
Feb 24, 2011 | Sony Keyboards & Mice
The cursor sticks sometimes when you move it across the screen. sometimes it want move. sometimes when you drag a file to put somewhere else, the cursor want release
replace batteries they get weak and cause mouse to act strange
replace mouse
replace mouse pad, make sure you use mouse pad
clean led light
clean mirror
I got a cheap replacement plug-in led mouse for under 9 bucks Walmart
Nov 27, 2010 | Logitech Cordless Mouse
I can't move the cursor with my cordless mouse - New batteries have been replaced.
You may need to re-connect it. Have a look for a little button on the bottom of the mouse... and a little button on the reciever stick that pkugs into the computer, press them one after the other and see what you get? Hope this 'Helped?
Sep 26, 2010 | Logitech Cordless Mouse
My keyboard is too sensitive to touch and one wrong key moves the cursor too fast on the msi a6005 I find myself typing away and the cursor moves to another place on the screen. Is there a way to tone down...
my keyboard is way too sensiticve. when ltyping if i don't hit my key dead center and just a small lportion of my finger touches a key arouind it, that key is also typed. I am a good typist, but when not looking at keyboard and going too fast I don't always hit jmy key dead cwenter. i would like a keyboard like an old typewriter. do they sell less sensitive keyboards ???
Mar 11, 2010 | Keyboards & Mice
Cordless Mouse Dell
Hi , your mouse is losing signal too the adapto that you plug into your PC , try putting it close , and change the batteries , this will help
Dec 29, 2009 | Logitech Cordless Mouse
How can I copy and paste a document/item by using the keyboard
You can copy and paste using keys.
CTRL (+) C for copy
CTRL(+) V for pasting.
Nov 19, 2009 | Keyboards & Mice
I use my computer for gaming and when i move around with the arrows they stick sometimes in one of the directions un til i tap that key again, is this common for the classic keyboard 200?
Logitech keyboards are excellent both in quality and longevity.
Make sure some sugary drink has not been spilled on the keyboard.
This will make the keys stick and repeat. I have had good luck with Dawn and warm soapy water. Just make sure the keyboard is completely dry before putting back into service. 1-2 weeks drying time. (IF you dunk and submerge. Only the most severe)
Never EVER dunk a laptop in water to clean the keyboard.
I know I know... but someone will try it. :)
Check to make sure the windows sticky keys are turned off.
Sounds like dirt or a soft drink is causing this repeating pattern you described.
Oct 10, 2009 | Logitech Classic 200 DH968019 Keyboard
Backspace and up arrow keys seam to stick
blow into the arrow keys and into the backspace key(maybe some dust is malfuncioning the keys
Jun 12, 2009 | Logitech Cordless MX Duo 967300-0403...
Logitech Cordless Desktop MX3200 Laser Keyboard Mouse Logo
325 people viewed this question
Top Logitech Keyboards & Mice Experts
micky dee
Are you a Logitech Keyboard and Mice Expert? Answer questions, earn points and help others
