Question about Minolta magicolor 2300W Laser Printer
16 h error wont calibrate or print what to do should i open i think labels are stuck in there
  • 214 Answers
16H means, that the transfer belt does not rotate correctly, open all covers, remove any paper, whats stack inside, remove waste toner box, drum unit then open 2 nipple screws and pull out the transfer pelt, if the belt looks ok, reinstall everything and power on again. if works, then everything is ok, if not, then there is something wrong with TBU or TBU
Posted on Feb 28, 2008
Also if the tab breaks off the door that you open to remove those items, it won't allow the drum lock to release. It is a tab next to the edge that you open. I bought one the other day, and this tab was broken off. It was giving me either a 16 or 17h error. I made my own tab and it works fine.
Posted on May 18, 2008
How do you calibrate a Konica Minolta Magicolor 3300 printer?
More then likely the Cyan Image unit needs to be replaced
Oct 25, 2012 | Minolta Magicolor 3300 Color Printer
I have a KonicaMinolta Magicolor 3730DN. It fails with Fatal error code 0F55H.
Toner level sensor for the black toner is bad or the black toner is not getting into section where that sensor is. ensure your black toner cartridge is OK
Oct 05, 2012 | Minolta magicolor 2200 DeskLaser Printer
Printing problem on a Konica Minolta 2530DL. Was printing fine until we printed a set of thick labels. Now the print quality is really poor on the right side of the paper. It is both streaking and...
sounds like a lable has gotten stuck in the fixing unit, you may need a tech to remove it, do not use any sharp tools to remove it ,this could cause damage to your roller,
good luck, tinyman
Jul 19, 2011 | Konica Minolta Magicolor 2530 DL Laser...
My Konica 2300DL is showing an error that reads AIDC Error and I cannot print anything
you may try bellow for your print trouble
1) clean laser lens cover using soft cloth,
2) perform an AIDC calibration cycle through the manu--- Engin/service/power on/test
reference user guide P81-82
Feb 01, 2009 | Konica Minolta magicolor 2300DL Laser...
Magicolor 2200DL
calibrating FW:412050G123D0 I think it says calibrating firmware. what happen before you get this error? did you try to wait for a long time?
Oct 05, 2008 | Minolta magicolor 2200 DeskLaser Printer
Avery Labels STUCK to drum, can't figure out how to get them off
you can clean it with a little alcohol or water, just take a good look at the PC Drum and Transfer unit, remove them from printer first, find labels and with wet cloth carefully wipe it away. but you should know that even if you remove labels there may still some marks on TBU and PC drum what leads to quality problems.
Sep 07, 2008 | Konica Minolta magicolor 2430 DL Laser...
Magicolor 2300DL 17H fatal - labels stuck in printer
This happened to me last week. A label (or part of it) has adhered to the belt inside the printer. It's an easy fix. Turn off printer and open the side door. Remove waste toner bottle. Lift blue handle in direction of arrow to 11 o'clock position to release belt unit. Carefully remove OPC drum by pressing and pulling handle as shown by little graphic (try not to leave this drum in lighted area and don't touch green drum with fingers). Next, remove two chrome thumbscrews (may have to use slotted screwdriver) on either side of belt unit, then pull out belt unit and inspect to find stuck label. You can rotate belt easily. I removed stuck label and then cleaned glue residue with Elmer's Sticky Out ( a citrus product with no solvents) and a soft cloth. Clean thoroughly and replace belt unit, replaced thumbscrews, OPC drum, and finally, the Waste Toner bottle. Close door, turn on printer and test.
Aug 12, 2008 | Konica Minolta magicolor 2300DL Laser...
My magicolor 2530 DL
Hi Condeleeza,
Normally smoke would be caused by label residue being left on the fuser rollers, I am assuming your use of the word label is correct and not a transparency (which is a common jamming source in laser printers) especially when someone mistakenly puts a inkjet transparency through a laser printer or mistakenly puts a clear plastic divider sheet through.
If you are sure all of the original label has come out and there is was no residue left directly on the fuser rollers, and the fact you now have smoke and an error code (which I do not have access to find service codes for Minolta), I suspect the fuser assembly is overheating now which is causing the error message (after probably 10 seconds after switch on from cold). This could mean the temperature sensor monitoring the fuser temp is either not touching the fuser due to label fragment lifting sensor off fuser roller surface or sensor is bent or damaged due to label revolving aorund or subsequent removal efforts.
Take a closer look and see if you can find a stray fragment stuck to a thermocouple sensor wiping against the fuser roller. Failing this then you probably need to send into service and ask for a quote to repair. Be aware that the fuser may have become scratched or otherwise damaged depending upon your label removal techniques....over zealous use of letter openers, nail files and small screwdrivers have destroyed many a good fuser assembly.
Good luck
Jan 14, 2008 | Konica Minolta Magicolor 2530 DL Laser...
this code means, youre label get stuck in TBU and the TBU is not rotating anymore, take out tbu and try to find these labels and remove them with alcohol, do not scratch the belt.
Nov 14, 2007 | Office Equipment & Supplies
Magicolor 2200 can't complete warm-up
clean the connectors of the toner cartridge, transfer unit, drum cartridge. did it signal ** toner? replace if needed. check the status of your printer install the printer utility then see the machine status you will see error codes. tell me if what is the code..
Nov 08, 2007 | Minolta magicolor 2200 DeskLaser Printer
Minolta magicolor 2300W Laser Printer Logo
278 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
