Thanks
You have to renew the ip address.the easiest way to do this is restart the computer then try entering your net key.ALSO if you use a standard ethernet cable the computer may be trying to connect to the internet through that.what you want to do is disable the LAN connection in your network connections window and right click on the wireless connection icon and click REPAIR,this will renew your IP address also.If you do not know how to get to these settings go to START/ CONTROL PANEL/NETWORK CONNECTIONS then right click on your wireless connection then click repair.While your in that same window you can right click the LAN connection and disable it.To enable it simply right click the icon again and click enable.
I can't connect with my wireless on my laptop nc6000, everything says its ok in the device manager but it does'nt recognize the wireless network
