Question about Panasonic RX-ED707 Boombox
Overall Problem - Panasonic RX-ED707 won't work properly at all
1. Top Panel won't lift or close down the first try
2. CD and both Tape Decks won't open at all
3. Stereo makes strange clicking sound when pressing any button except both Volume Buttons
4. None of the buttons work properly at all except both Volume Buttons
5. Display Indicator always flashes Three 0's, when trying to press any button (except both Volume Buttons) it'll show the particular setting for a split second before heading back to the flashing Three 0's
6. Power Light Indicator often flash Red, or sometimes flickers Green
7. Can't turn off stereo with Power Button unless unpluging the stereo completely
8. Can't get any sound from out of the stereo
9. Can't access Radio, Tape, or CD Compartments at all
  • Anonymous Mar 11, 2009
    Cant acces radio
Only 1 reason for that faults :
there is a flat connects the top panel which has all the controls with the other circutes in the stereo...
so you have to open it and care for the cd unit it damage easily then check the flat for loseness or cuts
it happened to me also and that works perfectly
good luck
Posted on Dec 21, 2007
  • George Tsai
    George Tsai Jan 31, 2014
    hI RQA300, I tried to check the FFC cable as you mentioned, it is fine (no lose or break) but still don't work? I think because of the humidity the front key panel is not working properly, is it possible?
No display on the LCD but with power on ligth
Posted on Jul 13, 2008
Where can i find schematic wiring diagram of panasonic rx-ds101a?
We recommend you contact our National Parts Center and obtain the unit's service manual. They can be reached at 1-800-833-9626.
May 01, 2014 | Panasonic Portable Stereo Cd System...
Tape deck on Panasonic RX-DT680 boombox issue
I think this should be a simple fix! The deck will have switches at the top of the cassette compartment. These detect the tape and also select it for type - metal or chrome etc. These switches have become bent or damaged or have dirt on them.
May 18, 2013 | Audio Players & Recorders
I require a user manuel for a Panasonic cd/double tape/radio model RX-ED70 EB-K FS61OE4750 CLASS 1 Panasonic Laser Product . Many Thanks for your help. bwesmith
You can get your manual for free from here:
http://safemanuals.com/user-guide-instructions-owner-manual/PANASONIC/RX-ED70-_J
Enjoy
Aug 13, 2010 | Panasonic Audio Players & Recorders
Need replacement remote for rx-ed707 panasonic boombox
here is link for your manual:
http://service.us.panasonic.com/OPERMANPDF/RXED707.PDF
based upon panasonic parts # looked it up and found a replacement for your remote.
MODEL: EUR644864
just google search it and replacement is available for 26.49.
Cheers!
Feb 15, 2010 | Audio Players & Recorders
Tape deck is stuck
push the eject button at the same time get a nail file and insert it in the tape slot
on the right hand side of the deck
it may take three hands one to push eject one to push the eject mechanism inside the radio behind the tape
and one to help remove the tape
if that doesnt work....dont try forcing anything as the stereo WILL break..... take the stereo out of the car, so it is not connected to the electrics, then either, gently take it apart with a screwdriver
I would suspect the belts, look for any small motors and missing belts. You may be able to manualy turn a wheel or gear till it ejects.
if your not comfortable doing this urself with the above said porcedures... its better to take it to the dealer...
regards iversh
A very helpful rating is appreciated for answering Your Query
Aug 30, 2009 | Panasonic RX-ED707 Boombox
Kenwood cassette receiver rx-28
There are sensor leaf switches that may not be contacting properly or the drive belt may be too slack to position meachanism properly. Have it checked by pro/tech
Apr 13, 2008 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
Error Code F26
Here is the link to the user manual if you need it; http://service.us.panasonic.com/OPERMANPDF/RXED707.PDF although of course it doesn't list that error code and panasonic no longer support the model on their site except for the user manual. If you don't mind paying $19.50, then these guys have the service manual available which almost certainly will list the error codes and their solutions; https://www.manualsparadise.com/ShowProductsForModel.do?model=M91217722 Sorry I had no luck finding that one for free. My guess is that the lens needs cleaning, and that the error code simply means "bad disc" or something similar. Best way to clean the lens is with a cotton bud/ Q-Tip moistened (not wet) with gin - nothing else works as well or as safely. This should be easy to do as you have direct access to the lens, just be gentle. If you get no luck from that then the best i can suggest is to contact panasonic direct; http://www.panasonic.com/support/ and see if they can tell you what the code means, if they do, and you need help solving the problem, please ask again. Good luck, I hope this helps
Jun 23, 2007 | Panasonic RX-ED707 Boombox
Panasonic RX-ED707 Boombox Logo
451 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
