Samsung CLP-670ND Color Laser Printer Logo
A
Anonymous Posted on Jun 02, 2015
We have a Samsung CLP-670ND laserprinter that gives a paper jam when printing from tray 1.
When we print one page the printer first print a few blank pages before the printed page jams. When we print from the MP tray the printer works fine. Can anyone help us?
Vinnie Marone
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 77 Answers
  • Posted on Jun 03, 2015
Vinnie Marone
Expert
Level 2:
New Friend:
Greenhorn:
Answers
77
Questions
0
Helped
29529
Points
119
Theres a bad guide on paper tray sounds to me
  • Anonymous Jun 04, 2015
    I forgot to mention that I tried the papertray and the pick-up roller from another printer, unfortunately this did not solve the problem. My conclusion is the problem is not in the papertray.
My samsung CLP-670ND is printing 4 separate images (one of each colour) offset by approximately 2mm.
It sounds like the image stabilization/calibration has not been completed properly, remove 3 print cartridges ( any) switch unit back on and wait for display to ask for other cartridges, - insert when asked and allow the machine to complete the calibration, alternatively use the menu function and look for image stabilization under diagnostics and activate.
1helpful
3answers
My Samsung CLP 315w refuses to print a whole A4 page. Stops half way then message comes up paper jam but when I open back / front, paper not jammed and when I close it document continues printing then...
most likly hood is your exit sensor is faulty. The printer work in this way. if it does not print out all the document. it will print again. that is why you kept getting this same issue after a jam open and close door it will print again.
replace the exit sensor it will help.
My Samsung 310 printer is giving a paper jam message inside warning when I turn the printer on and yet there is no paper jammed inside. Cannot print. Been working fine before. Mayb 100-150 pages printed...
Chek paper size (A4, letter...etc)in driver options and compare it whit your file settings (fo example - you trying to print something whit paper size A4 but printer expect letter format...etc)
Clean paper feed roller
Paper keeps jaming in paper tray
Try to give several print outs by placing paper one by one (Not a bunch of paper ) in Paper Tray. if it prints perfectly prints then your should use higher quality papers with no scrach on paper. and after that still issue of paper jam then
Your printer need to to be serviced by technician. It looks like Paper Pressure Roller of Printer is damaged.
Paper jam in tray 1
Hi glenpcr,
I had the same problem and solved it.
At my printer it was a problem of the MP-tray (multi purpose tray).
There are two hinges which keep the open MP-tray in a horizontal position. One of this hinges was broken and I just received it.
Just try it.
regards,
Stephan
I have a Samsung CLP-600N. When I try to print I get a Paper Jam Tray 1. There is no paper jam. The paper is not feeding. I tried to hold up the Sensor arm and tried to print again. The feed does not...
hmcoul,
In my experience, very rearly is the sensor bad, the sensor is a simple optical sensor activated by a flag. All this sensor does is indicate if there is paper in the tray or not. The most likely problem is that your paper feed roller,(the rubber roller at the back of the printer in the paper tray area) is embedded with paper dust as is very comon on these units. try getting some water or even better still some eucalyptus oil and clean the roller. try to print again and see waht happens.
Gremlin11
2answers
Not printing, making me crazy
A paper jam has occurred. To solve the
problem, see “Clearing Paper Jams” on
page 6.3.
• The front or top cover is opened. Close the
front or top cover.
• There is no paper in the tray. Load paper
in the tray.
• The waste toner container is not
installed or full. Check the container.
• Your system has some problems. If this
problem occurs, contact your service
representative.
  • Also i can indicate that the Toner Cartridges are empty and need replaced with Genuine Samsung Cartridges
Not printing (paper comes out blank)
it is possible that is has problem on your printer's memory... try printing below 30 pages see if problems still persist.
3answers
Paper empty message when pdf
Could be a page size problem.
A4 paper in the paper tray, but what page size does the PDF think it is?
Top Samsung Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
