Question about Panasonic Proline AG-DVC7 Mini DV Digital Camcorder
Ag-dvc7 when turned on am told to push the reset button.then told needs to be serviced
  • 221 Answers
Re: ag-dvc7
Most likely cause of this problem is loose or dirty cable connections to the video head or mechanism in the camera. get a tech to disassemble the cam and check the flex cables connecting the main board to the mechanism. same fix is good for AG-DVC10 and AG-DVC15.
Posted on Dec 05, 2007
0 characters
3 Points
Panasonic AG-DVC7 Mini DV Camcorder comes on with blue LCD screen with a message in red "press the reset button" .....when i do that, another message appears in red "this camera needs to be...
This is usually caused by an oxidized, misaligned or defective Audio/Video drum. You can try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be serviced by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair cost low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on .
Sep 15, 2011 | Panasonic AG-DVC7 MiniDV Proline Camcorder
I take the cover off the door, using the eraser as the end of a pencil - lightly press on the recording head (drum). Put a tape in and watch to see if the tape now wraps around the head and stays in position to record.
It turns on but when you push the recorder button it shuts off
Bad power switch... very, very common with the DVC7 and DVC15. Get the power switch/recorder button assembly replaced and hopefully you won't have the problem again until the new one decides to act up.
Apr 09, 2010 | Panasonic AG-DVC7 MiniDV Proline Camcorder
Camcorder will not turn on.
I'm not a technician, but we just sent our AG-DVC7 to a repair shop. For $45.00 they told me the CCD Unit and the CCD board were bad. they wanted $250.00 for parts alone. The camera is 8 yrs. old and I don't see a $400-500 repair as a good investment, as the new unit is only $1000.00
Jan 19, 2010 | Panasonic AG-DVC7 MiniDV Proline Camcorder
Need to replace lens
The DVC7 has a 43mm filter thread on its lens. Depending on your Bower's thread size, you may need a step-up or step-down adapter ring to fit it to the DVC.
After checking if you have your sizes correct, you need to remove the DVC7's lens hood. After that, it's just a matter of screwing the wide angle lens to the DVC's lens.
Hope this helps!
Nov 14, 2008 | Panasonic Proline AG-DVC7 Mini DV Digital...
take the tape out of the camera. you don't need to put a tape in the camera if you are not recording in the camera.
Apr 20, 2008 | Video Cameras
Is there an easy fix to Panasonic AG-DVC7 camcorder error F05, cylinder lock?
when you press the reset button, the first thing the camera does is a self-test of the mechanism. "cylinder lock" is displayed when the video rec/playback head drum (cylinder) motor does not operate or operates intermittently. this is usually caused by a poor connection on the small cable that connects the head drum assembly with the main control circuitry inside the camera. disassembly of the camera is necessary to clean and re-seat this cable, along with the cable that carries the video information to the head drum. I have repaired several of these cameras with this problem. it's not difficult, but an inexperienced repair person can do more damage than help if they're not careful.
Dec 10, 2007 | Panasonic Proline AG-DVC7 Mini DV Digital...
Panasonic AG DVC 20
check beneath the fold-out LCD screen.
Dec 01, 2007 | Panasonic AG-DVC7 MiniDV Proline Camcorder
Panasonic Proline AG-DVC7 Mini DV Digital Camcorder Logo
283 people viewed this question
Top Panasonic Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
