SOURCE: Sony 61" lcd has bluish spots in screen, any ideas?
Hello, inside the set there is an optical unit with 3LCD panels. Somehow the dust particles came into your set and now the dust is all over the optical unit and 3LCD panels. Only way to solve this issue is to clean the dust. Please contact your Sony dealer. Best regards, Arpi
SOURCE: Big grey/black spot
Is it a fuzzy spot or an actual hard edged black spot?LCD televisions can have a loss of pixel display- most very small. Was the TV hit with something or dropped against something (the screen)?
OR Try this first:
Black box appears on the screen
• Closed-captioning might be on. Check the Analog or Digital Caption option in the Setup menu.
Please let me know if your problem is solved. Thank You.
SOURCE: Screen has black spot in corner that spreads to entire screen
one of the floresant bulbs has fail there is a place in Haverhill Ma called Tops Electronics that can fix you up really quick but you will have to ship it to them they do good work there
their new name is pinnacle solutions group over 30 year serviceing
SOURCE: Power Only
On the LG TV remote, press either the "return" button or the "exit" button, then press power to turn it off and then power to turn it back on again.
Fixed!
(This happens when some other device remotes send a strange signal to the LG TV, putting it in a service mode).
SOURCE: my 47" LG LCD TV
its no big problem.I implore you visit the user's manual to see how to zoom and undo it. Get back if you encounter further problems.
