Question about Zenith C27A24T 27" TV
Need help cant find vaux video so I can hook up my palstation
  • 50 Answers
Re: need help
Scan below channel 2 and video should show? Or doesn't it have the audio/video jacks?
Posted on Nov 28, 2007
0 characters
3 Points
Konka 32 lcd tv kl32bs22u
RCA ouputs :
locate those colors
in a row usually label AUDIO/VIDEO
Aug 10, 2013 | Standard (CRT) Televisions
Im trying to hook up s-video to my old RCA tv and I cant get a picture. Can you help me.
Make sure you are selecting the correct input channel, and also make sure the yellow video cable is disconnected from both items. The two cables do not need to be connected in fact disrupt signal when they are.
Feb 04, 2011 | RCA F31672ET TV
Have no remote trying to hook my dvd player to tv cant get it to find av or aux channel on my broksonic ctgv 4563tct
Try the channel buttons and go below channel 2 or above 125 that`s usually where you will find the video input. Hope this will help.
Dec 01, 2009 | Broksonic CTGV-5463TCT TV
Cant get my cable hooked up
check your unit if it is cable tv compatible.then, hook your cable to antenna in.then do the manual tunig/search for channel.if not,you'll need to buy a cable converter ,much better if it has audio/video out.
Mar 29, 2009 | Mitsubishi CS-40503 TV
You need a RF Modulator that outs the signal into the cable input because the TV has only a video input (yellow) but no audio in, only audio out. Radio shack has one for about 29 dollars.
Mar 22, 2009 | Sanyo DS31520 31" TV
No sound - no video on TV
if you're hooking your VCR via analog video input of your TV then check that the yellow colored video wire goes to yout TV video input, will also be colored yellow inside the terminal. The white and red color inputs are for audio. Likewise the output of your VCD will have the same colord code Yellow for video, red/white for audio (stereo). After setting this up, select your TV function to video in, be sure to check your video input channel as well if you're having more than one video input. Video 1 or 2 or 3. Make sure your VCR is powered up when you start to setup your TV function select.
if you're hooking your VCR to your TV via RF signal (over your TV tuner) You need to scan the right frequency to get it tuned to your TV channel. Cabling willbe via RF antenna input of your TV and RF antenna out of your VCR.
Mar 17, 2008 | Standard (CRT) Televisions
How to hook up a DVD player
Go to this link; and a short way down under "Product Details" there is a link to the product manual page 7 and 8 of the manual (page 9 and 10 of the pdf file) should tell you what you need to know. Please post again if you still have trouble; Hope it helps :)
Mar 29, 2007 | RCA F32450 32" TV
Samsung TXJ2754 (27") DVD issues (Sound but no Picture)
Assuming you have picture on the TV when hooked up to cable, antenna or satellite I would take the DVD player to a friends house to see if it worked on their set (using your cables of course). If you can't get a picture on your TV no matter what, then it could be either the Jungle IC or EEPROM IC inside the set. Since it displays "No Video Signal" on the screen, that leaves out the High Voltage section of the TV. My main suspicion would be the video cable or settings on the DVD or TV.
Jan 02, 2007 | Samsung TXJ2754 27" TV
Zenith C27A24T 27" TV Logo
42 people viewed this question
Top Zenith Standard (CRT) Televisions Experts
matt martin
matt martin
Anastasio Benjou
Are you a Zenith Standard (CRT) Television Expert? Answer questions, earn points and help others
