Question about Mitsubishi WS-65905 65" Rear Projection Television
Mits. rear projection tv ws65905 picture has blue color tint
Why tv has blueish color tint
  • Mitsubishi Master
  • 737 Answers
Your blue picture tube is failing. Invest in a new TV. "If" you can find a new set of tubes(you have to replace all 3 red blue and green) they are around $800-1000. Not cost effective. Run the TV into the ground if you want to wait but do not invest any repair money in my opinion.
Posted on Jun 03, 2015
SOURCE:
Blue screen for about a half hour and then still blueish color
Tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D look pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts,must be replaced on the tv convergence board to solved the tv convergencce picture problems.The shop,will cost u $300-350 for parts and labors.
Oct 20, 2010 | Sony KP-65WV700 65" Rear Projection HDTV
BLUE TINT ON MY SCREEN
Philips tv's have always had this problem. Between the picture tube and focus lens there is a layer of coolant fluid. The coolant fluid, over time, will break down and turn a brownish cloudy color and it usually starts with the blue. Something to do with the color frequency. Have a good repair shop check it out and if the fluid is the problem have them change all the fluid in all 3 picture tubes (there is a red, green and blue tube). Don't feel bad, like I said all the philips projo's had this problem. Thanks
Oct 29, 2009 | Televison & Video
Blue tint on rear projection tv
If this is a crts model , then one of the crts had blown, if it is a lamp rear projection, then it is a fault on the video circuit.
Mar 14, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
BLUE TINT ON SCREEN ALL THE TIME, COLOR ADJUSTMENTS FINE
Sounds like a bad blue CRT (picture tube) ITs expensive and difficult to replace. CAll a Sony service center for an estimate. but expect to spend $500-700 to replace it.
michtech
Feb 18, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Bad Picture Blueish picture
If the red gun stops working it could make the picture very blue-greenish. This could be caused by a number of problems, including a coolant leak, but it's most likely a bad electrical connection somewhere in the set.
Best left to a professional repair guy, frankly.
Mar 19, 2008 | Samsung HCM5525W 55" Rear Projection...
SONY KP53HS30 rear projection TV screen suddenly turned blue....
The blinking 5 times is an error code meaning that the white balance has a failure. And because you are experiencing a blueish screen then your problem lies in the circuit of the blue picture tube or possibly the blue tube itself is starting to go bad.
C-Dog
Feb 05, 2008 | Sony KP-51HW40 51" Rear Projection...
Blue Screen/Waviness
sounds like convergance ic's mits is also know for bad caps
1000uf @ 16v check for bulges on top of the cap
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 05, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-65905 65" Rear Projection Television Logo
130 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
