Question about Dishwashers
Bosch Dishwasher 2H problem
get a 2H error message and machine runs on and water does not heat up on all but lowest temp cycle.
Is it new control unit ? If not then what else could it be ?
what they like to install ?
Many thanks
  • remarkablega Mar 17, 2009
    I have the 2H problem and my washer runs for hours. I have tried to reset it and tried the delay button but nothing works. Please tell me what to do.
  • Anonymous Mar 16, 2014
    message 2h on control panel
Found a cheaper solution than replacement control panel. Loads of rich people buy integrated kitchens soon after buying brand new dishwashers. They then sell them standalone cheap in Friday-Ad. Far easier than replacing the control panel, a lot cheaper and we now have an 18 month old instead of 7 yo washdisher. Great.
Posted on Nov 24, 2007
  • 213 Answers
Yes it needs a new control and its pretty easy to replace
Posted on Nov 20, 2007
My gaggenau dishwasher GM 954-110 is not working. when i switch it on the display panel shows 2H.
Hello, welcome to FixYa.
The dishwasher you're speaking of (provided it is indeed a Gaggenau GM954) is built by Bosch as you may or may not know.
To address your concern regarding the 2H in the display actually needs to be done in two parts. I'll start with the basic info associated with the 2H displayed.
This can be simply indicating the previous cycle exceeded a 2 hour wash cycle, not necessarily an error and can be attributed with too cold water entering the dishwasher (below the recommended 120F), a longer than normal drain time (due to partial blockages, kink etc. hence longer time needed to complete the cycle) or inproper water circulation during the cycle.
Aside from these issues, it (2H) can also mean the unit has a heating error and if left long enough will show another error of "1" in the display, extremely long wash times, etc.
**The first thing I'd suggest before attempting any repair is running an additional cycle while making sure the water inlet is hot (120F optimum) and the unit does indeed drain fine.
**A fair indication of proper draining is to start a cycle and once washing begins (2-3 minutes) activate the "cancel" and the unit should adequately drain in the 2 minute time allowance.
**To identify proper water circulation, place an empty cup in the upright position in the top rack, start a cycle and inspect the cup after 2-3 minutes and it should be full of water.
After trying and posting the results of these thing's we can move forward with potential heating errors, the cause, and how to remedy them. Let me know what you find and I'll continue to assist you in any manner possible going forward. Good luck.
Macmarkus :)
Jun 30, 2011 | Dishwashers
What is error code 2H
My Bosch dishwasher did the same thing. When the wash cycle starts, the dishwasher fills with water and then the heater is supposed to turn on to heat the water. If the water does not heat, then it will display 2H continuously. The heating element may be bad, but a more likely cause is with the control module. Bosch has a problem with the control module printed circuit (pc) board that powers the heater on many models. The solution requires some technical expertise and soldering skills. The details are explained in the document "Bosch dishwasher troubleshooting tips" on page 11. Download here
Bosch recommends re-soldering the connection, which is a temporary fix. The problem is that the copper conductor (called a trace) on the circuit board is not wide enough to handle the current required for the heating element, and as a result the copper trace overheats, causing the solder to melt on the relay connection. The best solution is to remove the control module PC board and solder a short length of copper wire between the pins to prevent the overheating problem, as shown in the attached photo (magnified portion of PC board). I did this on my dishwasher and it has been trouble-free for over 3 years.
Jul 07, 2009 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Touchpad--No Response
The "2H" is an error code indicating the control panel needs to be replaced.
May 08, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
2H displayed and pump runs nothing else happens
I would check the buttons on the control they may stuck. check the delay button..
Dec 21, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Error code 2H
The control panel needs to be replaced (indicated by the "2H" error code displayed at the start of the cycle).
BTW - The number 1 displayed at the end of the cycle indicates the cycle has timed out (i.e., it doesn't mean 1 minute remaining). Hence the continued running of the unit. Until you replace the control panel, you'll have to manually cancel the cycle at this point.
Oct 08, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch SHV 6800 dishwasher, 2HR error
Bosch dishwasher all cycles start at 2H and get hungup on 1 min.
Jul 02, 2008 | Bosch SHU9950 Dishwasher
Machine runs for 4 hrs and 2H shows
Problem machine ,replace the control electric
May 21, 2008 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Error code 2H.....or stops on last minute
I don't think you'll find it's the control board.
I think you'll find it's the heater box.
Not an easy job to do yourself unless of course you know what you are doing.
I would suggest you contact Bosch. One other possiblity is that the water inlet is blocked, although to be honest this is very rare.
Deep Diver
Dec 31, 2007 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Sounds like water....dx doesnt work
2H means the machine is taking longer than 99 minutes to run a cycle. Start the cycle and wait 5 minutes, then open the door. If water doesn't look like it is spraying out the wash arms or slowly coming out the wash arms, then check to make sure the filter at the bottom is clean. If clean, then sounds like your circulation pump isn't running or impeller has came apart.
Dec 16, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
741 people viewed this question
Top Dishwashers Experts
