Question about Brother MFC 420CN All-In-One InkJet Printer
Can't make it work
I have just bought a Brother LC_51 but when they send me faxes I can't reciiev them it says something about catiges
  • Anonymous Feb 19, 2008
    I place the document in the top. I put in phone number and hit start, it keeps saying no response busy
What exactly does the display show? Please write it here again otherwise we cant give you a cue!
Posted on Nov 14, 2007
How do I fax on brother LC-51
LC51 are Ink Cartridges , not the model. Please specify model
Oct 16, 2014 | Brother Office Equipment & Supplies
How do I receive faxes with the 240c
Manual mode turns off all automatic answering functions unless you are using the Distinctive Ring feature or you are using an external answering machine on the same line as the Brother machine.
*Distinctive Ring is a function of your Brother machine that allows a person with one line to receive fax and voice calls through two different phone numbers on that one line. Brother uses the term "Distinctive Ring," but telephone companies market the service under a variety of names, such as Custom Ringing, Personalized Ring, Smart Ring, Ring Master, Ident-a-Ring, Ident-a-Call, Data Ident-A-Call, Teen Ring, SimpleBiz Fax & Alternate Number Ringing and BT Call Sign.
  1. Setting the Receive Mode
    1. Press Menu.
    2. Press the up or down arrow key to select Initial Setup.
    3. Press OK.
    4. Press the up or down arrow key to select Receive Mode.
    5. Press OK.
    6. Press the up or down arrow key to select Manual.
    7. Press OK.
    8. Press Stop/Exit.
Receiving Faxes in Manual Mode
  1. Lift the handset of a telephone that is on the same line as your Brother machine.
  2. When you hear the sending machine's fax tones (short beeps that occur at regular intervals), do one of the following:
    • If the telephone you answered is near your Brother machine or connected to its EXT jack(socket), press Black(Mono) Start or Color(Colour) Start.
    • If the telephone you answered is not connected to or near your Brother machine, press *51 (*91 for New Zealand) on its dial pad.
  3. Your Brother machine will produce receiving tones.
  4. Replace the telephone handset. Your Brother machine will begin to receive the fax.
< Easy Receive (Fax Detect) >
The Easy Receive (Fax Detect) feature allows you to receive faxes in Manual Mode by simply lifting the handset of a telephone that is on the same line as the Brother machine. Your Brother machine will automatically generate fax receiving tones, at which point you can replace the telephone handset and wait for your fax to be received and printed.
Your Brother machine's Easy Receive (Fax Detect) feature is turned ON by default. To adjust your Brother machine's Easy Receive (Fax Detect) setting, please follow these steps:
  1. Press Menu.
  2. Press the up or down arrow key to select Fax.
  3. Press OK.
  4. Press the up or down arrow key to select Setup Receive.
  5. Press OK.
  6. Press the up or down arrow key to select Easy Receive or Fax Detect.
  7. Press OK.
  8. Press the up or down arrow key to select On, Semi or Off. *In some brother machines, Semi may not be in the options.
    If you choose Semi, your Brother machine will only answer an incoming fax if you answer using its handset or by pressing the Hook, Hook/Hold, Hold, Speaker Phone or Tel/R key on its control panel.
  9. Press OK.
  10. Press Stop/Exit.
Note Here are a couple of points to keep in mind:
  • If Easy Receive (Fax Detect) is ON, but your Brother machine doesn't automatically answer the incoming fax when you lift the extension telephone's handset, press *51 (*91 for New Zealand).
  • If you send faxes from a computer that is on the same telephone line as the Brother machine and the Brother machine intercepts the calls, turn Easy Receive (Fax Detect) OFF.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Jul 14, 2010 | Brother Multi-Function Center MFC-240C...
Just bought brother fax 1960c My dsl for the
Look on Page 101, "Phone line interference" and be sure compatibility is set for "basic." See if this works.
lstaples@kc.rr.com
Jan 13, 2010 | Brother FAX-1960C
I have black ink in my printer brother lc-51
Its because grayscale is selected in colors section.
Sep 26, 2009 | Brother Office Equipment & Supplies
Having trouble receiving faxes, takes several times of someone sending to me to receive.
First thing to check is the condition of the phone line, if the machine has a handset make a phone call from the handset, is the line clear? Is there any static or Echos on the line?
Is the machine on a shared line with computers or an answering machine?
Call the Fax machine from a phone, is the line clear? did the machine generate its handshake burst? Did anything else try to answer the line?
Check the phone cable input, it should be going onto the LINE jack on the back of the machine.
Apr 15, 2009 | Brother IntelliFax-1860C Plain Paper...
NEED THE MACHINE TO ANSWER WHEN THE PHONE SENDS THE SIGNAL.
After making my post, I went to the official Brothers website for the 4100 FAQs and "Operating Instructions." Here's what I found. Set your 4100 set to the "Fax/Tel" mode. Press "Menu", then the number 2 (Fax), then number 1(Set-up Receive), then number 1 again (Ring Delay). Use right arrow key to increase. Once increased, press the "Set" key. You'll see the message "Accepted." Now press the "Stop" key to exit "Menu." This will now give you up to 4 rings before the fax auto answers. Inorder to send a signal by phone to remote start the fax just follow the instructions I copied directly from Brothers instructions for the 4100: If you answer the call on an extension phone (this is any phone plug into a phone jack on the same line) and hear a beep every 3 seconds (automatic fax) or just silence (manual fax), press *51(remote activation code) on the telephone keypad, wait to hear the Brother machine turn on (chirping sounds) and then hang up. I don't have anyone that can send me a fax right now to test it out. I'll have to try it in the morning. Hope this works for you.
THEOH
Feb 23, 2009 | Brother IntelliFAX 4100 Laser Fax
I have a MCF LC-51 series fax, and scanner I cannot fax or recieve.
check for a dial tone using a regular phone plugged into the wall jack.
make sure the phone cord is hooked into the LINE jack on the machine
make you do NOT have a DSL line.
Sep 02, 2008 | Brother Office Equipment & Supplies
Faxing
the best way is to call brother hotline due to so many diffrent telephone line techniques!
You may read the chapter fax within the manual or have a look around here:
http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_list.html?reg=us&c=us&lang=en&prod=mfc240c_all&Cat=12
Sorry, not possible to give a brief and direct answer to your question.
Jan 24, 2008 | Brother Multi-Function Center MFC-240C...
Brother LC-51
I have a brother LC51 and when I try to fax, it rings but once the receiving fax picks up, I get a busy signal. Also, it will not receive faxes. Any Ideas. Thank You in advance for any suggestion.
Sep 08, 2007 | Office Equipment & Supplies
Brother MFC 420CN All-In-One InkJet Printer Logo
19 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
