Question about Neovo E-19A 19" LCD Monitor
Power problem? I have one of these monitors but not the original power adapter, so i use a universal.The Power seems to come on the go off, so basicly it flickers on and off. the green light flickers too! any ideas on how to fix?
Re: Power problem?
Try ordering a new power adapter from Neovo. Call them up. It could't hurt. Apparently adapters are tricky items. I have no idea how much they cost, but if its reasonable it would be a fair tade for the nuisance you are dealing with now.
AG Neovo Technology Corporation
2362 Qume Drive, Suite A
San Jose, CA 95131 U.S.A.
Tel: 408-321-8210
Fax: 408-321-8211
Posted on Feb 01, 2008
0 characters
3 Points
The power adapter for this monitor is overheating and the monitor is turning off as a result. Where can I get another power adapter?
The computer store sells universal power supplies that will work with your monitor, and they may even have the exact replacement.
Feb 14, 2011 | Polyview S17E 17" LCD Flat Panel Monitor
Hello, I have a Kds Radius RAD-7C monitor and the original power supply is no longer working. I have a universal power supply with a range from 15 to 24 volt and 6 amp, my question is, can I use this for...
6A is OK, HIGHER CURRENT is OK but not higher voltage, the main key is that the pwoer supply MUST be REGULATED power supply. Does it say that on the universal power supply that you have?
Basic LCD monitor and LCD TV troubleshooting guides:
Failed LCD monitors, LCD TV's pictures:
Learn about bad caps:
Capacitors kit: he can make you a set of caps for you.
Dec 20, 2010 | KDS Radius RAD-7 17" Flat Panel LCD...
I have a 17" Scanport
You may buy any adapter with 12V, however, make sure the new one also matches at least the same Amp. of the monitor. Universal laptop adapters are ok to use.
Nov 07, 2010 | Scanport 17" LCD Monitor
Cornea 1810 monitor power cord
Apparently the monitor's power consumption is near or slightly exceeds the specified value.
My suggestion would be to purchase an adapter with higher rated output current - if for example your original adapter was rated 12V 4.5A, go for a 12V 6A rated adapter. A 30% safety overhead will hopefully contribute to higher reliability.
Nov 18, 2009 | Cornea CT 1810 18.1" Flat Panel LCD...
Power Adapter for X2Gen MW22U
It seems ebay also sells the 12 v power adapter as well Click on the link
Jan 22, 2009 | Computer Monitors
Sceptre LCD Monitor
I did not have a power adapter for my lcd monitor but after 2 weeks of searching stores, internet and universal adapters I found the power adapter for my specific monitor on ebay. If that doesn't work I would suggest a universal power adapter.
May 28, 2008 | Computer Monitors
Need to know the polarity
you can set positive and negative of the universal power adapter 110v to 220v.
May 05, 2008 | Scanport 821S 17" LCD Display Monitor
Power issue with LCD Monitor
Try another power adaptor. Check the delivered voltage and go get a universal power adaptor that has a switched for varios voltages and a number of connectors. Simply match connector to the voltage switch.
May 21, 2007 | Princeton Digital LCD17 17" Flat Panel LCD...
Neovo E-19A 19" LCD Monitor Logo
269 people viewed this question
Top Neovo Computer Monitors Experts
Clive Gray
buzz flewhart
buzz flewhart
Are you a Neovo Computer Monitor Expert? Answer questions, earn points and help others
