A loud screeching sound from your dryer could be caused by a few different issues. Here are a few things you can check:
Belt: A worn or broken belt can cause a loud screeching sound. To check this, unplug the dryer and remove the front panel. Look for any signs of wear or damage to the belt. If it looks worn or broken, you'll need to replace it.
Drum Rollers: Dryer drum rollers can also cause a loud screeching noise. You can check this by turning the drum by hand. If it feels rough or wobbles, the rollers may be worn and need to be replaced.
Idler Pulley: A faulty idler pulley can cause a screeching noise. You can check this by removing the belt and spinning the pulley by hand. If it feels rough or wobbles, it may need to be replaced.
Motor: A motor that is failing can also cause a loud screeching noise. You can check this by turning the drum by hand and listening for any unusual sounds coming from the motor.
If you're not comfortable checking these components yourself, it's best to call a professional to diagnose and repair the issue.
sounds like the service station siezed and the control circuit to the motor has burned out- common fault for this machine- unfortunately this means its cheaper to buy a new machine than it is to repair- sorry
First, the loud screeching sound may indicate its start-up, but if this doesn't occur everytime you start, it may be a sign of water-exposure in the electric circuits in the PC. Thus it could not send it's signals to the PC and start up the computer. My suggestion would be to go and get it fixed at its retail shop as fast as possible.
Generally, in my experience, the loud screeching is caused by one of the fan motors or fan blades. There is a fan inside the cabinet (possiblle two, one on the freezer and one on the refrigerator side). Also, there is a fan underneath the unit near the compressor (probably in the back).
If the screeching is coming from underneath then pull the unit out from the wall and remove the cardboard cover at the bottom back. Now turn the unit on and check for where the screeching is coming from.
If it is the fan blade (hitting something) or the motor, you can remove these and replace them easily. UNPLUG THE REFRIGERATOR BEFORE TOUCHING ANYTHING UNDERNEATH THE BACK OF THE REFRIGERATOR.)
I try sending a fax then the paper goes through it makes a loud beep and the message says theres been an error try again this happens all the time no matter who I fax. then it prints out error confirmation stating Mode G3 send error
Managed to clear it myself. After making several cell phone calls to my machine last night and unplugging it over and over, etc. I gave up. This morning I again unplugged everything, reset all the settings and called the machine several times. At first I kept getting the "noise", but eventually I was able to call and leave a normal sounding message. Can't really explain what "cured" it! In desparation I did shake the machine and give it a hard slap, but who knows what did it!
If you haven't already done so, look into the printer roller areas, and look for a piece of paper stuck somewhere, or maybe a paperclip or other foreign object which has found it's way into the mechanicals. Also, check the printhead assembly for free movement.
