Question about Samsung HCL4715W 47" Rear Projection Television
Need part #
Found horiz output shorted. on same heatsink is a smaller transistor it has no locatoion# i need part# for it thanks, ronnie w.
  • Samsung Master
  • 8,617 Answers
Re: need part #
Can you read the letters and numbers on the transistor your needing to replace? If so post the numbers and I will post a link where you can order them or their substitue.
Posted on Jan 22, 2008
0 characters
3 Points
Where is the horizontal output transistor exactly?
So Far You've Done Very Good, The Horiz Output Is Located Very Near Or On The Flyblack Panel, It 's Usually A Rectangular Transistor Mounted To A Very Large Silver Like Heat Sink ..It Does Sound Like It's Shorted, But If Not,Check The Focus Divider Or Hv Tripler..
Sep 24, 2014 | RCA D52W20 52" Rear Projection HDTV-Ready...
There is no picture and there is a tick tick ticking noise coming from inside the TV
The ticdk tick sound is probably the switched mode power supply making noise due to the fact that there is a shorted component inside(may be the horiz. output transistor). You may need to have service personell look at unit and get an estimate...this is older set n may not be worth repair
Jan 14, 2011 | Panasonic PT-51HX40 51" Rear Projection...
SONY KP-61V90 tv will not power on, red light in front,
Its 2 times blink error code that shows +B volt supply (+135 volts) is shorted, most probably horizontal output transistor is shorted, replace it.
If you are good in soldering parts in circuit board then take out horizontal transistor, check it, found shorted then replace it with same number.
Horizontal output Transistor Q502 number is 2SD2578 and available in Part Store for $10
Let me know for further query, if any.
Nov 18, 2009 | Sony Projection Televisions
My Samsung 32 inch lcd tv will not turn on
first open rear cover and check the internal fuse, then if your proficient with a multi-meter check the horiz output transistor for a base to emitter short
Oct 07, 2009 | Projection Televisions
please check all the lights that are in the chassis hitachi puts led in the chassis so that if one of the lights are not working then u know that circuit is bad. now there is 2 things that hit has wroung in the units and that is a 2kv hv cap of the horiz output transistor that burns up and kill the power supply look for a small black or brown fuse it will not have glass on it it is rt behind the reg ic in the center of the chassis it allwas opens up because of the hv cap doonot run the tv without out that cap it will overload the horiz drive and will burn upo the horiz output but u have a very good ctv ther if u fix it will last u a long time and it is a very easy tv to trouble shoot.
Oct 12, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
Rca big screen
Most times when this unit chirps the horiz output transistor has shorted. If I remember correctly the transistor is Q401. Some times the flyback transformer can be bad as well T401.
Jan 28, 2008 | RCA P46921 46" Rear Projection Television
Horz. Output Transformer for a GE Mod#46GW945
Check this guys: //
This guys may carry that part: //
Jan 24, 2008 | GE 46GW945 46" Rear Projection Television
Toshiba 57H81
Check all fuses in the power supply and look for any bad connrctions on the PCB. You are probably missing the 130 volt supply to the horizontal circuit. Common reasons are: Shorted horiz output transistor; flyback transformer, picture tube arcing , bad power regulator IC. In short, you need to get a qualified tech for this symptom. Hope this helps.
Oct 29, 2007 | Toshiba 57H81 57" Rear Projection...
Rca p52927 chassis ptk 195 wont power up all of a sudden
ctc chassis with the 195 chassis were famous for flyback transformer shorting and taking out the horizontal output transistor also.
Oct 24, 2007 | RCA P52937 52" Rear Projection Television
Standby timer light blinking, tv will not turn on
Check out Ceramic Capacitor C514 by the horiz. output transistor (burned/shorted?) My question is how do you find the specs of the capacitor and where do you buy one?
Dec 11, 2006 | Sony KP-53S65 53" Rear Projection...
Samsung HCL4715W 47" Rear Projection Television Logo
20 people viewed this question
Top Samsung Projection Televisions Experts
Steven Wander
Steven Wander
The Wyzzyrd
Donald Griswold
Donald Griswold
Level 1 Expert
Are you a Samsung Projection Television Expert? Answer questions, earn points and help others
