FixYa.com
Tags:
Monitors
Generic problem for all Monitors
Dropped lcd monitor
posted by bearcub on Nov 14, 2007
i just bought an lcd monitor on e-bay, (15 inch synco brand i think), while getting ready to put it on the desk, i knocked it onto the floor, power light lights to green and quickly changes to orange, i can very faintly make out that box that pops up concernoning menu or something, is there any hope of me fixing this?, could it be just a backlight? any help would be appreciated
Comment by bearcub, posted on Nov 16, 2007
thank you, thank you, thank you, it worked!!!!
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
FixYa! (100)
rwedinburgh
Rank:Wiz Wiz
Rating: 84%, 74 votes
Very often the problem is that when an LCD monitor is dropped, the ribbon cable and power cables which have very little slack become partially unconnected from the ports they plug into. Unplug the monitor, remove the back casing, and have a look to make sure the ribbon and power cables are seated properly. If in doubt, reseat them by hand.
Good luck...
Rating Locked! (?) bearcub has rated this solution as FixYa!
This Problem Also Relates To: HP Pavilion F1503 15 in. Flat Panel LCD Monitor HP f2105 (Metallic, Carbonite) 21" LCD Monitor Philips 170S4FB (Black) 17" LCD Monitor Philips 170S7FS (Silver) 17 inch LCD Monitor Philips 150S4FG (White) 15" LCD Monitor Westinghouse 22" Widescreen Flat-Panel LCD Monitor Westinghouse L1975NW Monitor
Can you Help with these Monitors problems?
ViewSonic VX924 (Silver, Black) 19" LCD...
ViewSonic VP2920b
Can I turn my monitor from... Answer This...
Tatung - LD23HL Monitor
TATUNG LD23HL
trying to find a repair center... Answer This...
Toshiba 15 LCD Monitor
Monitor on laptop has vertical...
I have a toshiba satellite... Answer This...
Acer Monitor Lcd 22in X223w LCD Monitor
Computer slowing down?
Is it possible that an Acer... Answer This...
LG Flatron 775FT (White) 17" CRT Monitor
no signal
I have LG Flatron 775FT... Answer This...
Repair Service
Find Monitor Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
