Question about HP Pavilion zd7020US Notebook
My top load washer will not agitate or spin,but the pump still pumps water out????
Help what is wrong???? How much to fix do ya think?????? All of a sudden it quit agitating and won't spin!!! Pumps out water though.
    Novelist:
  • 85 Answers
This may not strictly be a laptop computer question, but it sounds like the belt drive on the drum has broken or come off. This is a common problem. If you are handy, unplug the machine, turn it around, and remove the sheet metal screws on the back holding the back panel on. Remove that panel and look for broken or unseated belts. If you find broken or unseated belts, replace them with new ones. If you do not, you need to call in professionals or buy a new washer. Or find someone more handy to help. :>)
Posted on Nov 16, 2007
Have a Kenmore washer that will not agitate or spin water out. What is wrong with it?
does the motor hum? It is either a bad motor, clogged pump, or a bad timer
Jul 04, 2016 | Kenmore 22422 Top Load Washer
Washer will not rinse on any cycle
Well if it won't rinse it won't pump out wither right? The pump is mounted on the motor. The motor won't pump or spin if the lid is open. I would check the lid switch
When this pump is going counterclockwise the water stays put. The machine agitates.
When time for rinse the motor goes opposite direction. If the lid is open the washer will not spin or pump out. I suspect you must have a lidswitch issue. Here is a video which shows how to check it without guessingthemobilian_3073.jpg
Oct 26, 2011 | Kenmore 23822 Top Load Washer
GE washer agitates but won't spin
I think you may have a stopped up pump does it drain the water out if not it will not spin. A putty knife inserted 2 inches in from each side will release the spring catches and gently pull on front as you release sprins then look to the bottom right hand side and there is the pump clamp the tub to pump hose or **** water out with a shop vac take off tub to pump hose and then two 3/8 in screws that hold down the pump turn over where you can look in the pump may have an obstruction as always disconnect power before service.
May 30, 2009 | General Electric WHDSR209DWW Top Load...
Top load washer will not drain
just by your descriptions,you may have trash/blockage in the screen/filter on the inlet side of the pump.to check this before pulling anything apart,take the drain line(with water in the tub of course)& drop it well below the water line in the unit(use a bucket).the water should run fairly fast out of the washer,if not you have a blockage.be sure to get as much water out of the tub as you can if you attempt this yourself.either way let me know & we'll see if we can get it corrected.thanx for using fix-ya!!!
Nov 14, 2008 | Kenmore 22422 Top Load Washer
Roper Model RAS6233KQ Spin Cycle doesn't get the water out
Its sounds like the pump has frozen, If your smelling the belt burning its either that, the tranny binding, Or the tensioner has a defect (very unlikely). If its washing, agitating and spinning okay its the pump. Get ya a new belt while your at it!
Oct 22, 2008 | Roper RAS6233KQ Top Load Washer
My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
Oct 18, 2008 | Whirlpool LSR5132PQ Top Load Washer
Kenmore 2.1 cu. ft. Portable Washer - won't drain
Probably something caught inthe pump. Will have to remove pump and take obstruction out. Only other thing I can think of is the pump ran tight and would have to be replaced
Aug 15, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
Won't empty water slow spin in spin cycle
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
if this helps please vote a fix ya
Jul 15, 2008 | Maytag PAV2300 Top Load Washer
GE washer eill not drain or spin.
if the unit is at least 4 or 5 years old, most likely the pump is clogged with the same hair.....that clogs vacuums. you probably can fix it yourself provided you can get to the pump without too much trouble. i'm not familiar with all the brands designs. maybe someone else on this sight can help. if this is not the problem than most likely some of the timers points are burned. if the unit is more than 10 years old and/or the unit has been used unusually alot there is the possibility that the transmission has problems, but that is pretty unlikely. hope this helps.
Mar 05, 2008 | GE WDSR2080D Top Load Washer
Open Questions:
See all HP Pavilion zd7020US Notebook Questions
HP Pavilion zd7020US Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
