Hello acoach194 - If the washer is not agitating try the following steps:
1) Verify a circuit breaker isn't tripped
2) Advance the timer control dial slowly 360 degrees-
If the washer starts spinning, then the motor and drive belt are fine but that there is something wrong with either the timer control dial or the agitator solenoid. Call in a professional for this. If the washer doesn't budge, then verify that the drive belt(s) is attached and not broken by removing the back panel. If the belt is broken, then it will need to be replaced. If it is loose, then it will need to be tightened. A professional will need to do so by loosening up the bolt holding the motor and moving it on its swingarm (much like a car alternator) until there is a 1/2 to 3/4 inch deflection in the belt.
Some washers use reversing motors. It's possible the motor works on the spin cycle but not on the wash cycle. If so, once again call a pro.
3) Visually inspect the lid safety switch- Is it loose or cracked? If so, the washer might work intermittently, stopping at different cycles.
4) Check motor and drive belt- Remove the main access panel (usually in the back). Is the motor spinning, but the drive belt isn't? If so, then you have a drive belt problem.
The
first thing to check when your GE washer is not agitating, is the belt.
Let me tell you how to check the belt & the clutch with out having
to take the washer apart.
The belt: Set the timer in the spin cycle and pull the timer knob to turn the washer on.
If
the washer drains the water and then spins the way that it should, this
tells you that the motor, belt & clutch are not the reason why your
washer won't agitate.
A broken belt could be the reason your washer is not agitating or spinning.
The agitator: After making sure that the belt, motor & clutch are working ok, lets check the agitator.
The
agitator uses a plastic agitator coupler that is couple to the
transmission shaft by using splines cut in the coupler and on the
transmission shaft.
Too much
usage or overloading the washer too many times will wear the agitator
coupler splines. With out the splines the coupler could not be coupled
to the transmission shaft and that could be the cause why your washer is
not agitating.
The clutch: A
bad clutch could also be the reason the washer won't agitate or spin.
Usually when the clutch is bad the washer will be noisy, like when you
have bad brakes on your car.
The transmission: The
transmission could be the reason your washer is not agitating. A common
problem with the transmission is oil leaking right on top of the motor
pulley and the belt.
As you
can see, there could be different reasons why your GE washer is not
agitating. You just need to keep checking each part until you find the
problem and replace the part responsible.
