Electrical Supplies Logo
Rick gravier Posted on May 30, 2015
What is the spark plug gap for a Coleman powermate portable generator sport 1600
Augusto Aguas
Level 1:
New Friend:
Problem Solver:
  • Contributor 17 Answers
  • Posted on May 30, 2015
Augusto Aguas
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
17
Questions
0
Helped
5009
Points
39
By default, the aprk plug gap is 0,40 MM. It may fit.
5 Related Answers
Anonymous
  • 169 Answers
  • Posted on Jan 07, 2009
SOURCE: checking the gas and oil levels?
There isn't really a guage to look at . What one does is to take out the plastic plug on the side of the engine and with the engine cold and level make sure that the oil level comes up to the lowest thread where the plug screws in.
You really should have a manual, so if it's missing look here for which ever "PM" number is printed on the tag on the end of your generator.
Regards,
Carl
protek480
Craig Butler
  • 1730 Answers
  • Posted on Aug 01, 2009
SOURCE: My coleman powermate generator will start but will not generate.
The voltage regulator controls the output. You will need to check that first.
If you need further help, Iā€™m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Anonymous
  • 243 Answers
  • Posted on Feb 10, 2010
SOURCE: coleman sport 1850 powermate generator, no fire to sparkplug
is there an oilprotection on the gen. disconnect the cable and try again
Sheldon Dedek
  • 912 Answers
  • Posted on Jun 12, 2010
SOURCE: want to remove the starter recoil from my powermate generator
I got one of these pieces of junk, and had same problem you described.
You will need to remove the end panel to get to the blower housing. You will have to thread the rope through the handle until you have enough slack to remove the rope from the handle. The end panel should now be free to remove entirely.
Find the 3 bolts that hold the blower housing on, and remove them. Once you get it off, make sure that the rope has a knot in it so it won't get retracted into the pulley recoil assembly. Take a screwdriver and push the rope back down into the pulley (that was my problem). Assembly is opposite of taking apart.
kel1guy2002
Kelly
  • 3740 Answers
  • Posted on Aug 17, 2011
SOURCE: where can i find a
This generator model was made with 2 different engines
Just using the model number without crossing to an engine it says the Cap PN is: 0049841
Call Coleman at 1-800-445-1805
($10.33)
http://arkansas-ope.com/93400-ms0323-0603.pdf
and
http://arkansas-ope.com/91400-ms7152-0603.pdf
Another source for PN: 0049841
Welcome to Generator Parts ' Generator Systems, LLC.
Generac Parts, Briggs & Stratton Parts and Coleman Powermate Parts.
Can't Find it? Contact us with your generator Make, Model and Part Information.
Call 1-888-207-2169 EXT 3
Email:[email protected]
Let me know if you still can not find a replacement and I will look for more sources.
Thanks for choosing FixYa,
Kelly
3answers
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Manual for powermate 54 series model#545020
what is the low pressure ( ) setting for a powermate 54 series
  • model 545020 is . because .i need a new fuel pump and dont have the manual for it thank you
What is the Coleman Powermate 5000W Generator spark plug gap
Powermate 435001 w Subaru EX30 spark plug gap is between ..006 - .007 according to manual.
1helpful
What size of spark plug do i need for powermate pm0301010
Champion RN14YC, Gap is 0.28/0.31
This is per the owners manual for your specific machine. Hope this helps.
3helpful
Where can I get owners manual?
go to powermate.com and click on the "manuals" button.
The cloeman 1850 portable powermate generator
Check spark, is plug wet? use sae 30 oil for summer use
Ignition coil spark is weak. And where can i find
FIRST check the gap of the flywheel magnet to the magneto coil. Use a business card as a spacer and adjust the gap. If unit has points rather than electronic triggering, check those and timing and gap.
1helpful
Coleman powermate 6250 no spark, switch on, has oil. changed spark plug.
check wiring most likely loose wiring, happens when your generator viabrates
Top Coleman Electrical Supplies Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
john h
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
